Question about Honda Garden
WE HAVE A HONDA ic2 EXCELL 2500PSI VR2522 2.2 GPM 5.5HP GCV160.THE PROBLEM IS OIL COMING OUT OF UNDER THE ENGINE I DON'T KNOW WHERE.
    Problem Solver:
  • 12 Answers
Check oil filter/sump gasket or sump oil drain plug copper washer
Posted on Nov 19, 2009
Oil leak under machine, how do you tell if pump needs more oil
Oil is leaking from the engine. Pump does not have oil in it.
Sep 01, 2016 | Campbell Hausfeld 2500 Psi, 2.4 Gpm,...
Grey oil leak and no water pessure
depends on where the oil leaks from , normally a cloudy or "grey" oil sheen ,oozing out from here and there doesnt consern me too much , but now the oil running from the big hole or crack in the housing now that conserns me , make sure unit is "primed" with water (small flow from tip with motor off but hose turned on) if still no good then cycle your unloader a few times by tunring the pressure adjustment all the way up and all the way down with water on and motor runninng , this should work unless you have a larger problem
Feb 20, 2015 | Karcher G 2600 VH 2600 PSI 2.3 GPM 161cc...
Where to install thermal relief valve
It should be the last threaded hole right before the water enters the pump itself, on the low pressure ( inlet) side, most pumps have 2 different size holes 90 degrees from each other, commonly 1/4 and 1/8 in.
Dec 13, 2012 | Honda Karcher G2400HH-R Pressure Washer
Need a Honda GCV160 mower owner op-manual
You will need to know your serial number. They are free to download, but if you want to order a paper copy, you have to pay for it. Hope this helps and please don't forget to rate!
http://engines.honda.com/parts-and-support/owners-manuals/GCV160
Jun 24, 2012 | Garden
I have a ic2 pump on my pressure washer, the diagrams have failed. My question is I need the parts to repair it, or how to purchase a replacement.
You can purchase a complete unit from Grainger for about $210.00. Their part number is 6UZP8. And in most cases they are located locally, so you can pick it up and be back in business quick. The pump is actually manufactured by Excell Power, so my thought would be replace the pump and then try to find a rebuild kit for the bad pump and try to rebuild it as a backup. Hope this helps.
http://www.grainger.com/Grainger/EXCELL-Assembly-Pump-6UZP8
Jun 13, 2011 | Honda Garden
No water pressure on my honda 2600 excell ic2 model xr2625
you need to check the valves,
there is a possibility that the springs are rusty.
Nov 15, 2009 | Garden
I just bought a 2nd hand honda excell psi max vr 2522 2.2 gpm max 5.5 hp gvc160. i put gas and oil and it wouldn't start?
Have a helper hold the trigger of the wand open while you try it again. If it starts that way you have a sticky unloader valve in the pump. DO NOT RELEASE the trigger for more than 10 seconds if the engine continues to strain when released! If the engine doesnt run freely when you let go of the trigger, pull it again and shut down the unit!
Add some power steering fluid to your supply hose (about 3 or 4 ounces at a time) and restart the unit with the trigger pulled. Allow the oil to flow through the pump for 1 - 2 minutes for each treatment. Several treatments should make the pump and valve happy again.
Hope this helps.
Sep 25, 2009 | Karcher 2500 PSI Pressure Washer
Honda GCV160 Engine Won't Start
Hello
You should siphon out all the old gas you can. Replace with new gas. Check that the spark plug is good and the air filter is clean. Spray some carb cleaner in the carburetor.. Also, you should check the oil level and change the oil if it is black. If it tries to start after you spray the carb cleaner in but won't keep going then you know the carburetor needs a good cleaning
Aug 08, 2009 | Karcher 2500 PSI Pressure Washer
No pump pressure
Sounds like the diaphragm in the pump unit has failed, the engine and the pump are two seperate things the engine only operates the pump but if the diaphragm is leaking or broken you wont get any pressure
May 22, 2009 | Karcher 2500 PSI Pressure Washer
How to repair a hole in the wand tubing for pressure washer
my Honda ic2 ran greet, then all of a sudden it started to slowly shutting down,
i restarted it. and it ran for about 5 min and shut down. i did this 3thee to four times do i need a gas additive or what
Apr 27, 2009 | Garden
Garden Logo
1,690 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
