Question about Midland LXT310 2-Way Radio
I can't get the 2 way radios on the same channel
I bought a Midland 2 way radio LXT 340 for my kid and we are having trouble getting them on the same channel so that we can connect. How does this work?
  • 1,305 Answers
Press the Menu button. The channel number will flash. Press the adjust keys to select the channel number. Press the menu key again and the Subchannel number will flash. Set to desired number. Then press the push-to-talk key to get out of menu mode. Repeat with second radio and be sure to choose the same channel and subchannel. Then adjust volumne as needed.
have fun!
Posted on Nov 20, 2009
Midland extra talk lxt 328
Check your model number and download the manual from here: https://midlandusa.com/two-way-radios/support/owner-manuals/
Jun 07, 2014 | Midland X-TRA TALK GXT400 (7 Channels)...
Midland lxt 328
Jun 07, 2014 | Midland LXT303-A 2-Way Radio
Oops, misplaced my manual for my Midland LXT walkie talkie radios. How do I get a specific channel to use. When I push the scan button it goes thru channels 1 thru 22 but how do I stop it on a specific...
bobduffy39,
Channels are selected by tapping the center button once then using the arrows. The next tap of the center takes you to the CTCSS, DCS, and other functions follow. When scanning simply tap the transmit button and it should stop on the selected channel. Channels 8-14 are FRS channels at 500mw. These are the preferred channels to use for most people. 1-7and 15-22 are considered GMRS and requires a FCC License. Many people have been known to use these channels without having the license. This form of pirating is not recommended. I have included these links which could be of help to you.
To find a PDF Manual for Midland LXT310:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
To locate information on obtaining a GMRS license:
http://wireless.fcc.gov/services/index.htm?job=service_home&id=general_mobile
JTRadiojunkie
Aug 18, 2010 | Midland LXT310 2-Way Radio
My Midland xtra talk lxt 320 is not working properly. Once I turned the radio on it just started buzzing. For some reason I can't turn it off. It also says rx at the top right hand corner. On my another...
Try replacing the batteries with a good set of alkalines. The standard batteries that come with these radios are of poor quality and get weak very shortly after purchasing these radios. The radios will have the symptoms you described when the batteries are weak. At least this has been my experience having these radios.
Jul 20, 2010 | Midland LXT310 2-Way Radio
I purchased a Midland 2 way radio for use in a small library. The series is LXT 110. The problem we are having is with a lot of static and other voices coming in. We have change the channels several times...
This model radio does not have Privacy codes to filter your communications,you should change them for a model with this feature. A radio with this feature you have to choose the channel first then the privacy code in both radios or in all radios that want to communicate with, if any radio that is in the same channel but with a diferent privacy code, will not be heard
Feb 03, 2010 | Midland LXT110 Two Way Radio
What batteries(AAA) can i best use for midland LXT322 two-way rad
i need a manual for a lxt 322 2 way radio and it just had AAA batteries in it is that okay?
May 08, 2009 | Midland LXT310 2-Way Radio
Midland LXT 300
they could be set to the wrong tone or channel.
Apr 08, 2009 | Midland LXT303-A 2-Way Radio
Can't figure out how to get a "channel" to lock on the handset
Here is a link to the owners manual for the LXT-330 420 Series radio:
http://www.hitechwireless.com/pdf/Midland/LXT-330-420 Owners Manual.pdf
I hope this helps.
HiTechWireless.com
Mar 27, 2009 | Midland LXT410 (14 Channels) 2-Way Radio
Midland LXT310 2-Way Radio Logo
181 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
