Question about LG Dryers
The cooling light is on and it wont dry properly
Hi I have a Maytag dryer. I have to turn on the machine twice, but the clothes did not dry properly.
Can you solve this problem?
Thank you.
mn
Posted on Nov 19, 2009
Back of freezer has frost and freezer wont cool to proper temp. icemaker etc also not working
Did you leave the freezer door open for a period of time while the refrigerator was running? Unplug and defrost the freezer manually with a hair dryer until all frost is removed inside and in back of the freezer. Reapply power and see if it will then cool/freeze properly. Let me know the results
APPLIANCE 911
Jan 10, 2016 | Samsung RH29H9000SR RH29H9000SR 36"...
Ran out of fuel. Now why won't it start?
You might not have enough pressure. The fuel pump cools itself with fuel and if it runs dry it will burn up seals quickly. Measure the rail pressure to make sure its correct. If its a little low the injectors wont open properly and let enough fuel in to start.
Otherwise check your spark plugs by cranking with a plug test light in line
Aug 09, 2015 | Dodge Neon Cars & Trucks
Kenmore dryer code ad
The "Ad" in the display indicates that the dryer is in the Auto Dry cycle.
The dryer will run in the Auto Dry cycle until the moisture sensor bars detect no more moisture in the garments being dried. The machine will then go into a cool down period and then end the cycle.
If the dryer is getting unusually hot, I recommend checking for a restriction in the air flow. Make sure that your lint screen is properly cleaned before starting every cycle. Check the flexible vent hose behind the dryer for a kink or a restriction. Check the exhaust ducting to the outside of the house for lint build-up or a restriction. This may help the dryer perform properly.
Sep 16, 2014 | Kenmore Dryers
The cooling light is always on, and it takes about 90 minutes to dry a load.
In normal operation as the dryer is drying the "drying" light flashes and the "cooling" light is on steady until the 5 minute cooldown at which time the "drying" light stays on steady and the "cooling" light flashes. click on this lg link
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6253
Nov 18, 2009 | LG DLE7177 Dryer
DRYER WILL NOT HEAT UP. "COOLING" LIGHT STAYS ON CONTINUOUSLY.
You dry by sensor???
Clean your sensor. The machine thinks the clothes are dry because the sensor is covered with who knows what???
Check your owner manual for the proper way to clean the sensor.
I hope this works for you
a
Sep 25, 2009 | LG DLE7177 Dryer
Lg dryer does not dry clothe properly
the drying and cooling light is on and will not dry properly.
Sep 17, 2009 | LG DLE2514 Electric Dryer
Wont start. Extra dry light on and cool down light on.
Fault #3 Drum Stalled; unable to move.
  1. Check drum movement mechanisms: belt, motor and motor harness (if motor moves drum slightly, treat as fault #2)
  2. Replace the motor control module.
  3. Replace the motor.
Fault #2 Drum Gap Cannot be Located
  1. Ensure sensor module is correctly located and clipped in.
  2. Replace the lens on the sensor module.
  3. Replace the sensor module.
  4. Remove Top Deck and clean the sensing bumps on the outside of the drum end.
  5. Replace the drum.
May 02, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Clothes are taking 3 cycles to dry and cooling light on front wont shut off
The vent is clogged.  To make sure, disconnect the vent from the dryer and run the dryer normally.  If your clothes dry normally, then have a professional vent cleaning company take care of the vent.
The cooling light will always stay on during the run.  When it is blinking, the heat has stopped and is in the cooling process.
If there is no heating, you have a problem with the high limit switch or something else electrical and needs to be addressed by a qualified LG technician.
Oct 22, 2007 | LG DLE2512W Electric Dryer
Dryers Logo
104 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
