Question about Whirlpool Dryers
Intermittant heating. The igniter always comes on but the gas does not. It works when it is first stated but then is iffy.
  • jruther814 Nov 19, 2009
    Hi Ginko,
    Yeah, that's what I kinda figured. I don't have a schematic for the dryer so don't know if there is a thermal; switch inline with the solinoid. Model is LGR5620KQ1 Whirlpool gas dryer.
    JR
    President:
  • 1,015 Answers
The way a dryer ignition system works is as follows. The system has two gas solenoid valves that must both be open to allow gas to the burner. One solenoid opens when the dryer is in operation and the second one opens when the igniter is on. The igniter is wired on the same circuit as one of the gas solenoid valves. When the igniter reaches 2200 degrees the electrical resistance changes so that approx 3 to 4 volts will be sent to the gas solenoid valve to open it. This is a safety system that will keep the gas from being released if the hot surface igniter is not on. So one of the gas solenoid valves could be sticking intermittently causing your problem. There is also a chance that the igniter is weak and not always reaching the high temp needed to activate the gas valve. When you turn on the dryer and the problem happens check the voltage reading to both gas valves and verify they are getting the voltage needed to open them. The top of the valves will be magnetic when they are charged also. You can also test the igniter with a ohm meter. It should read 500 to 800 ohms. Now that reading is an average for igniters and might be different for your igniter. They usually have the rating on the igniter body or schematic for the dryer. from what you are describing it sounds like a gas solenoid valve is sticking. And remeber to be very careful doing any work on the dryer. Take precautions not to get shocked or burned from ignition of gas. let me know if you have any other questions or what you find.
Posted on Nov 20, 2009
  • Whirlpool Master
  • 19,396 Answers
Hi.
That is probably the valve coil.
Check also thermal fuse.
If you give me complete model number as printed on service tag, I can be more specific on parts.
Regards.
Posted on Nov 19, 2009
When the thermostat calls for heat sometimes the gas pack works fine and sometimes it doesnt work at all . the inducer motor comes on but the burners dont ignite . what could be the problem ?
Could be the igniter or the thermocouple. The blower has to start first and it does but it will run on endlessly without further action unless the igniter heats the thermocouple to open the gas valve and fire the burner.
Dec 15, 2013 | Carrier 3 Ton 13 Seer Commercial Gas Pack...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101./';
Aug 06, 2011 | Maytag Dryers
Gas dryer heats then wont heat?
Bad ignitor most likely. Has a hair line crack, and yields an iffy contact.
Jun 21, 2010 | Maytag MDG2706A Gas Dryer
Intermittant Heat on Gas Dryer
Check the venting tube. It maybe clogged full of lint somewhere inside of it. If so the moister contro sensor will shut off the burner within due time such as yours
May 01, 2010 | Maytag SDG4606A Gas Dryer
Gas only comes on sometimes propane tank is full
check the voltage to the gas valve in cycle if there constant voltage there during ignition then change the gas valve
Jan 14, 2010 | Dryers
Maytag dryer dg712 does not stay lit
Yeah change the coils read my page on intermittant coils HERE
Apr 12, 2009 | Dryers
Intermittant spark when burner is turned on.
look and see if that electrode is sparking to burnner,,and watch for miss directed sparks from cracked ceramic isulaters..if so change electrodes,,if no sparks change spark module
Dec 23, 2008 | KitchenAid Cooktops
Gas dryer don't heat, pilot ok
The ignitor is coming on so that means you have power to the gas assembly. Next the flame sensor should shut down the ignitor when the bi-metal inside it bends from the heat. This kills power to the ignitor, which allows for the power to activate the coils. The coils snatch open the gas valve and allow for ignition. The raw gas hits that screaming hot ignitor and ignites into a glorious flame, raising the temperature inside the drum. While that flame is on, the control thermostat is monitoring the heat within the drum. When the temperature gets to a round 140 F then the power gets killed to the gas assembly by the control thermostat. If all of that seems to be happening for say, the first time, then suddenly the ignitor comes on then shuts down and no flame comes out, then you have weak and intermittant coils. Replace these puppys:
Dec 16, 2008 | Dryers
Intertherm gas furnace
Need more info. Are you saying that when tstat calls for heat then it short cycles. But if you turn it off then back on it runs ok?
Mar 21, 2008 | Heating & Cooling
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
