Not getting enough humidity in our house in the winter resulting in cracks in moldings, etc. Level drops to 15-20% without use of portable electric humidifer. 2 Story great room, 3600 sq. ft. house...2 furnaces...2 general aire humidifiers (model 1099LH and 1042)...checked all lines and water flow into humidifiers (everything checks out)...was thinking of adding a second humidifier for the furnace that handles the main floor in-line w/ 1099LH...thoughts? Comments: Nov 18, 2009 - Could it work out if I took the drain line from the first humidifier from above and ran it into the top of the second humidifier in order to simplify installation..also water will be a little warmer to aid in evaporation into the air? Also now that I think about it, isn't it more efficient to add the humidity after the are is warmed? not on the cold air return? Thanks, John
  • jaustindds Nov 20, 2009
    House is pretty tight...double pane windows, etc...also pads are new...line is clear...flows when furnace runs....i've checked all the obvious...
  • 43,501 Answers
Getting enough humidity in a house can be difficult in some climates. Some types of furnaces can make the problem worse also.
Before I would look into install more of what you have, I would consider installing a steam type humidifier. These units not only warm the water but actually produce steam directly in the air stream. When a unit says it will make 9 gal a day, with these it actually can do that! And YES!!! I would install this unit in the supply duct instead of the return. I would not want to be pulling this steam through my furnace.
These units are a bit more difficult to install and they require periodic leanings to remove the **** left behind by the water, but they will give you the humidity that you desire.
I have installed a number of steam units and can tell you that they do work well.
Feel free to comment back if you have any questions.
You can see a product like I am recommending here
http://www.amazon.com/dp/B001FD8A94
There are other similar products available, I have used a couple of different ones and I cannot say that one is bettter than any other. The best product is going to be the one that you can get for a good price and get part for if you need them. Check with a local HVAC Supply House to see what brand product they carry and can give you good service on as far as warranty and parts go.
I hope that this information will give you what you need to solve your problem.
Thanks For Using Fixya!!
Heatman101
Posted on Nov 21, 2009
    Scholar:
  • 105 Answers
John,
Two furnaces with a 1099LH and a 1042 humidifier should easily keep your home warm and with the correct humidity level.
Things to look for would be the evaporator pads on your humidifiers. Make sure that they are new. Clogged or old evaporator pads will not transfer water to vapor at the proper rate.
Another factor is how "tight" your home is. You must make sure your home is free of drafts or other factors where air is leaking in and out of you home. This is one of the biggest causes in the loss of heating, cooling and humidity. PLEASE CLICK HERE This will take you to the Energy star website which talks about a tight home.
My conclusion:
I don't believe you need another humidifier added to what you already have. Make sure everything is working properly and make sure your home is tight.
John, I hope this helped you out and good luck!
PS- You are correct, warm water will evaporate faster than cold water!
Posted on Nov 19, 2009
Condensation dripping from ceiling in all electric home with no basement
The wall of the daughter's bedroom is NOT insulated. Moisture from normal activities (showering and cooking) within the house are causing the realtive humidity to be above 50%. When that moisture enters the wall or ceiling, the temperature drops below the dewpoint and condenses out. The moisture that condenses makes a nice environment for the growth of black mold which is highly toxic. The mold will spread by airborne spores. If you have return air ducts for your HVAC system in the room, the spores might be dispersed throughout the entire house, depending on how good you HVAC filter is. Note that if you have a swamp cooler on the roof, it could be leaking water through the ceiling and causing the problem.
You need to immediately move you daughter to another room and remediate the situation -- tear out all the drywall and anything that is damp or has signs of visible mold. Get the humidity in ther house below 50% with a dehumidifier. I would recommend the Winix 50-pint model (refer to link below). This will condition 1500 square feet, which is a lot, but you will need one on each floor.
Amazon com Home Kitchen
Jan 29, 2014 | Kirby Shampooer Shampoo Hose G3 Ultimate...
Tip
Taking the Confusion Out of Using a Dehumidier
Many consumers are confused about setting the proper levels of humidity on dehumidifier units. And then think something is mechanically wrong with the unit. When in fact, over 70% of the time it operator error. That and a lack of proper routine maintenance are the problem.
The numbers on the LED screen represent the amount of humidity you want to maintain. Not the amount you want to remove. For example: If you set the level at 70%, which is rather high, more than likely the unit may start up momentarily and then shut OFF. That's because the setting is to high. Now, if you set it at 45%, the unit will turn ON and run until either the bucket is full and/or the humidity level has reached 45%.
Here's a good rule of thumb if you use your humidifier year round.
In the Winter you want to maintain a humidity level of 50 to 60%. The moister the air, the more comfortable it will feel. Plus, the humidity helps eliminate static electricity in the air.
Conversely, in the hot, humid Summer months, you want to keep the humidity level as low as possible (35% or less). Also, if you have ceiling fans, using them 24 hours a day, helps to move the air and generate a windchill, which fools your body into thinking it's cooler than what it really is. At the same time, it's saving on energy costs by not having to run your AC as much, because the dehumidifier is removing the humidity.
Just remember, the higher the setting, the higher the humidity level will stay. The lower the setting, the more humidity will be removed and the more comfortable you'll feel in the Summer.
And don't forget Routine Maintenance. Clean the air intake filter regularly. Clean and wipe down the refrigerant coils every 60 days. And don't allow water to remain in the collection bucket to long. As mold can build up in it.
