Question about Microwave Ovens
No studs for microwave installation
The area where my microwave is to go does not have any studs. If I use 4 toggle bolts to secure the plate, won't that and the cabinet screws be enough to support the microwave? My drywall is a double layer about 2.5 inches thick.
  • Greg Collins May 11, 2010
    Need a better description. 2 layers of drywall would only be
    about 1" thick. What do you mean by the "plate". In
    general I would say no, The microwave is heavy enough that over
    time it will pull the toggles loose.
    Scholar:
  • 142 Answers
If you can secure the mounting plate with four toggle bolts plus the two screw in front you will have no worry.
Posted on Sep 27, 2011
  • 579 Answers
There has to be something in the wall supporting the drywall. You need to find the supporting structure using exploritory holes if necessary and solidly fasten to it using lag bolts.
Posted on Jan 14, 2008
Tip
How to replace the bulb of a microwave oven
Replacing a Built-in Microwave Oven
  1. Step 1 Locate the cabinet above the built-in microwavemag-glass_10x10.gif oven. Find two screwed-in bolts. Unscrew the bolts while someone holds the microwave steady.
  2. Step 2 Unplug the electrical cord from the cabinet above and snake the wire down the hole towards the microwave oven. Continue having someone hold the microwave steady.
  3. Step 3 Roll microwave to left or right to set it free from the mounting bracket in the back. The microwave oven should now be unlocked from its position and can be removed completely from the area.
  4. Step 4 Install the mounting bracket on the new microwave that was included in the package.
  5. Step 5 Snake the electrical cord of the new microwave through the hole in the above cabinet. Plug in the electrical cord.
  6. Step 6 Lift the microwave and rest it to line up with the existing mounting plate on the wall. Roll it until the microwave is locked in place.
  7. Step 7 Use a screwdriver or electric drill to screw in bolts above cabinet into the microwave mounting bracket. This will keep the microwave securely and tightly in place. Your new microwave is ready to use.
on Apr 04, 2010 | Microwave Ovens
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
How do you mount this model
There are two bolts through the bottom of the upper cabinet that attach to the top of the microwave. These support the front of the microwave. There is a wall plate attached to the wall studs that supports the back. If removing the microwave, take care when removing the front support bolts, as the microwave will fall if not supported when these are removed. There are instructions available at www.sears.com under parts direct. Your model number will be a longer number than you have here it will look like this 000.00000.
Mar 10, 2010 | Kenmore 62702 Microwave Oven
Hi there, I'm installing an LG LMV205SW OTR Microwave and the four holes for the mounting plate do not coincide with the two wall studs that are behind the microwave location. Can I sink a couple of extra...
Consider the studs as I I add 2 2x4's like in an H with second 2x4 below the cenre bar in the H adjust both to the spaces needed for your mounting crews if it came with a template use it....I am not a carpenter but It Is what I would do
Dec 29, 2009 | LG LMV2083SW Microwave Oven
I have ge under cabinet microwave model jvm1331 004 that i need to remove. what holds the unit in place?
Look in the cabinet above the microwave. You should see a vent if it is vented outside. You will need to remove the vent. Then look in the same area to find two screws that will need to be removed. Disconnect the power cord and have someone hold the bottom of the unit and remove the screws. It will fall at this point so hold it good. With the screws out and vent removed you will be able to let the front of the microwave down a little. This will allow you to now lift the back to release it from the channel hook in rear. Then you will see the mount plate on the wall. It should have screws securing it to the wall on stud locations. remove these screws and remove the wall plate. Hope this helps. Good luck.
Jul 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
One stud in the middle for an OTR Microwave Install?
i had the same trouble, yes i used a solid bolt to hold the microwave bracket in the stud then used the biggest toggle bolts that will fit, also the cabinet will not have to be changed. it works fine, if you had a vent a hood dont forget to hook up the exhaust vent. i figure your old exhaust vent is in the cabinet like mine was
Dec 31, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Ge spacemaker installed over stove-----need to remove it
Her is a link that I hope with work that shows the bracket and how it was installed.
PDF]
  JVM1850BH/CH/SH/WH – GE Spacemaker Over-the-Range Microwave Oven File Format: PDF/Adobe Acrobat - View as HTML
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
We have a GE Spacemaker Microwave installtion issues
You need to have studs where the installation instructions specify them.
If they are not there, they will need to be added.
With the weight of these units, proper support is critical, and drywall anchors are not at all sufficient.
Nov 22, 2008 | Microwave Ovens
Microwave range hood install -- stud in middle of exhaust
You have a few options, First off, I am assuming that the stud you refer to is an outside wall. Assuming that is true, then you have a few options.... one of them is to cut thru the stud and run the vent out. Even if that stud is on a bearing wall ( meaning it is carrying a roof load above it) ... It is unlikely to pose a problem if that one stud has been compromised with it cut out, If that concerns you.. and you are handy, you can open that area of wall up from the inside and box the area that the vent will be located in with short pieces of 2x4 to the studs on either side of it... Another option is to vent the hood up thru the cabinet above and direct that out slightly offset to the stud in the wall..
One thing I have done is to cut the stud out and then to place a piece of 1/2" plywood in the area that the micro/hood will be located and attach that piece with drywall screws to the studs in the wall.. That piece of plywood will help support the stud you cut when you screw it to the adjacent studs and also act as a place to secure the hood mounting bracket on the wall. Granted, it shifts the hood out from the wall 1/2 " but then you have plenty of surface to secure the plate and don't have to worry about hitting a stud or using wall anchors.. I hope you understand my comments..If not...please respond to this and I will provide additional information to clarify this... Hope this helps !
Aug 13, 2008 | Hotpoint RVM1635 Microwave Oven
Microwave Ovens Logo
226 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
