Question about Canon EOS Rebel G 35mm SLR Camera
The films rewinds as soon as I close the lid. It
The films rewinds as soon as I close the lid. It does not move forward.
Turn the camera to M, set the fastest shutter speed and smallest aperture, turn autofocus off, and put lens cap on. Open the camera and take 1 shot. Put the film back on Close the camera Done.... (the other guy is an idiot)
Posted on May 10, 2011
  • 571 Answers
One reason may be that the film is not pushed far enough to the receiving spool and the camera thinks it's empty thus rewinding the film.
If this is not the case it needs to be repaired.
Posted on Jan 11, 2010
Film rewinds when loaded
Align film leader at mark, then close the camera back for prewind loading. Film rewinds as each shot is exposed. Built-in motor for automatic winding/rewinding. Film advance: Automatic. Single-frame and continuous (1 fps). Automatically rewinds film leader into cartridge when designated number of frames have been exposed (midroll rewind available).
sorce: http://www.canon.com/camera-museum/camera/film/data/1996-2000/1999_eos3000.html?p=2
Canon Camera Museum Camera Hall Film Cameras
good luck
Dec 20, 2014 | Canon EOS-AE-1 35mm SLR Camera
The film ripped from the cassette on a contax rts when i was manually rewinding it. is there any way to salvage this at home? also, what is the best way to remove the film from the camera, without damaging...
before opening the camera, press the film rewind release button and ensure that the portion of film which remains attached to the cassette has been totally rewound. Next, with the camera in total darkness, open the camera back and remove the film cassette. Grab a firm hold of the loose end of the torn film and tape it to a piece of wooden dowelling and then turn the dowelling so that the film pulls out and winds onto it. Once the film has disengaged from the camera, place the dowelling with the film into a totally light-proof container: an old but spotlessly clean metal tin, such as a custard powder, cornflour or even a paint tin will do the job. Don't use a plastic lidded tin as the lid is always slightly translucent and will fog the film. When the tin lid has been firmly closed with the film inside, you can take the tin to a specialist processor and get both film portions developed.
Note that specialist handling of this type regarding development is not cheap. You cannot use a regular postal processor or minilab as their machinery cannot handle damaged film, only a professional lab (or a well-equipped friend) can individually process your film. Bear the cost in mind, as it's only worth doing if you are sure that there are valuable/irreplaceable images on the film.
Also note that by pressing the rewind button before pulling out the film, you are largely using the camera as intended so will not damage it. Afterwards, check the camera thoroughly and clean out any broken film fragments.Torn film is sometimes down to a manufacturing defect in the film, or due to the rewind button popping out during rewinding, or rewinding much too fast or due to excessive resistance in the take-up mechanism as the film is rewound; the latter usually indicates that the camera is overdue for a professional CLA (Clean, Lubricate, Adjust) service. The fault may commonly be due to a combination of those factors.
Sep 13, 2011 | Contax RTS II 35mm SLR Camera
How do i rewind the film in my nikon n2020
Set the film advance mode selector to L.
While sliding film rewind lever, push film rewind button.
Fold out film rewind crank and rotate until film advance indicator stops moving.
If you don't have a manual, you can download one from http://www.butkus.org/chinon/nikon.htm
Feb 13, 2010 | Nikon N2020 35mm SLR Camera
Film rewind crank stuck in up position nikon n2000
Move it a bit (some half circle)back and forth. The slot may be in wrong position related to the roll inside. It should click in when you get the slot in right angle.
Aug 02, 2009 | Nikon EM 35mm SLR Camera
My pentax zx-m rewinds new film as soon as i shut the door
When loading film, make sure to draw the film all the way to the receiving spool. If you don't pull the film far enough the camera thinks it's empty and rewinds the film.
Jul 08, 2009 | Pentax Photography
The light on the lid, for scanning negatives won't move
You will most likely find that the FAU cable that connects the lift up lid part to the lower part of the scanner has at least one fractured wire within it. There are eight quite fine wires and the constant opening and closing of the lid has caused this to occur. Unless you have some micro-surgery skills and a small soldering iron it's off to the scanner shop, I'm afraid.
Mar 17, 2009 | Canon CanoScan 8400F Film Scanner
I cant seem to load film in my camera . it winds it back up as soon as i close it or try to take pictures
It's still in auto-rewind mode. Depending on the model, do a manual rewind with no film in the camera to reset the internal counter. Then load film and try it. Please leave feedback if this helps.
Jul 26, 2008 | Cameras
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
Film loading
Rewinding button or option may be in action
Oct 27, 2007 | Canon EOS Rebel G 35mm SLR Camera
Nikon F60 Film rewind uncoded film help
Most manual cameras have a button to release the film on the bottom of the camera, push the button in and turn the rewind crank (left side of the top of the camera) until you feel the crank suddenly turning much easier.
Oct 04, 2007 | Nikon F60 35mm SLR Camera
Canon EOS Rebel G 35mm SLR Camera Logo
98 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
