Question about Mitsubishi VS-55707 TV
Power clicks on, then immediately off. TV is Mitsubishi VS 55707.
  • 834 Answers
Convergance amps ic's shorted you will need to replace them or have it done along with the 2 resistor that will have burnt not a bad job about 150 to 200 dollar job
Posted on Nov 19, 2009
Testimonial: "thanks.. i will try that next"
Can i buy a new tv screen for mitsubishi vs-55707 tv
Yes, You can buy another screen for Your mitsubishi television, You can get it from any part dealer store, also, You can get it from someone whose television is having a different problem than a faulty screen. There are some television that develop other kinds of fault, therefore, they are moved to stores where they can be disassembled and sold in parts.
Hope this information helped. Thank You for using FixYa!!!
Jan 15, 2011 | Mitsubishi VS-55707 TV
I have the Mitsubishi Big Screen TV Model number VS-55707. When I turn on the power the light flashes 3 times and will not turn on. It was working great then just stopped. I assume that 3 blinks on the...
Your power supply board is not yet dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Dec 20, 2010 | Mitsubishi VS-55707 TV
Mitsubishi VS-55707 TV powers on for about 1 second then powers off. I have replaced the convergence IC's, but still get the error code 22. Are there any resistors that I should be double checking?
THERE ARE 2 CURRENT LIMITERS 1 OHM OR SOLIDER IN FUSES FOR + & - SUPPLY THEY FEED THE CONVERGENCE IC'S YOU NEED TO VERIFY YOU HAVE YOUR POWER SOURCE TO THESE. ALSO A LOSS OF VERTICAL DEFLECTION WILL CAUSE THIS.
Dec 22, 2009 | Mitsubishi VS-55707 TV
It just won't keep running after running fine a while.
PROBLY NOT TRIP CHARGES ARE AT LEAST 45.00 AND THEN 65.00 PER HOUR PLUS PATS WHICH ARE EXORBENT
May 20, 2009 | Mitsubishi VS-55707 TV
TV turns off on its own
Set may have poor/cold solder connections on power supply board and convergence board.
Dec 17, 2008 | Mitsubishi VS-55707 TV
Jumping screen on a mitsubishi vs-55707
check the high voltage leads on the multiplier flyback transformer for leakage
Nov 17, 2008 | Mitsubishi VS-55707 TV
Power
the tv probably has a loose solder joint or broken or cracked circuit board due to moving
Aug 13, 2008 | Mitsubishi VS-55707 TV
Mitsubishi VS-55707 Shuts Down
I would not recommend working on a TV unless you have a great deal of knowledge about them.
it is probably your power relays do you have a part # i could help you look around
Jan 26, 2008 | Mitsubishi VS-55707 TV
Mitsubishi VS-55707 TV Logo
434 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
