Question about Porter Cable 18 - Gauge Brad Nailer and Compressor Combo Kit
Will not shut off after pressure is reached, must shut off with switch
  • 2,176 Answers
It sounds like the pressure switch is malfunctioning and should be replaced. I would recommend going to Dewaltservicenet.com and typing in your model number for a breakdown for this compressor and replacement parts.
Posted on Nov 21, 2009
What possible causes have an air compressor shut down before reaching max pressure?
The pressure switch needs adjusting or replaced. The power cord is attached to this switch. There is an adjustment screw under the cover.
Nov 20, 2015 | Air Tools & Compressors
I have a Central Pneumatic 38898 pancake compressor that will not shut off when the pressure reaches pre-set PSI. I have replaced the pressure switch but to no avail...HELP!!
There must be a blockage on the fitting where the pressure switch goes in that stops the air pressure from reaching the regulator. Try taking the switch off and turn the compressor on and see if air comes out the hole
May 23, 2015 | Air Tools & Compressors
Husky Air Compressor wl660800AJ...my problem is the compressor will not shut off after it reaches the shut off pressure it keeps running? checked and supply tube clear....
Hello
Replace the pressure shut off switch.First drain the tank and shut off all power.Remove switch and inspect for any debri or water in the tube to the switch.
Also check the settings.max i think is 150psi.So it should fill to say 145 and shut off.
Sep 26, 2011 | Air Tools & Compressors
I have a portible air compressor, with two gauges on it and it takes a long time to reach its pressure, also once reached it does not shut down
Make sure the air intake filter is clean and make sure there is no leaks in the metal lines and hoses of the compressor by putting liquid soap around the fittings and looking for bubbles. If the compressor is used a lot you might have bad ring on the piston. Since it does not shut off when it reaches pressor the pressor switch might be adjusted right or if it does not adjust you have to replace the pressure switch.
Mar 15, 2011 | Garden
My regulator broke and I just replaced it. Now the compressor doesn't act like it will automatically shut off when it reaches pressure (130 psi max). Last night it pressured up to right at 130 psi and...
Hi, my name is John. Welcome to FixYa. Look on the pressure switch and see what the max. is. I have some notes here I will have to locate them and I will post them here if you still having problems, but it sounds like you need to replace the pressure switch. Thanks for choosing FixYa...John
Nov 20, 2010 | Craftsman 33 gal Air Compressor 6 hp...
Truck starts runs for a second shuts off .
The fuelpump is primed by the oil pressure switch.When the fuel pressure reaches normal PSI the computer shuts that pressure switch off and turns thepoweron to the fuelpump relay.You have a bad fuel pump relay
Jun 02, 2010 | 1994 Mazda 2WD B Series Pickup
Pressure switch dows not shut off motor when
Pressure switch has gone bad and needs to be replaced. Part runs around $25. Go online and put in model number, pressure switch. You will find companies that sell replacement parts. I had to replace mind, it did the same thing.
May 03, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
I replaced the pressure switch and my compressor still will not shut off when the max pressure is reached?
Wiring is incorrect. Do you hear it click when the pressure is reached...if so incorrect wiring.
Apr 22, 2010 | Square D 9013FHG14J52X Air Compressor...
Compressor will not turn off
Most single stage compressors come with a pressure switch set to shut off at 125 - 145 psi. These switches become less efficient over time and will Begin to fail but remain useful. A safety valve (brass plut with pull ring) is installed somewhere on your compressor set to open at aprox. 160psi. If the pressure switch shuts off before the safety valve activates you could probably continue to use the unit. If however you would like to have the unit shut off at 125psi replace the switch any switch that can be installed in the space allowed. The black tubing that you see is the unloader. When the unit reaches set pressure and shuts off, the small valve under the pressure switch will open and release the pressure in the tubing. This allowes the compressor to start with no back-pressure. For max. life of compressor make sure that there are no leaks in system and upplug when not in use.
Pressure switches are sold in pressure ranges from 45psi to 160psi. Some brands are better constructed than others. A squareD switch will give long life being used w/o extension cord. Good Luck
Jan 01, 2009 | Campbell Hausfeld 26 - Gallon Air...
Porter Cable 18 - Gauge Brad Nailer and Compressor Combo Kit Logo
170 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
