Question about Samsung LN-T4665F 46 in. LCD Television
I have a 42 inch samsung and the sound is fine
I have a 42 inch samsung and the sound is fine but the video signal (s) are white, green, red an blue snow... its like the pixels are overlapping... if youstand back from the screen you can see the menu box but just barely with out of register pixels... any suggestions...?
    Sergeant:
  • 295 Answers
Is it still covered under warranty?
If not - you have a bad processing board and will need to be replaced.
Blessings,
A/V Guy
Posted on Nov 19, 2009
How can i connect a video camera to play through tv. my camera cables are red-white-and yellow. tv. is white-red- green-green-and red.
Your camera has three cables, red and white for stereo audio, and yellow for what is called composite video. Composite video puts the three color signals into one composite signal. Your TV sounds like it has a component video connection, which wants all three color video signals separated onto three plugs. They are usually color coded green, blue, red. Not sure if you mistook a blue outlet for green..... In any case, on my TV, it will allow me to connect a yellow composite signal to the green component jack, the first (leftmost) of the three component video jacks. Not sure if your TV will work this way, but it is worth a try. Otherwise, you can look up accessories for your video camera and see if it can output true component video and stereo audio, but I tend to doubt it will.
Aug 27, 2014 | Televison & Video
Connecting my new samsung blu-ray player (bd-fm57c) to my toshiba theaterview tv.
I don't think that cord will work. HDMI carries video and audio signals, you might get video but probably no sound. You might as well try anyway though so here goes... The red green and blue plugs are your video and the other red plug and the white plug is for stereo sound. The yellow plug is just a lower quality video plug. So plug in the red blue and green plugs into the component video inputs on the TV then the red and white plugs into the audio inputs. DON'T plug in the yellow plug. If this doesn't work go to your local home theater store and ask for a receiver or switcher that will downscale high def HDMI to component video and stereo audio. You can probably pick up a cheap one for around $100. Good luck!
Mar 29, 2014 | Toshiba 50 Inch Big Screen Flat Tv Theater...
Samsung tv plugging the red white and yellow cables but getting only sound and black and white picture
Hi,red-blu-green is a component signal....but red-white-yellow is a video and audio signal....component and video-audio is a different signal.You can not
Apr 14, 2013 | Samsung Televison & Video
Im trying to connect my sega dreamcast which has red white an yellow av cable only, however my insignia NS-32E570A11 led tv only has for component connection with the blue green n red, when i hooked it up,...
Sorry, this will not be easy....
You need to locate a composite to RGB converter box.
Your Sega outputs a composite signal - Video (yellow) and audio left/right (white/red).
The TV needs RGB (red/green/blue) inputs on the component connection...your composite signal divided by three. There are converter boxes out there for around 70 bucks or so.
Are you certain you do not have a yellow VIDEO IN jack on your set? Every LCD and LED TV I have experience with has at least one.
Feb 18, 2011 | Insignia 42" LCD Flat-Panel HDTV
ShubhangiWe try to connect CD player with Samsung LCD TV. CD Player is having Three Component Yellow, Red,White. It dont have Blue and green components.What to do ???
Hi, Component input connectors use the colour convention
Green = Y (luminance signal)
Red = Pr or Cr (Red colour difference signal)
Blue = Pb or Cb (Blue colour diffrence signal)
Composite input connectors use the colour convention
Yellow = CVBS (composite video, blanking, sync)
Red = Audio Right
White = Audio Left
for compatibility both units will need to have matching colours. note the component inputs do not have audio and as such will also have a set of red & white connectors for use with the audio signals too ( rule of thumb Component = 5 connectors, composite=3 connectors)
Sep 23, 2010 | Samsung Televison & Video
The picture is green
Make sure that the unit is connected to the tv properly. Be aware that most dvd players have six connections. You can connect the unit to the television using RCA cables (yellow, white, red) or RCA sound with component video (white, red, blue, green, and red). When using the yellow-white-red method, the sound is carried by the white and red cables and the video signal is carried by the yellow cable. If you're using the white-red-blue-green-red method, the white and one of the red cables carries the sound, and the blue-green-red cable carries the video signal. This connection uses one cable for the green component of the picture, one for the blue, and one for the red. Make sure that the cables are connected properly and you don't have the two red ones mixed up. Connect Sound-R to Sound-R, component R to component R, etc. If that doesn't work, you may be able to adjust the picture on the tv. There's still a chance that the machine is defective.
Mar 08, 2010 | Daewoo DVRS04 DVD Recorder/VCR
Black Screen
You really need to check your video connections. It sounds like you have the sound cables connected properly, but not the video cables. Are you using the component connection (blue, green, red, white, red) or RCA (yellow, white, red)?? Make sure the color coded ends are plugged into the right places. If you've done this then your display is shot and you'll need to get your warranty paperwork out or call a local repair shop. Good luck!!
Sep 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Samsung HD Plasma - hooked up DVD to it but movies play in black & white??
anytime you connect componet signal (green red and blue)to regular video inputs (yellow) end will have same effect. make sure that if you are using component signal from DVD player you have to connected to component input in the set.
component signal will use green red and blue for video and red and white for sound.
Composite signal will be yellow (video)
red and white(audio)
Jul 10, 2008 | Televison & Video
Denon AVR587 Setup
red/white/yellow = composite
red/green/blue= component video cables + audio cables needed
the red/white= stereo audio
the denon 587 has 2 optical (toslink) inputs and 2 digital coax. These are surround sound cables basically, it's the only way to get true 5.1 dolby or dts.
connect cable box, and the samsung to the sony using hdmi. then connect the cable box and the samsung to the denon receiver with optical cable. And that's it.
Jan 15, 2008 | Denon AVR588 Receiver
Samsung 42 inch
Take to repair shop this is no easy fix it yourself problem!
Jan 15, 2008 | Samsung PS42P2S 42 in. Plasma Television
Samsung LN-T4665F 46 in. LCD Television Logo
155 people viewed this question
Henry  Thomas
Henry Thomas