Speaking of which, the water in the bucket, when fresh, is great for watering house plants. Because, when it's fresh, it's distilled water. No chlorine or minerals.
on May 04, 2011 | Maytag M7DH45B2A Dehumidifier
What is the reason for the gap between the boards on my floor?
The reason is because that in the summer days the humidity level is high and your hardwood soaks up the humidity and expands and in the winter time, once the heat is turned on the humidity level drops, the floor dries and the gap starts.
Feb 06, 2013 | Building Materials
Plug it in turn it on and nothing in the bucket after several hours
Hi, Mindy! The following is an overall review of what causes the problem you listed.
If the room air is less than the set air, then there is no water in the bucket, because there is almost no humidity in the air. If it is winter, there is likely not enough humidity in the air to have water collect in the bucket. A dehumidifier will only pick up humidity out of warm air. If you are running a dehumidifier in your basement in the winter, the room may be damp, but too cold for the dehumidifier to pull out the humidity. Try running the unit in the bathroom after having a hot shower without the bathroom fan on. If working correctly the unit should draw water. In addition, if you set the humidity level you want to maintain higher the actual humidity level in the house or room, it won't pickup and collect any moisture. The fans on most of the dehumidifiers on the market today run almost constantly. They do this, so that the room air is always moving and if humidity is detected, it will extract it.
Hope this helps you understand how dehumidifiers function and what you can expect from them under given circumstances,. In fact, there may not be anything mechanically wrong with yours. But, to make sure, do what is suggested above to test the unit.
Apr 29, 2011 | Haier Dehumidifiers
How to get off mold of the wook of my bass guitar (Ibanez sr3006)?
First clean the wood with methyl hydrate (alcool) to kill off any remaning mold, then treat the wood with some kind of mold resistant oil (murphy's lemond) or ask a local music store for a recomanded product than keep the instrument out of humide places of the house (celler, garage, etc...)
good luck!
Dec 31, 2010 | Ibanez Sr3006 6String Bass
Have a large new house with lots of vinyl clad wood double hung windows on a lake temp today this am is 0 F we have a HRV system house temp is 66 downstairs and 58 upstairs heating with a heat pump and...
Really not efficent to run a heat pump at those temperatures. Below freezing is not good for the compressor in the outside unit. The humidity in the house with the low temp. is causing the condensation on the windows to freeze. Kinda like an air conditoner does in the summer without the freezing humid air from the house goes over the cold a/c coil and the moisture condensates on the coil running down to drain pan. raising the temp. in the house and lowering the humidity should help. I would also recommend running the electric heat in low outside teperatures.
Dec 17, 2009 | Aprilaire 600 Humidifier
Are there any recalls on a Rheem Criterion II Model No. RGPH-05EAUER in WI? I have a house that was built in '98. The furnace doesn't dry out the air enough and tons of moisture has built up in the house...
there have been several situations wht rheems as far as control boards cracked heat exchangers cracked inducer assemblys and touchy pressure switches i would call to get a furnace inspection from a rheem dealer
sounds like you really need to buy a portable dehumidifier
Jul 06, 2009 | Heating & Cooling
Won't humidify past 30% in a 90sf bedroom
The most probable reason that the humidifier does not reach the levels you describe is because you said you had the unit in your bedroom.
Bedrooms typically contain materials that are known as "hygroscopic." What that means in plain English is that items such as the bedding, mattress, any carpeting, wood, curtains, you, etc. all absorb moisture , kinda like a sponge. Since that moisture is being held by these materials, the air itself contains less by percentage. 25-30% humidity is actually pretty good for any room, especially in colder climates and higher humidity levels can lead to the production of mold, condensation on windows, etc., which are not good things. The good news is that reasonable humidity levels are healthier for textiles such as carpeting, cloth, and so on because the fibers won't dry out and crack. Dust is also reduced, but again, only to a certain level.
If your humidifier is reaching 30% it's probably working ok.
Mar 27, 2009 | Hunter 33201 Humidifier
Aprilaire 600 humidity level too low
you may try running your blower 100% of the time.this should allow the humidifier to stay on even when your not heating. once the humidity level gets to where you want it, you may be able to put the fan selector back to auto. also you mentioned you have a variable blower. this is great if it is set up to run at approx. 20% fan speed when it is not heating or cooling. at 20% you can circulate enough air through the house to humidify without being able to hear the noise of the blower. it will really increase the comfort level of the house if you tend to have hot and cool spots. if it was not set up this way, contact the installer and ask if they can do this for you.
Jan 26, 2009 | Humidifiers
Works too well, can't stop windows from sweating!
I don't know much about humidifiers other than they are rarely needed and most folk around here would rather there was a lot less humidity., especially considering how easily black mould grows and how injurious to health that can be.
Those few people living with an unsuitable heating system in a badly designed house usually find it is adequate to have a water feature in the lounge or to balance a bowl of water on a radiator.
Certainly when the windows sweat to such a degree, especially if you have double glazing, the humidity must be well above the comfort range, above 70%, and probably well into the moist range of 80% - 90%. Higher than that and any exertion becomes decidedly unconfortable...
I am guessing the humidistat is either faulty or cannot work because the humidity is already too high. I suggest you need to check the humidity in your home with an accurate independent humidity meter before you go further...
Mar 24, 2017 | Honeywell HE220A1019 Whole House...
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
