Question about GE Adora (DSF25KGTBG) Side by Side Refrigerator
When you open the refrig. the door slams open. I thought there should be a guide to stop that???
  • 999 Answers
There is a small stop to keep it from flding completely back. If the door is swinging back hard the frig is tilted back too far and there is too much heavy items in the door containers.
Eric
Posted on Nov 19, 2009
. I need the hinge door stop on the lower right side of refridge
The door stop part # WR02X10782 If this is for the refrig door , check the screw at the bottom of the door , to make sure it is not adjusted too high , bypassing the door stop . The same door stop is used on both doors .
May 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
MaytagMFD2561HES french door slams open
theoabear,  Seems I ran into this before,  check out the following post the cat here posted.....Catriver
http://www.fixya.com/support/t129304-maytag_fridge_french_door_hinge
Oct 19, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Door hinge on refrig door
the door stop on the bottom of your door is either bent or broken off. this si located on the hinge side on the bottom of the door the part number needed to repair it is WR02X11465 you will have to empty and remove the door from the refrig to replace the part. it is a fairly easy do it yourself fix. good luck and thanks for using FixYa Peyton
Feb 19, 2009 | GE GSH22JFR Side by Side Refrigerator
Refrigerator door
Need to lower the front feet that will adjust your door... let me know
Apr 06, 2008 | Refrigerators
Kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Apr 06, 2008 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Mcb780w
So it's running even with the door open? If not, please reply back with more details. If so, here's my initial answer:
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 18, 2008 | Magic Chef MCB780W Microwave Oven
Kitchen aid superba side by side doors slam
sounds like a door closure is broken on refrig door, a 2 part door closure(cam). look under door where sits on hinge, freezer door should have as well(use for comparison as to broken or not)
Feb 17, 2008 | KitchenAid Superba Architect KSCS25INSS...
Microwave runs when the door is open.. stops when you shut it.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 11, 2008 | Microwave Ovens
Stops cooking
You can usually find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
Jan 04, 2008 | Sharp R-1500 Microwave Oven
Door is slamming open...
Without seeing it.Check to see if the unit is level.If it is, You may want to remove everything on the door and see if it still happens.If the problem still exits, you may be able to adjust the door.
Dec 05, 2007 | Maytag MBF2256H Bottom Freezer...
GE Adora (DSF25KGTBG) Side by Side Refrigerator Logo
205 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
