Question about NEC VT460 Multimedia Projector
I do not have remote. Church inherited projector.
I do not have remote. Church inherited projector. Lamp life has timed out. Lamp is ok. How do I reset time with out remote
  • fourjay267 Nov 25, 2009
    I wasn't able to get it going. By source keys I assume you mean the 'video, s-video and rgb' keys and you mean 'auto adj' key when you say auto. I don't think I mentioned the projector does not turn on the lamp at all. thanks jim
  • 691 Answers
Hello
Thank you for using
FixYa for your problem
  1. you need to enter factory Menu.
    You do so by doing the following:
    1).Start the projector.
    2).Press keypad <Source> and <Auto> keys simultaneously, enter " Lamp Hour info" layer
    3). Press <Source> and <Auto> keys simultaneously again, then enter factor menu.
    Do not change anything till you reach Lamp Layer where lamp hour and usage hour is given. If you reset, then all data revert to default - factory reset. you may chage here or under (2).
    Let me know if this solves your problem.
  2. - Press exit for 3 seconds
    - The Menu to reset the Hours rises up
    - Folow the manual on your screen
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 19, 2009
How to find lamp hours
Hello
Lamp life depends on how much you use it per day. Effeciency of lam detereiate to time. Anyway if you use the projector for 4hours a day, the lamp may last for 1 year. OK.
Feb 05, 2012 | Sanyo PLC-XP51 Multimedia Projector
Lense hours
Hello muhammad
Projector's lamp life is said to be, not with the lens life. Lens is made up of glass. But lamp will go weak. the life of lame will depend on how much time the projectior have used. Normal life of Panasonic projector bulb spans between [1800 to 2000] continous use. It means, if we take the low life span of the bulb as 1800 Hours [1800/24=75 Continous days]. If we use it for 4 hours a day, the bulb may last for [1800/4=450 days ie 1 Year and 85 days] OK.
Dec 12, 2011 | Panasonic Videoprojector PT-LM1E...
How do i check the lamp life on the lvp-x300? how do i check the filters for dust?
For lamp life time, locate the UP, DOWN, and ENTER buttons on the keypad on the projector itself (not the remote) and press all three at the same time. The manual says you may get up to 2000 hrs., but we had to change ours at our church after 681 hrs., it was getting dim. There are filters on the bottom and front of the unit--find them and clean them!
Mar 12, 2011 | Mitsubishi LVP-X300 Multimedia Projector
Installation of lamp unsuccessfull. Lamp light continues to come on after new lamp intalled.
Projectors have a Lamp Life Clock that needs to be reset when bulbs are changed for your projector you need to:
1) Turn your projector on
2) Go to the option menu
3) Choose "Lamp Time"
4) Hold the "reset" button for at least 3 seconds on the remote, or the > arrow on the projector.
5) Confirm the dialogue that pops up...
That should be it.
Mar 08, 2011 | ViewSonic PJ862 LCD Projector
Projector turns on. The blue screen comes on. After the ben Q symbol disapears a warning measage comes up 2004 hrs, change bolb if not bright. Then picture disapears and the temp light comes on! Any...
hi,
its because ur lamps life comes on its end. its time to replace the lamp. after replacing u should rest the lamp timer to zero. if u have already replaced the lamp do the following,if not also.
1 Press and hold the Exit (up arrow) button on the projector for 5
seconds to display the total used lamp time.
2.Press Auto button the projector or on the remote control to
reset the lamp hour to "0".
3. Wait about 5 seconds to let the OSD disappear.
ok
Dec 22, 2010 | BenQ PB6110 Multimedia Projector
I cant get the message lamp life is ending off
Unplug your projector from the power source. Hold down the On/Standby button and the Menu buttons at the same time and plug the power back in as you are holding them down. This will reset the lamp hours used and should remove that message.
May 30, 2010 | Toshiba TDP-S8 Multimedia Projector
Panasonic PT-AE900u no image
may i know now what is the age of your projector. have you done replacing the lamp of the unit before.
Lamp life varies by manufacturer and projector type. Lamp life also depends on the projector's environment: air flow, clean air, and also on the level of usage. Check the user's manual or specification pages for your projector to determine the exact lamp life.
Nov 04, 2008 | Panasonic PT-AE900U Multimedia Projector
XR1X sharp projector
reset the lamp timer (hold down menu, down arrow, and enter buttons, then power on).
Aug 17, 2008 | Office Equipment & Supplies
Projector Lamp
Hi there
Does your Projector go in for regular services ?
Have a technician check out the fans of this unit as well.
I would suggest you hook up a UPS to this Projector , because eventhough you might not have power dips or failures - the power supplied to appliances is not spike free and Projectors struggle to handle this well.
Apr 01, 2008 | Toshiba TDP-TW90U Multimedia Projector
Wont start up
Pls clean the filters and check the lamp by opening the lamp cover. If lamp looks okay in all aspects then send the projector to any engineer to check the ballast unit of the lamp.
Viren
+919814903739
Nov 26, 2007 | Dell 1100MP Multimedia Projector
NEC VT460 Multimedia Projector Logo
570 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
