When i plug my external hdd in it says its successfully connected. but when i go to my computer it isnt apperaing. however, it show that its connected in "Disk Management" ...
  • 702 Answers
Does it also show that it is partitioned and formatted in Disk Management?
One option is that there is a driver letter conflict. Could be a network drive or a USB stick. Try disconnection all other USB stuff and network driver and plug the disk again.
If that does not help, you might find more info here: http://www.devicedriverfinder.com/blog/external-hard-drive-troubleshooting
Posted on Nov 19, 2009
000 wd5000c035
If it's the power adapter then a simple search of the internet should show you where to go to find one. The other problem is that the HDD may be bad. You'd have to open the case, remove the HDD then connect it to your computer. I'm sure this would void the warrenty. However if it is the HDD then you saved yourselp the cost of a power supply.
Aug 27, 2013 | Western Digital Elements powered by WD 320...
External hard disk not recognizing by computer
to connect through USB
  • Just connect your HDD data cable into the USB port of the Computer
  • Then Right Click on My Computer select Manage then Go to the Device Manager and Click on Update Hardware Option
  • After updated you see a Icon as yellow Question Marks with The name of your HDD.
  • Just Right Click on it and select Update Driver
  • Do as per the given Direction.
After successfully install your driver you just restart your computer. Your HDD now installed with your PC
May 16, 2011 | Omega Computers & Internet
My WD My Book Essential 1TB External is not showing up on 'My Computer'. It was working perfectly in the morning, then when I rebooted my machine it no longer showed up.
disconnect your WD ext HDD. and reboot your computer. then connect again. if still not showing. go to device manager (right click my computer then properties -- click device manager). expand by clickin "Disk drives" category here it will show all the hard drives installed in your computer including your WD ext HDD . if you see yellow sign on your external drive right click and remove then go to Action menu click on Scan for hardware. it should detect and install the driver again. if still the same or maybe its not on the list of Disk drives.. try to change another USB cable .. i hope this will help
Jan 03, 2011 | Western Digital My Book Essential 1TB...
I have the imicro 3.5"
the hdd enclose may be bad/faulty
try connecting the hard drive inside your computer doing away with the hdd enclosure
the light only means its getting power not a connection to hdd
hope this helps
Dec 15, 2010 | Western Digital imicro IM35ST320SI 3.5 IDE...
Simpletech 120gb extern HD does not respond when plugged in and freezes computer hooked up to
try to plug in to other computer it still freeze there might problem with your external hdd. remove cover on your external hdd remove board ckt controller look for possible burn IC. remove hdd and try connect directly to your desktop if it work, assemble again and observe if still freeze you need to replace board controller.
Apr 10, 2010 | Computers & Internet
Have just purchased a USB 2.0 to SATA HDD Adaptor made by Nikkai from Maplin. Have connected everything okay with my old HDD but when I go to run the 'Driver & User Manual' disc it just tells me it a...
Most of these adapters don't need windows drivers EXCEPT for use on a '98 system.
Got to the disk management console & see if your USB drive is there. It may simply need to have a drive letter assigned for you to see it in My Computer.
The path to the disk management console is usually: %SystemRoot%\system32\compmgmt.msc /s
Paste that into Start/Run.
Aug 12, 2009 | Televison & Video
USB HDD not showing in My Computer
It could be that the USB port on that computer is not delivering enough power.  Will your Drive accept external power?
May 12, 2009 | Computers & Internet
WD1000VE external hard drive not recognized
If possible check it out on another computer.
This will then establish one or the other which is misbehaving.
Then come back
Feb 11, 2008 | Western Digital (WD1000VE) 100 GB Hard...
I/O DEVICE ERROR
I/0 error, IS AN INPUT/OUTPUT ERROR. this device is formatted as FAT32 as it is usable on all OS. however if you formatt it to the faster, safer NTFS format, it will only work on 2000, XP etc. so firstly is the device being "seen" by windows? as in does the plug and play connect device sound play? or the green arrow and card icon appera in the bottom left corner? if it doesnt your computer may not have a mass storage device installed, or a driver for it, go into your device managment and click rescan plug and play and if nothing comes up click, view hidden devices, and select the correct driver, by either manually selecting the mass storage or Hdd driver or letting windows find one on the net or locally. if this still doesnt fix things, be aware that external HDD us ealot of power, and some USB ports dont give enough power for the HDD to wind up enough speed to operate. try using a different port, 2.0 not 1.0 as i have found power draw issues with 1.0 USB and/or get a shorter, foot long or less cable. good luck.
Sep 24, 2007 | Computers & Internet
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
