My new 500GB WD SATA internal hard drive isn't recognised
I have just bought a 500GB WD SATA internal hard drive and have connected it to my MSI MS-6741 (K8TM-ILS) Motherboard but, although the drive spins up, my system does not see it. SATA on BIOS is enabled but it does not register as a new device. Do I need a driver? If so what sort and where from? Paul
  • phalliwell Nov 19, 2009
    Nope, no disc. Can I download from the WD site?
  • phalliwell Nov 23, 2009
    Thanks for your comment Phil but my drive didin't have a disc with it when I bought it from Dabs. Any thoughts on how to get hold of one now?
    Sergeant:
  • 295 Answers
Paul: Usually the drives come with a disk/cd from WD. Did you use this to format the drive?
Posted on Nov 19, 2009
  • Philip Frye
    Philip Frye Nov 19, 2009
    I believe you can! Burn it to a CD after you down load and keep it for future use.
    Blessings,
    A/V Media Guy
Hi, I want to know how to install the WD10EARS-00Y5B1 drivers? Okay, the problem is, that my computer doesn't recognise my SATA Hard Disk. I have Windows 7 Home Premium, and another SATA Hard Drive. I...
there are no drivers required for a hard drive.
Windows 7 should automatically detect the new hard drive and it should show up in disk management to format or prompt you to format.
Check your cable connections again.
Otherwise your new hard drive may be DOA. Return it to the store that you purchased from.
Mar 26, 2011 | Western Digital WD Caviar Green WD10EARS -...
Slow, and sometimes non responsive. I just cloned my old hard drive in my Macbook Pro to a new 500gb WD drive. What could be the issue? please advise
Please check that the power connection - to the outlet and to the device itself is as it should be. Mostly, when these things occur, it's related to a physical problem - either with the power source (cable/outlet) or a physical problem with the drive itself.
Feb 13, 2011 | Western Digital Caviar 500GB Internal SATA...
I have a 320 as my primary and i want 2 ad a 500 sata wd how do i set the pin jumper for secondary on my new one and the factory 320 has no jumper at all thanks
The SATA Drives do not need jumpers to set primary and secondary drive positions. Each sata drive gets it's own connection to the motherboard. Check you motherboard diagram, and make sure the 320GB drive is plugged into the 1st sata controler, and that the 500GB drive is connected to the 2nd.
Oct 11, 2009 | Western Digital Caviar 500GB Internal SATA...
Western Digital Reset / Set Hard Disk Size ?
hit F1 when you bootup dont let windows come on . Go in you Biso to set you new hard drive.dont forget to F10 to save changes...Good Luck
Aug 15, 2009 | Western Digital 500GB My Book World...
Hard disk Recognition problem
U are actually facing the same problem as "jackwilkinso". As my previous post: Windows XP does not come out to support SATA hard drive, because inside do not inclued the SATA driver, that why u cannot see the harddisk during the setup. What u can do is try to install the SATA supported OS like Windows Vista or Windows 7, or maybe can "forcely" put in the SATA driver in ur Windows XP setup CD.
YBC (/\)
Mar 29, 2009 | Western Digital Caviar 500GB Internal SATA...
Switching from 40GB IDE HDD to 500GB SATA HDD. SATA won't boot.
Hi there
No there is no need to change any jumpers on a sata drive, go into the bios settings and tell the bios to boot from the western digital drive only.
Good luck and thanks for using Fixya!!!!
Feb 09, 2009 | VIA MSI: MSI PT8 NEO-LSR P4 PT800 DDR400...
HDD Installation
Hi gravni,
The bios (MUST see the drive). If the bios does not see the drive neither will windows!
The down below port (as you mentioned) is for IDE devices. IDE1 by name. Use your ATA IDE port for the slower IDE drives or cd-rom drives. (This board does not have a second IDE port).
If the WD drive is a SATA drive connect it to the SATA 2 port. See your manual. Go to page 1-4.
As show in this pic below.
2711d19.jpg Is the WD 500Gb drive SATA or IDE?
It's suggested when adding a new drive into a working system, the user should setup the drive by using the manufactures guide. Click on this link & download WD's pdf file:
http://www.wdc.com/en/library/sata/2079-001042.pdf
You mentioned the drive is hot. This only means it is running.
Include in this post the model number of your WD drive? So I can check the specs.
Mike
Oct 28, 2008 | MSI P965 Platinum Motherboard
Formatting WD SATA 500GB AAKS in larger than 137GB
The best software that can fix this problem is "Power Quest Partition Magic".It works like a dream for drives of any capacity!
Oct 11, 2007 | Western Digital Caviar SE16 (WD5000AAKS)...
Trying to format a 500GB HDD at full capacity
check your bios if the disk is recognized as 500gb first. if it is not recognized, update your motherboard bios. most updates are available in their manufacturers site.
Computers & Internet Logo
358 people viewed this question
David Payne
David Payne
