Question about Garden
Replacing the fuel vent hose on a Stihl chain saw
Had to replace the fuel vent hose on my Stihl 029 super that somehow my son lost. I hooked up the tank end and can't figure out where the opposite end goes. The shop wants a minimum charge of 75.00 to show me. I hate getting ripped off. Can you help please? Thanks
If it's the clear vent hose that connects to the tank on the left side, that's it. There is a brass plug inside the hose that meters outside air in the tank to regulate the pressure. The hose connects to the tank nipple, done.
Posted on Oct 17, 2011
    President:
  • 2,220 Answers
I'd try to contact them. Stihl IPLs are proprietary (not on-line) they may be willing to provide you one. it will probably have the detail needed to answer your question.
Stihl USA
http://www.stihlusa.com/contact.php
HTH
Lou
Do you have more than one Stihl dealer close? Sounds like this one doesn't need your business!!!
If all else fails someone with your model saw will probably help you here: Please do a dearch your question may have been asked and answered.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
Posted on Nov 19, 2009
Were does the small vent tube out the top of the gas tank go on a stihl 029 farm boss. mine broke off flush with the nipple and is leaking gas badly.
This is very important that the connections are correct. The fuel is pulled through the carburetor to purge all the air before starting. Air will keep the fuel pump from refilling the carburetor when attempting to run.
A filter is attached to the end of the fuel tube located in the tank. This hose is the fuel pickup and passes through a tight hole in the tank. The other tube is the return also from the carburetor and is open on the end returning inside the tank also fitting through a tight hole in the tank.
It is easy to reverse these tubes. If one has cracked it is likely all need to be replaced. Take pictures and take notes before starting.
Reversing the hoses allows for unfiltered fuel to fill the carburetor with the result of plugging the jets.
Feb 25, 2017 | Stihl Garden
I need to look at a parts diagram for a stihl 029 farm boss. I started leaking out of the vent tube tube on the gas tank when saw is on it side. There is nothing attached to the vent.
The vent hose attaches to the white nipple coming out of the tank. This hose is about 2 inches long or so and contains two little grub scews to allow a small amount of air leakage. One can be fabricated or easily acquired from a Stihl dealer. (note, the other end doesn't attach to anything)
Oct 25, 2016 | Stihl Garden
Fuel lione and filter came off in the tank
This is a simple repair.
1. Drain tank save fuel can be used again
2.Purchase fuel line replacement kit Lowes -Home Depot
3.Kit needs to contain feed wire and gas hose.
4.Disassemble cover to reveal fuel line connection to carb.
5. Feed wire from kit into fuel tank through fuel line hole.
6. Install new hose over wire connecting end into hook at end of wire
7. Pull hose through tank up to the carburetor
8. Remove wire and connect filter and hose to carburetor
9. Replace gas into tank, Ck for leaks
Nov 15, 2015 | Stihl HT101 Pole pruner
Gas vent hose is missing. What goes on end of replacement hose?
A lot of Stihl have a tiny tiny tiny allen headed set screw just screwed into the open end of the vent. Some have a fancy deal with many descriptions. Try a set screw ran in flush with the opening of the vent tubing. Keep it clean and venting, because an unvented tank will not allow fuel to be drawn into the cylinder.
Mar 15, 2015 | Stihl 029 Chainsaws
Gas tank vent
filler neck vent hose to tank/vent line from tank to carbon canister under hood that then hoses to fuel throttle body.
Mar 18, 2014 | 2010 Ford F-250 Super Duty
Take apart stihl blower for repair
If you have the correct Stihl hose , then pull air box off and will probably have to remove the 8mm nuts that hold carb on and disconnect the fuel line and fuel return line and throttle linkage. then empty the fuel tank and pull the filter off the end of the hose and remove from the top. You will have to probably make yourself a hook out of rigid wire, hanger works good, just something to hook fuel line to pull through the cap opening so you can pull filter off old hose. then insert new Stihl hose from the top and grab it from the fuel cap hose with needle nose pliers or hemostats and pull gently not cutting the hose but enough to pull hose into tank to where groment on fuel line is in place in tank, then install NEW fuel filter and make sure your return line is good, I would replace both while I'm there, then reassemble it. if it doesn;t run right you may have to pull carb back off and dissemble it and clean it cause it may have sucked dirt through the crack
Nov 17, 2011 | Garden
My Stihl Farm Boss 029 leaks gas when I run it. The saw runs fine. It appears as though theres a small hose missing from the top of the gas tank. Looks like there should be hose going somewhere but its...
It could be the fuel tank vent is missing.try looking up your model number at ereplacementparts.com.It will show a diagram of whats where and the part you might need.
Mar 02, 2011 | Garden
Stihl 029 super oiler is not working
Pull off the clip and sprocket, then check the spring or wire behind the clutch. There is a notch in the sprocket hub that drives the spring when the hub is spinning. Sometimes the spring comes off the worm gear that it drives. If the spring is not there you need to remove the clutch to check it. It has left handed threads on it)
Mar 08, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Need to know where the FUEL FILTER is on the Stihl 029 model
Some chain saws have the filter as the little bulb that picks up the gas down in the gas tank. Remove the gas cap and look in the gas tank. Using a piece of wire with a small hook bent into one end, reach into the tank and catch the pickup bulb. Slowly pull it out of the tank. Clean it with clean gasoline.
Jun 05, 2009 | Garden
Garden Logo
3,138 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
