Question about Husqvarna Garden
Engine turns over won't start. There is no spark
  • 169 Answers
Poss saftey interlock switch failure. Bad ign coil or the harness has shorted to ground Unplug the kill wire from the coil and if fire "spark" returns then u know your coil is good. Hope this helps
Posted on Nov 20, 2009
What shall I do my car running normally but suddenly the engine stop running and never start again.
need more info, year,make,model, is the engine light on have you retrieved all engine codes, when turning engine over, is it spinning very freely or just like it always did,
RE POST with all this info. to get a better diagnoses
Problem 5 Engine Cranks But won Start
http://www.linnbenton.edu/auto/perform/no_start.html
Engine cranks but won start
Feb 05, 2016 | Cars & Trucks
My mercedes ml350 won't sart..when i turn the ignition it makes a sound but the engine won't start
I don't know if this is helpful but an engine needs three things to work. Air, fuel, spark.
Jan 15, 2013 | 2006 Mercedes-Benz ML 350
My 2000 honda civic wont turn over and has no spark but the ignition coil and modual are both fine
Won't turn over? Do you mean the starter won't crank the engine over?
Or the engine cranks over and won't start, and you have tested for spark when cranking and have no spark? And then you have tested the coil and ignition module, and they tested out good? Am I on the right page here? If so, maybe the next thing to check would be the crank position sensor. The ecu (computer) signals the ignitor (ignition module) when to initiate spark after it digests the signals from the crank position sensor and the cam position sensor.
Nov 04, 2012 | 2000 Honda Civic
2003 kia Sedona won't. start
If this is a sudden occurrence and nothing suspicious happened prior, you most likely lost either gas or spark to the engine. You need to check for both.
Do you hear the fuel pump in the gas tank buzz on for a couple of seconds when you turn the ignition key to ON? Unless the fuel pump turns on and puts gas under high pressure at the fuel injectors, the engine cylinders won't get gas to start. Correct fuel pressure is crucial to know if you have a fuel pump (or fuel filter) problem. If the pressure is correct, it is probably not a fuel problem but a spark problem, although there are less common instances where a fuel injector circuit may malfunction.
The ignition system not producing spark at the spark plugs is the other common problem of no starts. Buy a cheap spark tester at a parts store, plug it into one of your spark plug wires, then crank the engine over and watch for a strong blue spark. You might need a helper to do this. If you see a consistent spark, the ignition system is probably good, although you should probably check more than just one plug wire-sometimes one bad ignition coil in a coil pack will cause no starting. Good luck.
Jan 28, 2012 | 2003 Kia Sedona
My 1999 buick turns over but won't start I had the ignition module checked & it was ok it appears that i am getting spark any ideas why it won't start?
It could be that your fuel pump is not getting enough fuel to the engine to start it. Is your starter turning over or trying to start the engine.
May 24, 2011 | 1999 Buick LeSabre
Was riding bike and was stopped at a red light when it made a loud noise and died, now it won't start. The engine cranks and turns over but won't start.
You didn't say what year and model the bike was but on any four stroke engine, you must have three things for the engine to run. You need fuel, spark, and compression. The easy one to check is the fuel. Take your air filter off and make sure you're getting fuel to the engine. Then, check your spark. Pull the spark plug wires off the spark plugs in the head and insert another set of plugs in the wires. Ground the plugs against the engine, turn the ignition switch on and press the start button. Watch the plugs to see if you have spark. The next test is compression. With the engine cold, remove the spark plugs. If you have a compression gauge, connect it to one of the heads and spin the engine over with the starter. If you don't have a gauge, simply put your finger over the spark plug hole. Turn the throttle wide open and press the start button. You should show about a hundred pounds of compression if you have a gauge or the compression should blow your finger off the hole with a good deal of force if you're checking it that way. If you have all three of these and they're timed correctly, the engine should run. If the engine won't run, find out which of the three elements is missing and work from there.
Good Luck
Steve
May 21, 2011 | Harley Davidson FLHTC Electra Glide...
Garden Logo
167 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
