Question about Samsung SGH-J600 Cellular Phone
I have the wire to connect to the pc but it doesn't work
HDMI connection Dell Latitude 6320 to Panasonic Viera TV doesn t work
Look for your cable wire to Panasonic Viera tv or switch on your tv hdmi.
Oct 21, 2012 | Dell Latitude E6320 Computer (blct63s2) PC...
I purchased a SBG901 and have connected 2 MAC pc's wireless - 1 HP printer and 1 Compag laptop, I have one more pc which is running Vista on a HP Pavilion dv5 and visited the HP website to update
It might not be anything your doing wrong, the wireless portion of the card may have just gone bad. you could check this out by reconnecting your old router back up to verify it works or doesn't. If it doesn't work your wireless in your laptop went bad presuming that the wireless was not deactivated on the laptop. if it does work the Vista Driver may be incompatible with the new router, you may be able to hook up both routers at the same time which would allow you to keep using your HP system.
Feb 28, 2012 | Arris SURFboard SBG901 Wireless Cable...
WLAN Chip internal has a Brown and White wire from the monitor into the base, wires came out while replacing DC plug, cannot find which wire goes to MAIN and AUX, cannot find online any where or if it...
Try connecting the white to the Main and the Brown to the Aux.
Then test the Wireless connection.
If it doesn't work then swap them around. and test again.
Dec 10, 2011 | Acer Aspire 4520-5950 Laptop
How do I connect this keyboard to the computer
Keyboards connect several ways. Older systems use a PS/2 connector (round) that plugs into the purple/gray jack on the back of the computer. The mouse plugs into the green jack next to it.
If you have a USB keyboard, it plugs into any USB slot.
PS/2 connections must be made with the computer off. USB connections work any time. If one slot doesn't work, try another.
If the keyboard doesn't work, try another.
Nov 17, 2011 | Unitech K2724U-B Keyboard PC Desktop
The lights flicker on the dash and headlights flicker while driving
You have a loose connection in your wiring somewhere. Unfortunately, this can be time consuming to find. Start with the fuses to make sure they are all good and making good connections. If this doesn't solve your problem. Start tracing your wiring, checking all connectors to make sure that they are connected properly and not broken. If this doesn't solve your problem, you may have a wire that has broken inside of the insulation and occasionally makes contact so stuff works. This is a b*tch to track down. Start at the battery with a test light and at every connection, take the connection apart, stick the test light in the connector and wiggle the wire to make sure it has juice continually going through it. My suggestion is that if it comes to this, have someone else do it.
Aug 24, 2011 | 2001 Dodge Stratus
One backup light works and one doesn't on a 88 chevy 1500. New bulbs and bulb holder.
Connect a Test Light between the ground wire on the light socket (bulb holder) and somewhere on the body (a clean/bare metal surface) and then put the transmission in reverse.
If the Test Light lights up, you have a bad ground (broken wire, bad/corroded connection). If it doesn't then use a Multimeter to check for power on the Positive side of the Socket, No or Low voltage means a bad wire. Battery voltage is generally 12.45 (without the engine running) and 14.5 (with the engine running) So if you're getting less than that (by more than .3) you have a poor connection or damaged wire
Aug 24, 2011 | Chevrolet C1500 Cars & Trucks
Connect the wire of the globe broadband doesn't work
globebroadband preffer IPs..try to encode the IP provided by globe for you..
Jul 11, 2011 | Computers & Internet
A lot of problem WRT54GR with DHCP, gmail, hotmail, google earth, deezer.com ...
Try settings up the MTU to manual.
1500/1400/1300 for cable connection.
1492 for DSL. if this may not work then yes, you need to upgrade the firmware.
Aug 21, 2008 | Linksys Wireless-G WRT54GR Router
Samsung SGH-J600 Cellular Phone Logo
15 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
