Question about GE WBB4500EWW Top Load Washer
Machine is making humming sound drum not turning
    Guru:
  • 1,738 Answers
Bad motor, sorry about that.
Posted on Nov 19, 2009
Wm2016cw
LE errors mean the motor is locking up and cannot turn the drum. If the drum turns freely by hand then it could be https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/406-200-684484-/LG-LE-MOTOR-ERROR-Motor-Stator-overheat-or-connection-error-WM2016CW
If that is not the problem then the motor needs replaced.
Apr 15, 2017 | Washing Machines
Dryer motor just hums, drum doesn't turn
check belt drum drive? check drum turns at all, it may be stuck.most drums turn with a belt. if it broke it is laying on the bottom of the dryer.didnt u see it??look again.
Apr 21, 2013 | Kenmore 98702 Stacked Washer/Dryer
Hotpoint TDC62p is making a buzzing/humming sound and the drum will not spin though it does move if you push it.
Either something is binding the blower wheel up or the motor is bad. The best thing is to take the front of the machine off to access the blower wheel to verify ifanything is indeed binding it.IF not read the next section.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
May 17, 2012 | Hotpoint Tumble Dryer Tdc60n Tdc60p Tdc60s...
Start of the cycle the drum will start to turn but just hums. trys to turn the other way and does the same. it will eventully stop and throw a LE code = over load and motor. All this with or with out...
sounds like if it hums something has the drum fouled if nothing catching the drum then i would say the motor is at fault sounds like the motor is trying to start off the running winding instead of the start winding or a starting capacitor on the motor is bad
Jan 24, 2011 | LG WM-1832C Front Load Washer
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing....
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Dec 27, 2009 | Dryers
Humming sound
If you open the door can you turn the inner drum by hand , if you can is any there any resistance or does it just spin freely
It sounds as if your drive belt has snapped and what you hear is the motor running on its own
If the drum spins freely you will need to take the back off the machine and see what state the drive belt is in
Ps
Is there heat inside the drum when you try to make it work without a load.
Jun 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Just makes a hum nosie and won't spin or anything else
Sounds like the belts are off the bottom of the machine..
You may want to pull the front cover and look underneath.
May 30, 2009 | Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
GE WBB4500EWW Top Load Washer Logo
65 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
