Question about Garden
Electric trips out when operating trigger on king
When i start my clarke king 100 power washer, my trip switch on my electric board trips out
    Problem Solver:
  • 10 Answers
Too much pressure is tripping the switch, clean the water flow....nozzles etc! happy flushing!
Posted on Dec 11, 2009
Why does the machines cct breaker trip on a simoniz S2000 XE02 pressure washer
It could trip for a number of reasons. If you turn it on and nothing happens for a few seconds or instantly trips the motor is overloaded or burned up or a motor capacitor is bad. If the machine turns on and sprays if you hold the trigger open while you turn it on and then trips when you let go of the trigger you probably have a problem with the cut off switch . The circuit breaker might be too small for the load of your machine. The extension cord might be too light duty and causing the breaker to trip.
Jun 26, 2014 | Coleman Powermate DuraBuilt 1400 PSI...
Clarke power washers 150
Need more info:
What fuse? the one at the end of the cord on the pressure washer? Or the circuit breaker on your house?
If it is the one on the cord it may have gone bad. To test replace it with normal plug (non-GFI) and plug it into an outdoor or bathroom GFCI (GFI) outlet. If it still trips that outlet then there is a ground fault in the device which may be minor or major.
If it is a home circuit breaker remember that electric pressure washers use a lot of power - typically 1500 watts. If anything else is plugged in it can trip the house circuit breaker.
Jun 04, 2014 | Garden
Start button doesn't work on King Size Washer
Are there any lights on at the washer? If not check the washer circuit breaker in your house main circuit breaker/service panel. If it is tripped reset it and try start button again. If it trips again you need a service call. If there are lights on try turning the washer main knob to off and unplug the washer from the wall outlet...wait 10 seconds then plug in and try start button again.
Mar 16, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Electric box keeps tripping out when machine turned on
You have a short or overload fault in the washing machine that causes the circuit breaker to trip out and this prevents a possible fire.
Feb 20, 2013 | Computers & Internet
When the welder is first turned on I can weld with gas for about 5 seconds. Then the breaker trips. ( i have the proper wiring and breaker). The more times I reset the breaker the shorter the weld time...
Hi:
Just make sure that if you are using an extension cable between your machine and the power outlet, this cable is at least a 12 gauge size, if you are using a 14 or 16 it's too small to handle the amps.
Other point is to check that your breaker is 20 or 30 Amp capacity.
Hope this help.
Sep 08, 2011 | Clarke Power Products Clarke 130EN...
Power overload swith in the house has started tripping when the dishwasher is started
Is this happening only now! If it was working OK earlier and tripping now only it may be due to some electrical fault inside the machine.
Switch off all the high power appliances and try the dish washer. If it works you have to check the breaker overall power rating!
If it trips during dish washer ON, the fault could be in the heater circuit of your machine. Heater Insulation would have become weak etc.
May 17, 2010 | Dishwashers
Indesit wd 125 had tripped a fuse switch
So many reasons. Check electronic board, loose cables, power inlet inside the chassie (noise cond).
Jul 27, 2009 | Indesit W 123 Front Load Washer
My maytag neptune has no power any suggestions
Check for ~220 volts AC across the two slanted contacts on the dryer power socket. If nothing, check the house electrical panel for tripped dryer circuit breakers(pair)--push the breakers OFF, then ON to reset. Recheck for 220 volts at dryer socket--if ok now, try the dryer. You need to use a voltmeter for this checking. If it starts, then quits, you likely have an internal short (heating element) inside the dryer case that trips the circuit breakers.
Jul 23, 2009 | Maytag Neptune MAH9700 Front Load Washer
Garden Logo
185 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
