Question about Linksys Wireless-G WRT54G Router
Wireless Linksys router won't reset to factory default. Have attempted to press reset button for one minute. Have unplugged. Nothing works.
    Problem Solver:
  • 18 Answers
There should be a tiny hole about the size of a pencil head either on the back or underneath the router. You will need a pen, pencil, or paperclip to press in the hole. That should reset the router.
Posted on Nov 19, 2009
Wireless LAN button won't switch off.
Most Netgear routers have a recessed button on the back or bottom panel, marked "Reset" or "Restore Factory Settings". Because the button is recessed, you will require a thin tool to press it. Most people use a straightened paperclip.
  1. Power up the router, and wait for it to complete booting up, typically about one minute.
  2. Press the Reset or Restore Factory Settings button until the test or power led starts blinking. This takes about 20 seconds. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the reset was not successful, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the Reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Apr 17, 2013 | NetGear N600 Wireless Dual Band Router
Tip
Wireless Network Password - Linksys
If you are unable to connect your laptop wireless to your Linksys wireless access point/router, the easiest and fastest way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.
There are 2 steps involved Reset your router, Setup/Secure a new router
Reset your router:
First
  • Unplug your DSL/Cable modem from power (not your access point/router) Leave this unplugged for now
Second
  • On the rear of your Linksys router you will find a small RESET button
  • With the power still on the router, Press and hold (with a pin/pen tip) the RESET button for 30 seconds.
  • Release the RESET button a wait 15 seconds for the router to reboot
almost done....
  • Unplug your Linksys router from power
  • Plug your DSL/Cable modem back in to power
  • Wait 1 minute for the modem to boot up
  • Be sure the ethernet (cat5) cable from your modem is securely plugged into the WAN port on the back of your Linksys router. This is usually labeled WAN or Internet above the jack
  • Plug your Linksys router back into power.
You will now be able to connect to the internet with your wireless device. I would advise that you follow the next steps in securing your wireless network.
Log into your router
  • Type 192.168.1.1 into your web browser and hit enter
  • In the login fields (case sensitive):
  • Username: leave_this_blank
  • Password: admin
  • Click OK
Once in the web interface for your router
  • Click Wireless tab - Basic Wireless Settings
  • Find the Wireless Network Name (SSID) field
  • change this to your new network name (this is the name you will see when you connect through your wireless device)
  • Find the Wireless Channel field
  • Change this from 6 (default) to 1 or 11
Magoo
on Mar 12, 2011 | Linksys Wireless-G WRT54G Router
RESTORE FACTORY SETTING
Press and old the reset button on the router for 20 seconds. Release the reset button. Wait for 30 seconds. Power cycle the router.
See How to reset Linksys router to factory default settings.
Also watch video
Jun 12, 2012 | Linksys WRT160N Wireless Router
It has password and I can't open it
Resetting the Linksys Router to Factory Default
To reset the router to its default settings, press and hold the Reset button located at the back of the router for 10 seconds.
IMPORTANT: Older Linksys devices may require pressing and holding the Reset button for 30 seconds to complete the reset process.
kb19584-003_en.png To perform hard reset on your Linksys router, follow the steps below:
NOTE: The location of the Reset button may vary for every model.
If the normal reset does not work, unplug and re-plug the router's power adapter while pressing the Reset button.
You can also reset the router via its web-based setup page. Follow the steps below to learn how.
Resetting the Router Using the Web-Based Setup Page
Step 1:
Access the router's web-based setup page. To learn how, click here.
NOTE: To learn how to access the web-based setup page on a Mac computer, click here.
Step 2:
Click the Administration tab then click on the Factory Defaults sub-tab.
kb19584-004_en.png NOTE: If the screen on your router's web-based setup page is different, click here.
Step 3:
Under the Factory Defaults section, click on the Restore Factory Defaults button.
kb19584-005_en.png The default settings of your router are now restored.
Sep 20, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
How do I reset my Linksys WRT400N Router to factory defaults
Reset There are two ways to reset the Router's
factory defaults. Either press and hold the Reset
Button for approximately five seconds, or restore
the defaults from Administration > Factory
Defaults in the Router's web-based utility.
There should be a small hole with a red circle around it on the back of the router next to the power plug hole. Use a pin or straighten paper clip to push the tiny button.
Jan 11, 2011 | Linksys WRT400N Router
Setting up wireless password
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
To perform a hardware reset on your Linksys router, follow these steps:
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
NOTE: The image may vary depending on the model number of the Linksys device.
Figure 2: Location of the Reset button on a Linksys WRT54GX router.
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then click on Factory Defaults.
kb4008-004_en.png NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Click on Restore Factory Defaults and select Yes.
kb4008-005_en.png Step 4:
Click OK.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up a Router with Cable Internet Service
Setting-Up a Linksys Router Using DSL Internet
Changing the Linksys Router's Password
Nov 12, 2010 | Linksys Wireless-G WRT54G Router
The Cisco System logo just stays orange, I attempted to repair on my lap top but it won't let me repair.
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Click OK.
Related Articles:
Nov 09, 2010 | Linksys Wireless-G WRT54GS Router...
Tryint to reset my wireless router to default settings. Can you help me?
The router's admin page is http://192.168.1.1 or http://192.168.0.1 and the default password should be either "admin" or "password" without quotes. There should be a choice under "Setup" called "Factory Reset". That will erase the settings and reset it like new.
Alternatively, you can follow the procedure as given below on all the brands I've tried (Belkin, D-Link, Linksys)
1. hold the reset button for 30 seconds (don't release)
2. unplug the power (still holding reset) for 10 seconds
3. plug power back in (still holding reset)
4. hold reset for another 30 seconds - the lights will usually begin flashing in some odd pattern
5. release the reset button
6. wait 1 full minute or until the lights stop flashing
7. unplug the power for 10 seconds, just to do a reboot
8. verify the settings (e.g. SSID) are back to the defaults
Get online router/wireless router support at http://www.vtechsquad.com/linksys-router-support/ to fix Linksys router/wireless router issues.
Dec 21, 2009 | Linksys WRT160N Wireless Router
Reset to factory default
Get instant online Linksys router/wireless router support at http://www.vtechsquad.com/linksys-router-support/ to fix Linksys router/wireless router problems.
Oct 25, 2008 | Linksys Wireless-G WRT54G Router
Factory Default Reset Procedure
Hold the reset button in for 10-15 seconds... Now its defaulted back to factory and the user name and pass will both be admin
May 07, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
242 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
