Question about RTO Atv Ramp:truck,6-7,lawn Mower,trailer,motorcycle
1990-1996 honda300four tracwill not fire cheched the cdi box and the coil all are good what could be the problem
  • 30 Answers
I would remove the flywheel and inspect the key. Many times these are sheared and timing is off.
Posted on Nov 30, 2009
My 1980 pe 250 is getting fire from magnetio to cdi box but not to coil put new cdi box off a running pe 250 and still no fire to coil
Check the coil. Swap it with another if possible to check. Sometimes coils fail short-circuit on the primary. If so, you will see no signal from the CDI when attached to the coil.
Apr 14, 2015 | Motorcycles
Miss fire after up to temp and runfor short amount of time. I get a miss fire coming to a stop..drops to cylinders or 1. will not accelerate at all boggs with miss fire.
Joe, i'm afraid we'll need some more info; year, make and model. Have you changed anything to after market like air cleaners or exhaust? How many miles are on it?
Jan 14, 2015 | Motorcycles
Why is my Motion Pro Go Kart 250cc not getting fire?
the crankshaft position sensor may be out remove and test
Jul 12, 2014 | Computers & Internet
2000 YZF R1 ONE DAY I SAW THAT BATTERY WAS SWOLLEN. REPLACED BATTERY WOULDNT START
Hi, Merle and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and CDI box.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose, check for spark leakage in the dark.
6. Faulty ignition coil, pick up coil, trigger coil or CDI box testing needs to be checked with an ohmmeter at 70 degrees Fahrenheit
7. Faulty safety switches clutch, kickstand, neutral, off/on etc.
8. Faulty ignition switch.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/102-00-01-r1-mechanical-help/287594-2000-r1-wont-start-no-spark.html
http://www.r6-forum.com/forums/57-garage-mechanical-help/38102-00-r6-turns-over-but-no-spark.html
2000 2001 Yamaha YZF R1 Service Manual R1 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Aug 21, 2012 | 2000 Yamaha YZF-R1
I have a vt250fd it fires on front cilinder a couple of times then stops does anyone have any ideas on how to fix it
check its sparking all the time first if its not chech the coile then the cdi unit, it may also be down to lack of fule getting to that pot?
Oct 17, 2010 | 1987 Honda VT 250 F
What causes cdi box to fail? the big red ran fine,but when trying to resart it the next day it will not fire. Also how do I know if it is truely the cdi box?
many things can cause a cdi box to fail they are hard to diagnose. but as far as testing goes u can use an multimeter to test ur resistence in the stator and coil if they test good its the cdi. or even a bad ground can cause it to loose fire.
Apr 13, 2010 | Honda XR 250 R Motorcycles
At idle and half throttle the front two cylinders dont fire
The year of the magna can make a difference on the answer. Early magna's had two cdi boxes. Later models had one.The front two cylinders use the same coil and possibly the same cdi box.I suspect a bad coil since since it operates both cylinders. Compare the readings between the two coils or switch them to see if the problem changes from front to back. This will work for duel cdi box models too. If these checks show no change in the front cylinders not firing, You probably need a new pulse pick up(the cdi equivalent of points.
Mar 20, 2010 | Honda VF 750 C Magna Motorcycles
I need help i have a 1990 yz 125 i have fire from the scatter plate to the cdi box i also have fire from cdi box what i need to know is how to hook it up to the kill switch and the coil
you run the positive lead from the cdi to the positive lead on the coil.... then somewhere between the negative lead on the coil and the frame/engine ground you splice in the kill switch.........what that does is breaks the ground when you push the kill switch which then kills the spark to the motor
Aug 19, 2009 | Yamaha YZ 125 Motorcycles
Honda fourtrax
Where is the cdi box located??
May 21, 2009 | 1998 Honda Accord
RTO Atv Ramp:truck,6-7,lawn Mower,trailer,motorcycle Logo
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
