Question about Motorola Mobility MOTOROKR EM330 Cell Phone
Ring Tone Choices?
On the Motorola EM330, can I use a fiferent ring tone than the one that was "installed" at the factory?
I download musics on Motorola. i want to use musics download as my ring tone. how? i need steps to use music downloads as ring tone
Go onto the music download and click on it then before playing it look at the options they'll either be "set as" or settings. Go on settings or set as and set it as ring tone. If this doesn't work or them options don't appear go onto your main menu and go on either settings or if your phone has one a ring tone setting. Then go onto sound settings. Then click on it and on there should be your downloaded music NOTE: Make sure it's on your phone not stored on your memory card.
Hope I helped Dr Reed
Apr 05, 2010 | Motorola Mobility RAZR V3i Cellular Phone
I have Nokia 1661-A and model: 1661-2b. When
I had the same problem with mine. when I would go to tone settings every time I tried to hit ring tone it would turn off the phone and restart, by the way in ring tone it was blank. No matter what I did it wouldn't work. So I went to settings then restore factory settings entered the code. It reset the factory settings, then when I went back to tone settings the ring tone said Nokia Tune so I hit enter and it gave a list of all other ring tones, then it worked so my phone finally rings.... Hope it works for you.
Mar 23, 2010 | Nokia 1661 Cell Phone
My ringtone goes beep
  1. Push Menu
  2. Choose Settings (Wrench icon)
  3. Then Ring Styles
  4. Choose the second option (Ends in the word "Details")
  5. Change the ringer for messages to be different then calls
Aug 23, 2009 | Motorola Mobility RAZR V3
The problems is rintone is very low how increase ring tone
you will need to frist add the contacts to your phone memory then edit the contacts and assign a ringtone to each contact you wish.
Jun 01, 2009 | Motorola Mobility RAZR V3i Cellular Phone
PERSONALIZE MY RING TONE
i m not geeting download any ring tone in my phone ????????????????
Nov 08, 2008 | Motorola Mobility W375 Cellular Phone
Motorola C139 Ringtone problem
After you made the ring tone, go to Menu, Ring Styles.
Go to Loud Ring Detail, the go to Messaeg Tone. At the end of the factory installed tones, you will se the one(s) you made. Select it!
Apr 27, 2008 | Motorola Mobility TracFone C139-4 Cellular...
MOTO PEBL MESSAGE AND RING TONE
i think this is what you're going for...Go to SETTINGS, then RING STYLES. Whatever ring style (ie, vibrate, silent, vibe & ring, vibe then ring, loud, soft), underneath is the detail for it, which you can then change (bottom right of screen).
So right now my phone is:
"Style: Vibe & Ring" and underneath that is "Vibe & Ring Detail"
Under the details, you can change your ring tone by scrolling down to the "Calls" option and choose change (bottom right of screen). And to change your message tone, just go to "Messages" and then change (bottom right of screen).
Hope that helps!
Apr 08, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Ringing styles problem sir,,
try resetting your phone to its factory settings...
Oct 16, 2007 | Motorola Mobility RAZR V3
Motorola Mobility MOTOROKR EM330 Cell Phone Logo
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
