Question about Samsung Omnia Cell Phone
Samsung Omnia Frozen
I was installing SPB Mobile Shell 3.5 then it said installation unsuccessful so it took me back to my standard ommnia home page then it froze. I couldn't turn it off because it was not responding so i took out the battery. Everything is fine until i reach the unlock screen part then it freezes.
I want nokia c5-03 spb software rigester key
i want nokia c5-03 spb software rigester key
May 07, 2012 | Nokia 5800 Cell Phones
Nokia 5233 spb mobile shell register key
nokia 5233 users plz use this registration key to register your spb mobile shell application, no. is 8C59-8UN9-QGAY
Enjoy the application...;-)
Nov 08, 2011 | Nokia 5230 Cell Phone
I want to download pics from my Samsung Omnia pro 7330. I have a data cable connected to my laptop but i do not see my laptop sensing the mobile phone. How do i download the pics? I have a nokia too. and...
Go to settings of your phone then choose USB data connection. Then choose Mass Storage. Don't click the PC Suite because it will took longer time to upload photos from your phone
Jun 10, 2011 | Samsung Computers & Internet
Can i use Samsung omnia i900 windows phone as a modem to connect to intenet?
1. install the Samsung Omnia modem driver on your Windows PC - can be found @http://www.samsungmobile.com/promotion/omnia/fr/sub02_xp.jsp
2. if you have installed Active Sync on your Windows PC then make sure that before you connect your mobile device to PC you disable "Allow USB connections" from the Active SyncOption menu
3. after you connect Samsung Omnia to PC, on your mobile device go to START->PROGRAMS->INTERNET SHARING and select the connection type (bluetooth or USB - most commonly used would be USB); tap "Connect". Your Samsung Omnia will connect to the mobile network if you have set up a profile for GPRS/HSDPA according to your billing plan provided by the network operator.
Feb 27, 2011 | Computers & Internet
How to install HTC P3400i Spb Mobile Shell 3.0.1
If it is a .cab file, you can directly install in ur PDA by clicking on installable file.If it is .exe, then connect to pc and install it in system which will install in your phone.
Aug 24, 2009 | Computers & Internet
Problems problems with omnia i900
This is the finest trick I am sharing with you...
I have managed to watch YouTube Videos on my Samsung Omnia after doing researching on the internet. You have to access the http://m.youtube.com on the Internet Explorer and it does not work on Opera.
Please install the files according to the steps below.
1.Samsung Omnia i900 Owners you will need this TCPMP/Player version for Your device, TCPMP 0.72RC1-ARM-PPC-recomp-03.cab.zip.
2.FlashvideoBundle 1.4.4.zip
3.Install ac3.arm.cab
4.Install H.264.cab
And njoy!!! Watch YouTube on the Samsung Omnia...
Please reply if it helps or in case you need any other help in this regard.
Aug 19, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
SPB mobile shell
go to ur program files, both location of ur storage card an my device location...then remove the folder SPB....also goto windows\program\and del the spb too..it will work
Mar 05, 2009 | T-Mobile MDA
Icontact by default on mi samsung omnia
why dont u try modding ur phone menu i mean change it to SPB mobile shell and then u can change the soft key or just set the hardware key on the right of the PDA used for menu u can customize it in settings and make it go for icontact then when u press that key it will bring i contact , or u can google there is software for changing soft keys and hard keys , i will not suggest playing with ur registry
Feb 02, 2009 | HTC Touch P3450 Smartphone
Internet settings for samsung omnia 3 uk network
3 mobile internet seettings for omnia - see this page: http://www.3g.co.uk/3GForum/showthread.php?t=73345&page=2 , instructions are for HTC but have just tried them on my omnia and it finally works !! (on 3 mobile PAYG)
Nov 15, 2008 | Samsung SGH-i900 Omnia Unlocked Cellular...
What is a better software for omnia? spb...s2U2...or touch flo 2d OR CAN YOU INSTALL THEM ALL TOGETHER?
2 of the things you mention SPB and TouchFlo 2d are user interfaces.
i have used both in the past and each has its positive and negative points.
SPB mobile shell gives the benefit of making your Omnia much more finger friendly. when i had this installed i really didnt have a use for the stylus any more.
where it falls down a bit is in the way different things work inside the shell itself.the basic omnia screen still runs in the background, then you have to touch the soft button in order to launch the mobile shell each time you reboot the phone. also if you hit the bottom right hardware button the screen reverts back to the basic samsung screen and you have to hit the soft button again to relaunch the SPB shell. if it had a bit more of a flowing feel to it i would have stayed with it but it almost felt clumsy compared to other user interfaces i have tried.
i am currently running the TouchFlo2d user interface and have to say i am quite happy with it. it is also known as Manilla2D. i followed the basic instructions here http://www.modaco.com/content/i900-omnia-rom-discussion/274737/update-24-nov-08-custom-rom-manilla2d-with-alternate-landscape-dxhk1-m2d04/ and have not had a single problem with it as of yet....been installed for 2 weeks now.
full install instructions are on that forum thread as well as a ton of different Omnia only themes you can install to change the look of TouchFlo to better suit your personality.
i dont reccomend installing both user interfaces at the same time unless you just basically want run out of internal software memory ( this is different then storage memory)
the 3rd app you mentioned is simply a screen locker.
S2U2 can be used with either of the above UI's but i found it, for lack of a better word, useless.
holding down the right lower hardware button for 3 seconds locks the screen anyhow. then it takes 2 taps to unlock it again.
if you are simply trying to emulate the slide to unlock on the iPhone then maybe you bought the wrong phone to start with.
other uset interfaces you might want to take a look at are winterface and pointui.
i have already found my fav but maybe your tastes are different.
good luck
Oct 11, 2008 | HP OmniBook XE3 Notebook
Samsung Omnia  Cell Phone Logo
205 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
