Question about Nokia 7373 Cellular Phone
7373 Headset problem
I have a Headset symbol on my screen, without a heatset. So I can speak only via loudspeaker! Please help me°
    Problem Solver:
  • 5 Answers
just try a restart for your mobile. It should be solved by this. incase it is not helping try to reset to factory setting but you will loose your personlaised setting of the hone though.
Posted on Jan 11, 2008
6ya staff
SOURCE:
I have an H-12 headset and I wanted to know can I listen to my music on my phone as well using this earpiece
ive owned 4 different heatsets(bt) and only one that i could get to operate on my phone for both music and talking together via a pause button they made to allow both to be functioned in at once ok aswell that headset has 2 earphones attached also try going into the music setting and try another output for the music sometimes it will help you achieve your results have patience and i hope this helps ok
Nov 17, 2010 | Motorola Mobility Motopure H12 Bluetooth...
HI , i am using a Sony Ericsson T303 Mobile Phone and I can't hear properly when I speak to friends
Your problem might be,
1. with your mobile phone service provider
2. With your friend's mobile
3. With your mobile itself
To sort out problem 1: Use some other network sim card and try it.
To sort out problem 2: Call to some of your other friends and test it
To sort out problem 3: Use headset connected to your mobile and test it by speaking to your friends via headset. If works fine, then there is some problem with your mobile phone speaker. Test the call using loudspeaker as well. Test the call using a bluetooth headset as well ( if one available with you)
So by the above method you can find out where about your problem is and place a service order to your mobile if needed.
I hope this is helpful to you
Thanks
Sep 06, 2010 | Sony Ericsson T303 Mobile Phone (Shadow...
I have Nokia 6233 and it's Headset symbol is displaying on the screen even no headset is connected. It was accidentally turned on. I am able to talk while incoming and outgoing calls only when...
you got a chort cut in the microfone contact,
phone indicates that the headset has been plugged in,and cut of the circuit to the phones microfone.
1)open your phone and clean the microfone connectors and the goldplated surface on the mainboard.
2)if your phone has been very wet, the short cut can be in the microfone.( change microfone)
If solution 1) doesnt help,
try solution 2) and change microfone.
This kind off problem is an common microfone issue.
Hope this helped, Please vote!
May 03, 2010 | Nokia 6233 Cellular Phone
Headset icon on nokia 6280
Have Her Make A Call Then Plug The Headphones In And Out 3 or 4 Then See If The Problem Persists.
Jan 14, 2009 | Toshiba Satellite 1400-S151 Notebook
Nokia 3500 headset symbol in display
I have a similar problem on my phone, which is that when I insert my headset, it does not recognise it. And thus the music is played through the loudspeaker. And if it is recognised (luckily), then after I take it out, I see that the headset sign is still there. The only solution I have had is to turn the phone off and switch it on again. The sign should go away by then.
Sep 13, 2008 | Nokia BNIB NOKIA 3500 Classic Unlocked/Sim...
Nokia 2610 Problems with headset.
I think that when you connected the headset, the internal connection got jammed and even if you remove the headset it will show that the headset is connected.you should see a mobile repairer.the problem is internal
Sep 04, 2008 | Nokia 3110 Cellular Phone
Nokia 6288 fault
koo73 - you need to do a reflash the software on the phone.
lou75 - you need to have the earpiece replaced and speaker
May 20, 2008 | Nokia 6288 Cellular Phone
Nokia 7373
its a problem of connector
please clean it with accitone
and give a normal heat on board
Jan 09, 2008 | Nokia 7373 Cellular Phone
Nokia 6280
reset your phone by this code *#7780# and if not work try this one *#7370#
Dec 02, 2007 | Nokia 6280 Cellular Phone
Nokia 7373 Cellular Phone Logo
162 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
ASHRAF CA
ASHRAF CA
