Question about Dometic NDR 1062 Refrigerator
Light won!t go out. And how do i get the switch apart.
    President:
  • 2,702 Answers
Its realy not worth trying to fix the switch, its all cliped together and may only just brake up if you try to open it up,,,
Posted on Nov 19, 2009
Sony bravia lcd won't power on after lightning strike
I am sure the tv is shot from the surge but you can check a few things. I would take the tv apart and test the power supply first. Look for obvious burn damage throughout the boards. If there is a blackened one (prob video board) then you can try to replace that. Don't worry about taking this apart and breaking it further. In this case it can only get better for you.
Oct 06, 2012 | Sony BRAVIA KDL-46EX400 46" LCD TV
Blinking cancel light, had broken element replaced and still won't work and blinking cancel light still flashing
You probably have to replace the latch and strike, as well as a switch that is on the latch assembly. It may only be the switch, but when you have it taken apart it makes sense to replace all three parts. Parts should be available on Amazon.
Sep 12, 2012 | Kitchen and Much More Dishwashers
Low beam light won't come on
most of the time that problem is in the switch where u turn ur lights on i would not recommend u take apart ur dash unless u know what ur doing but before u seek help u might try the fuse box and see if u have any bad fuses
Jul 23, 2012 | 2004 Cadillac Escalade Esv
What company manufactured lid switch PS350434 FOR WHIRLPOOL WASHER
3949247 is the actual part number for that lid switch, and you won't find a blow out of the thing taken apart because its a molded part and not designed to come apart/
Jun 03, 2012 | Whirlpool Washing Machines
1990 fzr 1000 won't start
check relay switches, earth wires
May 10, 2012 | 1990 Yamaha FZR 1000
My Whirlpool Dryer GEW9868KQS has power, but won't start when the button is depressed. The sensing light comes on, but the dryer doesn't start. Any ideas?
It's probably either the start switch or door switch. Try bypassing the switch and see if it starts. If it does,you can either replace the switch or try taking it apart and fixing the switch yourself. (I had a switch that simply required a copper contact to be readjusted and its worked perfectly for several years)
Oct 18, 2011 | Whirlpool LER4634J Electric Dryer
My lights, windows, and radio all work fine. But it won't start it makes a click noise but nothing. Then we thought it was the battery so we jumped it and now it won't even make no click noise at...
The "click" sound condition make us guess that could be a bad ignition switch or starter.
It turned out to be the starter. I first took the battery to have it tested and it was fine. Next, I took the starter apart and took it to Autozone to have it tested? and it was bad. It is not easy access to remove the starter. The intake manifold and exhaust system are in the way and need to be taken apart first. See instructions below:
- Take off Intake
- Take off Starter
Hope this helps (remember to rating this answer and leave some comment).
Sep 28, 2011 | 2003 Honda Element
My bike won't start(lights light ,horn works push starter button nothing no power to spark plugs ??? i belive one of the starter interlocks must be stuck in an open position possibly?
Hey, When that happened to me I took the bike half apart and it ended up being the Kill switch. Try rocking it back and forth also if you have contact cleaner flood the switch and let it dry then give it a light spray of wd-40. also check the start switch to be sure it is making contact,bike is in Neutral and the kick stand switch is also working.
Jul 07, 2011 | 2000 Honda Valkyrie Interstate
Dometic NDR 1062 Refrigerator Logo
197 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
