Question about Refrigerators
Noise humming in fridge only in when doors are closed
    President:
  • 2,702 Answers
Its just likley to be a shelf or the rad on the back thats humming, if its a shelf its likley to be just tuching the inside of the door if its the rad on the back stuff a rolled up news paper under it jamed between the rad and the rear of the fridge that shuts them up realy good too!
Posted on Nov 19, 2009
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
Loud humming noise stops when re fridg door open than continues when close-side by side refrigerator
Humming noise is normally the compressor running,,,usually nothing too worry about
Jun 13, 2013 | Refrigerators
Our Samsung fridge srs757dw is making weird noises(it hums loudly). When the Freezer door is open it stops but as soon as it closes the noise begins again. What do you think is the problem?
Sometimes this can be due to vibrations within the duct , possible that the ventillating fan is frosted and so makes the noise with the door closed. So shut down fridge for few hours to defrost and check.Also make sure there are no loose screws or clips on the back panel and the evporator section that can cause vibration.
Aug 30, 2011 | Samsung Televison & Video
Hi, My fridge ( 420 ltrs) Top Freezer making constant humming noise ( like a dieasl car engine)like the engine keeps running and try to cool the fridge. 1 year old. When I open the freezer or the...
The noise is the fan hitting ice build up on the coils... it is no defrosting properly...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 14, 2010 | Samsung Refrigerators
My whirlpool fridge makes a loud humming noise when the door is closed. It is not freezing items in the freexer and is not cooling items in the fridge section. The freezer is above the fridge section in...
The fan is hitting ice build up...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Oct 11, 2010 | Whirlpool Refrigerators
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Fridge makes a fairly loud humming noise when I close the door
it sounds like your refridgerator might be unlevel try adjusting the legs all the way down to start then level to floor if that doesnt fix it its probably the rubber gromet under the compressor usually there is four of them if one comes out(usually after moving it makes your compressor vibrate you can use almost any gromet of of any junk refrigerator or if you want you can by original replacement parts at one of your local appliance dealer
Dec 18, 2008 | Dishwashers
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
418 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
