Question about Kenmore Refrigerators
Instal relay overload
Ins tal relay overload how to put on compresser had repaired once but they used different parts then came with frig
    President:
  • 1,218 Answers
Good day,
The compressor has three terminals sticking out of it. Forming a triangle.
The bottom left is the start terminal, the center top is the common terminal, and the bottom right is the run terminal.
You have 2 wires going to the compressor.
The relay connects the bottom left to the bottom right.
One of the 2 power wires goes to the bottom right side of the relay.
The other power wire goes to the overload, which in turn is connected to the top center (common terminal).
If you cannot connect the parts with these instructions, don't go any further. Take your parts to the supply house where you bought them and let them explain in detail.
Posted on Nov 19, 2009
I do not have a skybox problem ... I was looking at Starter relay information and skybox guy posted starter relay info ... I decided to pay for help ... Frigidaire Gallery side by side DFRS26ZSHB2 ... no...
If it's not cooling and the internal lights and fan are working, then the problem is either the start relay or the overload relay. I checked the model number you posted and I didn't get any information for the number. Please double check the number that is posted inside the unit. In the mean time, take a look at this relay kit. It is a combination start relay, run capacitor and overload relay all in one. Usually the start relay will run you around $25.00 alone so this is what I use to repair this type of problem at a fraction of the cost. Again, please check that model number again and I will get you the pricing for the individual parts. It is best to replace all the relays if one goes out.Here is a link to the ERP410 relay kit.
Regards,Richard
Dec 09, 2011 | Maytag SkyBox MBV1976A Beverage Dispenser
Plug in frigerator and than smelled smoke and saw it coming from back bottom part of frig.
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 07, 2011 | Kenmore Top Freezer Refrigerator
We have a bottom freezer refrigerator-kenmore elite 795.7877-not cooling frig or freezer-makes a clicking sound every once in a while can't get no one to come for 3 days b/c of holiday weekend. Any...
Hi!
Leo Ponder
Sep 03, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
My frig not cooling or freezing.(Room Temp inside) Both fans are working, Lights working, Has power, Hear clicking from rear bottom. Clicks on then off. Compressor at room temp and coils too Model...
Hi!
Leo Ponder
Aug 30, 2011 | Refrigerators
On our 15 year old GE Profile TPX27PF frig the freezed defrosted (system check "FF") and the "warm" light came on for the frig. This has happened several time. After each episode the frig corrects...
Probably the start relay and capacitor....
Check the last tip...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Compressor does not want to start.
If the compressor will not kick on what you have is either a bad compressor or a bad starting device. Generally the unit will try and start and after 8 seconds or so you will hear a loud tick. That indicates the relay is bad. If the compressor is bad it will usually make a loud humming noise.
The start device is plugged into the side of the compressor. Unplug the frig. You can simply take off the wires to the start device (remember where they go!!!!!) and pull it off. You have two piece, the overload and the relay. The relay is the piece that is most likely the problem. Some machines will have these put together in a white plastic block. You can shake this entire piece and if you hear loud rattling it is broken. Sometimes the relay is visibly burned and blacked where it plugs into the compressor. Anyway, if you do not have this white plastic relay/overload combo, the relay is a brown square shaped plastic piece. Shake it and see if you hear rattling. If not, chances are very good the relay is ok, and the compressor is locked up.
Compressor changes are expensive and unless the frig is extremely nice and cost a pretty penny, they aren't worth fixing. Relays and overloads should not break $100 for the parts, and any tech should be able to change one in under 10 minutes. So if it's a relay fix that puppy! good luck :D
P.S. In a RARE occasion the frig may use a capacitor, and the capacitor may be bad. The only way to check is with a multimeter or replace the capacitor and see if it fixed it. This is highly unlikely and therefore not checking from the beginning.
May 29, 2010 | Kenmore 72232 / 72234 / 72239 Bottom...
Here are the unit's issues: 1. freezer won't stay cold and 2, a loud buzzing sound can be heard periodically Any idea what's causing these defects Thank for any help you can offer
Sound's like the start relay overload on the compressor if you hear a humming and a click do not leave plugged in get new relay/overload at you local part store or the compressor winding will burn up and a new frig will occur message me if this is the sound and inconsistent cooling temp b4 you heard the buzzing and click take you model # to the parts store an easier repair which is good....
Aug 24, 2009 | Kenmore Freezers
I have a Kenmore Coldspot 106.53504300 The
you need to check if the compresser is red hot if so change the relay to a 3 and 1 overload relay very easy to in stall
trick put a floor fan pointed at the compresser let it run a while see if you notice a difference
Apr 17, 2009 | Refrigerators
Whirlpool start device
k here we go, thinkkn we can get this to work for you.
the difference is going to be the white overloads in the bag9s). depending on size of compressor they will change, as far a s the relay thinkin ther is onl one in that bag'box/ (brown with 3 possible connections..
if this is the cas e ill asume that the old relay/overload was a onepiece white plastic with smaller connectors.. .you will need to cut off and resplice a new spade connector on the wires to fiut the new piece..
the extras are just that extras, its easier for them to stock and store one part number for a multitude of repairs( youll need only one)
Mar 09, 2009 | Kenmore 50522 / 50524 Side by Side...
Frigidaire upright freezer and frig with freezer on top
it might have low volatge to compressor and burned out overload try unplugging it again wait a few hours and plug it back in it might start working good luck if it doesnt try replacing relay overload compasator they sell a kit called a 3 n 1 start kit
Aug 27, 2007 | Frigidaire 14.1 cu. ft. Upright Freezer...
Refrigerators Logo
62 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
