Question about Syntax Olevia 532H 32 in. LCD HDTV
Screen runs for a while then goes pink i shut it off and put it back on runs a little while then goes pink again
  • 2 more comments
  • boby1957 Nov 19, 2009
    its a lt 30 hv
    olevia syntax lt 30 hv
    sound goes off tv stays on sometimes i get a shade of purplish along with the pink
    ps you can see an outline almost like a negative of the picture frozen thru the pink
  • 10,594 Answers
Let me know exact model and brand of TV to diagnose problem and suggest its solution.
Model number would be written at back of TV.
Thanks.
Posted on Nov 19, 2009
  • Shahid Electronics
    Shahid Electronics Nov 19, 2009
    Thanks for model info,
    Do you get sound in TV while screen gets pink?
    Does TV shut off automatically or screen remains pink?
    Let me know to find out reason of problem.
    It sounds digital video processor on main board problem.
    Main board is available in Shop Jimmy for $145, click that link to see an image of board.
    f you are not comfortable with board replacement, please call local tech to replace it.
    Thanks.
Pink screen on sumsung LCD
Likely to be a bad main board that processes all signal and controls the display panel for tuner and all inputs---other possible boards not likely as they do not know when a DVD etc is being played or not.
Not out of the realm of being possible is a bad connection or loose plug to or from the main board---especially look for any that are secured or held down with tape where they plug into that board.
May 30, 2012 | Televison & Video
Our temperature gauge goes from a blue light to a flashing red. after putting more coolant in, it seems to correct the issue for a little bit then it happens again. Why is this light going on?
The blue light is only supposed to indicate low engine temperature, reminding you to go easy on the engine until the light goes out.
The flashing is either for low coolant or for overheating, and it sounds like you are having a low coolant problem.
If after you add coolant the lights comes back, you have a coolant leak. The most common place for a leak is the coolant flange on the end of the cylinder head. If you take the engine cover off and look at the area where the transmission meets the engine, you should see either pink coolant puddling or pink crusty residue.
It's also possible to have other leaks from the radiator, heater core, water pump, etc. The nice thing is that with the pink coolant it will leave a trace of pink residue leading to the leak if you take a good look around with a flashlight.
Feb 17, 2011 | 1999 Volkswagen Beetle
Monitor goes black after running for a few minutes. Brand new 22 inch sceen.I prees the button to turn it on and it says Analog and goes black again. I have to shut down the computor to get it to come back...
Sounds like the computer is shutting it down and the monitor is fine. Check for viruses then check your settings in device manager for the screen saver and power down (screen off) options.
Aug 10, 2009 | Dell Computers & Internet
My screen keeps turning pink. If I switch the set off then back on it goes away for a little while but comes back again
Basically, the green is either shutting down or going open circuit. It may sound like a Heath Robinson approach but, does the fault appear/reappear when the set is banged or moved?? If so, check the scart leads in the back of the set, these can cause this problem and try different inputs like the inbuilt tuner, if it does it on this then you have an internal fault. If it still faults when you bang or move the set, you have a dry joint within the set. Ian
Jul 30, 2009 | Sharp Televison & Video
I had to replace my Toshiba A105 screen recently due to damage. I installed the new screen myself and it worked fine for a while, but now it has a pink vertical line about an inch thick running down the...
Ok then, take it apart again and make sure all the connections are well seated, check the inverter (circuit board under the screen) the ribbon cable that goes behind the the screen and the block connector that attaches to the motherboard. If all theses connections are well seated and you still get the pink line, the screen is defective and you need to send it back.
Good luck and thanks for using Fixya!!
Feb 23, 2009 | Toshiba Satellite A105-S4004 Notebook
My monitor works for a little while, then goes black.
Your power-inverter board needs an overhaul.
Probably in need of the standard capacitor replacement.
OR
a bulb in the screen is bad (a bad bulb will usually show symptoms)
It will flicker, or will look pinkishish for a bit or dark in the middle top or bottom of the screen.
ebaysbammbammfran
Oct 11, 2008 | E-Machines eMachines Monitor E15T4
Tv screen goes off until you unplug and replug in
That's a video card error. Pulling the plug resets the card, but a firmware or chip problem is reoccurring. It needs a professional service call.
Sep 04, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Frustrated with tv repairman
Good day, rickbowers;
This may be your problem, this model is known for this concern. But let me ask you; is there more fluid on the board? If so put some type of "sheild" over mentioned area. Some shops use a thick cardboard or others use a heavy plastic, install over entire area.
Try this first.
Let me know, good luck, big IRISH.
Jul 20, 2008 | Mitsubishi WS-55807 TV
Lens wont retract
Lens motor is shot - check out Olympus web site for repair options-not cheap
Jul 04, 2007 | Olympus FE-140 Digital Camera
Syntax Olevia 532H 32 in. LCD HDTV Logo
43 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
