Question about Pool & Spa
I have a raypac RP2100 model # CR185MN ASME. I want to know how many millivolts are required to operate the gas valve ?
  • 366 Answers
Generally, it should operate properly at around 500mv. There are different gas valves that require anywhere from 250mv all the way up to 750mv. If you're in that range, the gas valve should work. If you have a weak thermopile, a replacement should do the trick. It's also good to clean all the contacts on the gas valve, pressure switch, and other components. Also make sure you have adequate gas pressure and a strong pilot.
Posted on Nov 20, 2009
How do i light the pilot light for the hayward
The lighting instructions are usually located inside the heater on the inside of the access panel or on the firewall near the gas valve.
Most millivolt heaters require you to turn the gas valve knob to the pilot light position and then depress the knob while lighting the pilot through the pilot hole. This varies depending on the exact model.
Aug 07, 2012 | Hayward 250 1 Millivolt Propane Pool...
Raypac 2100 rvo error code
check high limits or fusible link if quit while running could have overheated
Aug 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypac 407 ASME swimming pool heater Do you have a troubleshoot manual for this heater that I can download ?
if pump ok and filters ac going to unit check transformer if ok check safety circuit if ok on cycling check ignitor if ok check gas
Jun 20, 2011 | Raypak COMMERCIAL R407A 399K BTU ASME...
Just bought a used RP2100 P-R265A-EN and after hooking it up I following the operating instructions in manual but pilot does not light and after 2 minutes the LCD screen reads PLT (top left corner it shows...
Be sure to open the gas line at the heater and turn on at local valve to bleed the line. Let run for a few seconds till you smell gas. Close valve and close line then let sit for a few minutes till gas clears and try to light again. Let me know how you do and good luck.
Apr 23, 2010 | Raypak RP2100 DIGITAL POOL HEATER R265
The raypac 2100 pool heater turn on but when you go to fire it al
If you hear it sparking, verify the spark is happening INSIDE the combustion area and not shorting out at the ignition module. Also verify you actually have gas available and the gas valve is turned on...
Apr 08, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Empire wall heater with wall vent pilot light
It sounds like the gas valve is dropping out. Make sure the system is venting the exhaust(no restrictions). Then make sure all your wiring connections in the unit are tight. In a millivolt system if all wiring connections aren't tight and clean your circuit will drop in millivolts and the gas valve will drop out. The gas valve requires a certain millivolt to stay open. I hope I was of some assistance!! Good luck!!
Nov 29, 2009 | Empire Direct Vent Wall Furnace Millivolt...
Coleman Gravity Floor Furnace need millivolt gas valve & pilot ki
Go to www.grainger.com and look for a "power pile generator" this is a millivolt thermocouple that may be just what you need to make your heater work again
Nov 12, 2009 | Heating & Cooling
I have a Raypac C155A LP spa heater. won't light
I would agree with you. The pilot generator has probably degraded over the years and is only proving enough millivolts to power the pilot but not enough to run the gas valve for your main burners.
Replacing the pilot generator, preferably the entire pilot assembly, will fix the problem.
Sep 05, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Comfort Glow Vent-free Gas Heater CGN18B
the pilot light is operated off a millivolt generator. that is the small tube directly in the pilot flame. its purpose is to generate a small dc current which is connected to the pilot valve inside the main valve. setting the control to pilot opens just the pilot gas supply. when operating normally the millivolt generator keeps a small electromagnet pulled in that keeps the pilot gas supply open. if it don't work the pilot gas supply valve closes. replace the thermocouple.
Dec 04, 2007 | Heating & Cooling
Pool & Spa Logo
161 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
