Question about Sony KP-51WS500 51" Rear Projection Television
Power led flashes 9 times. No power on. - Sony KP-51WS500 51" Rear Projection Television
  • Sony Master
  • 5,138 Answers
In your Google search Bar Type in Understanding Sony Blinking Codes there you will find what you need to repair TV for Parts Call Encompass Parts or look them up online as well 1-800-638-3328
Posted on Nov 19, 2009
Need cods
  1. Turn on the component you wish to control
  2. Press the button for the device you want to program.
  3. Press and hold the [SETUP] button until the LED flashes twice.
  4. Enter the code 9-9-1. The LED should flash twice.
  5. Alternate between pressing the [POWER] key and the device key until your device shuts off, or use [PLAY] for VCR, LD, CD and DVD players. This may take some time as there are hundreds of codes.
  6. When your device turns off, press the [SETUP] button to save. After you have configured your devices using the Code Search feature, you might need to find out which code was assigned.
  7. Press the button for the device you want to program.
  8. Press and hold the [SETUP] button until the LED flashes twice.
  9. Enter the code 9-9-0.
  10. Press the numeric button [1] and count the number of times the LED blinks. This represents the first digit of the four digit code. Press [2] for the second digit, [3] for the third digit and [4] for the fourth. If the LED does not blink, the number is 0.
Feb 19, 2011 | One For All URC-7800 Remote Control
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
My Panasonic PT-60Dl54J tv shut itself off and the power button is now flashing red 6 times. What has happened, how do I fix it?
This is straight from the service manual (I'm not sure what the problem is but it sounds serious):
8.2. Power LED Flashing timing table
When an abnormality has occurred, the protection circuit operate and cuts the power supply. At this time, the defective line can be
identified by the number of flashes (red) of the power led indication at the front of the unit.
NUMBER OF FLASHES CIRCUIT MICRO PIN
1 LOAD SHORTAGE 92
2 OVER VOLAGE 93
3 FAN SOS 94
4 MAIN 3.3V 88
5 LAMP DISABLE 61
6 GC3FM-IIC IIC
7 GC3FS-IIC IIC
8 GC3I-IIC IIC
9 COLOR WHEEL STOP 110
Dec 06, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Led with number 9 displayed is flashing
LED 9 flashing can mean many things. Here is the list of "flashing codes" for the vostro 1510.
Keep in mind a flashing led is going to blink 3 times. for example,
number one would look like this:
On (solid lit). Blink, blink,blink (paused off) blink, blink, blink... (paused off), (then repeat)
1. ON-FLASH-FLASH = No Ram or ram not seen
2. ON-FLASH-ON = Ram has a problem
3. FLASH-FLASH-FLASH = Motherboard failure (replace board)
4. FLASH-ON-ON = CPU Fault/failure
5. FLASH-ON-FLASH = LCD detect failure/fault
6. ON-ON-FLASH = MINI pci card (controller) failure/fault
7. FLASH-FLASH-OFF = Keyboard fault/failure
8. FLASH-OFF-FLASH = USB FAILURE
9. FLASH-FLASH-ON = Video BIOS or BIOS issue
10. ON-FLASH-FLASH = Modem issue
Depending on the blinking code, you might just need to re-seat or replace your RAM or your CPU. But then again, you could have a more severe motherboard issue.
Nov 01, 2009 | Dell Vostro 1510 Motherboard System Board...
Is it multiregional
Sony are probably the most protective manufacturer of this kind of information. All manufacturers carrying a DVD logo are obliged to say "no" but will normally intentionally leak this to boost sales, particularly in non-US areas.
But try this:
  • Press the DVD button
  • Hold down the Magic button until the unit performs a double LED flash
  • Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option 3. On your DVD recorder, using the official Sony remote, select the Setup option 4. On your DVD recorder, using the official Sony remote, select the Options option 5. On your DVD recorder, using the official Sony remote, select the Command-Mode option 6. On your DVD recorder, using the official Sony remote, select the DVD1 option 7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover 8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player 9. Program your OneForAll remote with the following instructions:
  • Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
  • Press the Magic button once
  • Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
  • Press the 1 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
  • Press the 2 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
  • Press the 3 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
  • Press the 4 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
  • Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode 15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 16. Your DVD player should show the words TIMER OK 17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 18. Your DVD player should return itself to Standby mode 19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Nov 27, 2007 | Sony DAV-S500 System
Sony KP-51WS500 51" Rear Projection Television Logo
127 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
