Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Rinnai Tropic ventless heater. Pilot will light when cold and heater will run for apx. 2-3 min. then it shuts off and so does the pilot and then when trying to start the pilot it will only stay lit while holding the dial down in the pilot lighting position.
  • bombluewitch Nov 23, 2009
    have this problem. Pilot light will light but when you release the button it goes off. Will not stay on
Found that the pilot tube had dust bunnys in mine so blew it out with a air can i had for the computer now the pilot light stays on just fine
Posted on Feb 09, 2010
Where is the gas pilot and the jet in the rinnai royale
thermo couple or oxygen sensor if it has one you can temporarly bypass the sensor it to check it.believe those are only on ventless heaters.At least something that is somewhat newer technology to an old man
Mar 18, 2013 | Heating & Cooling
I have a Rinnai Tropic ventless propane heater. I can light the pilot and turn on the burners. However, when thermostat kicks off the burners...then my pilot goes out and I have to start all over. I...
The thing with these is over the summer months when they are not in use they get dust inside the ODS safety pilot. When that dust gets in there it cuts down on the oxygen inside and the safety simply shuts down because it was designed to do that. What you need to do is flush the pilot and allow it to dry. I use a product caller but you could use shop air or even a soda straw to blow out the pilot. I used to sell these thermocouples for ODS systems and they are not cheap. Most times they do not solve the problem either because the pilot is dusty. A brand new one won't solve your problem and a cheaper thermocouple don't work on these. More HERE
Here is the whole thing for $52 not a bad price
The thermacouple alone for these cost nearly as much by itself.
Dec 24, 2010 | Rinnai Unvented Gas Zone Heater. 99% fuel...
I have a ventless gas heater. the pilot lights
It just has a little dust in the pilot safety and that makes it think low oxygen levels are present. Ti correct that situation I flush the pilot safety device with rust buster, I relight the heater with pretty good success. I have a page which shows where to clean and has a nice demo which shows exactly how it works HERE
Feb 28, 2010 | Heating & Cooling
I have a glow warm ventless heater and the pilot goes out every 1
Take the 4 screws out and remove the front of the heater. Then blow the dust and cobwebs out with compressed air, I have to do it once a year. The pilot will get dust and hair in it. Hope this helps.
Jan 04, 2010 | Empire ECS HearthRite HB20T Heater
How do you shut down
the pilot light always stays on, its designed to allow your heater to turn on by itself without you needing to light a match every time. if the pilot light is burning you have nothing to worry about. its when the pilot light goes out that a small amount of gas leaks into the room. and by small i mean smaller than a hand held lighter... if you still want to shut the entire thing down you could turn off the gas line feeding the heater or possibly the whole house, otherwise the pilot light will stay on. as far as the actual heater turning off, thats probably controlled by some sort of thermostat somewhere. if you set the temp to very cold it should stay off. if that doesn't work then you may need a new thermostat.
Dec 31, 2009 | Vanguard International VN18B Infra-Red...
Pilot light goes out when I turn the the dial to "On"
Hi no thermocoples are made to be exchanged never come across that in 30 years of gas fitting
Nov 16, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
My ventless propane heating stove shuts off by itself
I have a Rinnai Ventless heater hooked up to a 20 lb propane cly with a Moble home type regulator in line, and when I light it the pilot light lights and stays on. When I turn it to the heat position the pilot light go's out and that it!
Jan 28, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Wont run
check the flame detector it may be a millivolt generator or a flame rod feeding to an electronic circuit.
Nov 16, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
1,169 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
