Question about GE Dishwashers
Timer knob is stuck and won't turn
GE GSD1380TWW timer knob is stuck and won't turn
2 Suggested Answers
whytfang
  • 170 Answers
SOURCE: Locked timer knob in GE Nautilus dishwasher
I ran into this problem earlierr today ....Check the float valve...it is a round looking device in the front (usually) of the DW...if this gets stuck it will (or may) get stuck in drain or in assist dry mode...push it up and down you should here a clicking noise. Take it out and see that there is no debris in it ...if so clean it ..and replace...then try the Dw.
I hopr this helped....good luck....thanks for rating my effort...The Fang.
Posted on Mar 28, 2009
Set clock on ge profile gas range
Didn't give a model number, but try the following:
For a mechanical clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
For a digital clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
For an electronic clock, touch the Clock pad. Touch the number pad. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
(From the GE website)
Nov 06, 2016 | GE Kitchen Ranges
Set the hour on clock on GE electric stove
Setting clock on GE electric stove
Range Setting the Clock and Timer Non-Electronic Clocks: To set the clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
Digital Clocks: To set the clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
Electronic Clocks: To set the clock touch the Clock pad. Touch the number pads. Touch the number pads. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
Dx4500 ge dryer
Maybe the knob is broken and slipping on timer shaft. If not, replace timer.
Sep 10, 2017 | Dryers
The knob on the right just turns (no clicking) so it does not seem to be selecting a time. now dryer wont start.
Check your timer knob. On these GE dryers I have found a lot of times the knob cracks where the stem of the timer goes in and the resistance of the timer will make ti slip internally rather than turning the knob. If the knob appears to be ok, then I would say you definitely have a bad timer on your hands.
Timer is part number WE4M271 and runs around $100 from marcone's
Knob is
WE1M654 and is around 18$
Good ;uck with this!!
Jul 05, 2010 | GE DBXR463GDWW Gas Dryer
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
GE Top Load stuck at 6 min wash. Will not stop/pause
sounds like your timer went bad, try and replace the timer that is behind the knobs, you will know what the timer looks like because it is behind the knob that allows you to set whatyou want to run and for how long.
Feb 09, 2009 | Washing Machines
GE dishwasher model # GSD2200Z02AD
yep you need a new timer part. on your search engine type in ge dishwasher model number then scroll down to find timer part number order it only if your can take broken one out if u cant then u need to call repairman.
May 13, 2017 | Dishwashers
GE washer timer knob
I can not set the timer on my GE washer. The knob just turns with out stopping.
Mar 04, 2008 | GE WDSR2080D Top Load Washer
Dishwasher knob is stuck
dont turn the knob counter clockwise it could damage timer try prying the knob off it could be shoved in to tight
Dec 13, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
