Question about Alarm & Keyless Entry System for Nissan Vehicles
2000 Nissan Maxima security system just goes off for no apparent reason. Any answers?
  • 1 more comment
  • Tommy Glover Nov 19, 2009
    Thanks. This one goes off without being touched. You can set it and then rock the car and it won't go off, but sometimes just sitting in the driveway it will and then after 30 seconds or so it will stop.
  • clintmoses May 11, 2010
    sometimes the shock sensor is set to be far too sensitive and will go off from slight vibration. Generally when they are installed the installer will do some testing to calibrate the sensitivity. It should take a decent bump before it goes off. If you barely have to touch it then you are going to see if go off from wind blowing against the car, etc. Sometimes they are also very sensitive to cold weather and will intermittently go off for no reason at all.
Where is heater control located on 2000 nissan maxima
check for a stuck open coolant valve to the heater core. check for an air flap that is stuck open too . thanks.
Apr 22, 2015 | 2000 Nissan Maxima
How can I bypass the security system on my 2000
You cannot its thats simple ,dealer only
Sep 27, 2014 | 2000 Nissan Maxima
2000 nissan maxima wont fire
is security light on? do you have correct key programmed for security? if security light is solid and not blinking when starting, you will have to get towed to dealer for reprogramming...
Mar 02, 2013 | 2000 Nissan Maxima
2000 Isuzu Rodeo (just purchased), anti-theft alarm goes off periodically for no apparent reason. Was going to remove fuse, but it is already gone. How can this be possible, unless someone has bypassed...
THATS WHY THEFT SECURTY ALARM GOING OFF THEFT SECURITY SYSTEM NOT WORKING FUSE IS MISSING.MORE LIKELY THE GUY SOLD YOU THE CAR BECAUSE OF FAULT IN THE THEFT SECURITY SYSTEM, GOING COST TO FIX.
May 30, 2011 | 2000 Isuzu Rodeo
MY 2000 Nissan maxima will not go into gear are there any solutions. If the car is off it goes into gear if the car is on it want.
Check the fuses and check if the brakes lights are operational. If not, that would be one reason why.
Nov 18, 2009 | 2000 Nissan Maxima
I put the wrong key in my 2000 maxima now the right key wont work. How do I reprogram it.
Check your owners manual. Put the right key in the ignition, turn it on until the gauges light up and leave it for about 10 minutes like that. If it has a security light or a theft light flashing wait until it goes off, then remove the key and try to start it.
Oct 29, 2009 | 2000 Nissan Maxima
2002 maxima TCS slips or disingages for no apparant reason.
2000 & 2002 Maxima TCS slips or disingages and idle becomes rough for noreason.
Mar 26, 2009 | 2002 Nissan Maxima
Nissan maxima 2001 panic alarm goes off for no reason
Hello, I had the same problem with my 2001 Maxima. The dealer suggested new key fobs, but the eventual fix was the car battery. When the battery is on the way out, the voltage drop is enough to set it off, just as it would if there was a voltage spike when someone breaks in. I have no problems now!
Oct 02, 2008 | 2001 Nissan Maxima
Alarm & Keyless Entry System for Nissan Vehicles Logo
394 people viewed this question
Top SMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a SMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
