Question about Buffalo Technology AirStation G54 WHR-HP-G54 Wireless Router (DHWHRHPG54)
I have lost my Network Ket to my AirStation 54G. Is the only way to change it to Reset the ROuter ?
  • 2,263 Answers
To get the network key of your wireless network, you will need to access the rotuerset up.
Is there any computer conencted to the router with the cable ?
If not then is there any computer online through the same router wirelessly ?
You can open the set up page on the working computer.
If you do not have any other computer online then you will need to connect the computer to the router with the cable.
Click Here for more info about how to find the network key
Posted on Nov 20, 2009
Model name wbmr-hp-g300h, i have lost the password so it cannot be log in
Did you loose WiFi access password or router password?
If it's WiFi password then you can connect over Ethernet cable, login to the router (default password is blank) and change WiFi password.
If it's router password you will need to reset it to factory defaults and setup everything from scratch.
Here is the manual with the details.
Wireless Configuration, p. 40
Factory Reset, p. 67
http://cdn.cloudfiles.mosso.com/c85091/WZR-G300N-Manual-v1.1-web.pdf
Aug 20, 2013 | Buffalo Technology AirStation Nfiniti...
I need to reset the password on my linksys Wireless GBroadband router WRT 54G without ruining my wireless set up in my house!
Use an Ethernet cable to connect your computer directly to the router.
Access the web-server "inside" the router.
Login to the router, with the current ID/password.
View the wireless settings:
* SSID
* encryption-level ('WPA' or better, please)
* network password
and change it, if you need to.
Feb 21, 2011 | Linksys Wireless-G Broadband Router
Belkin router my password has been changed
Are you speaking about the password of the router or the password of the wireless network ?
If you don't know the password of the router , then you will need to reset the router and use the default password of the router.
Once you reset the router, you will need to reconfigure it.
If you are looking for the wireless password, you can find it on the set up page of the router.
You will need to open the set up page of the router.
Click here for step by step instructions
Oct 20, 2010 | Belkin (54G F5D7230UK4) Wireless Router
How to put a password to the 54g router
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Feb 21, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Forgot the network key. Either I want to get the network key or I want to reset the network key to something else
If you can access the router setup page, you can still get the network key that you need and if you can also access the router setup page you can also do change the network key that you have on it...
Dec 29, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I have a buffalo airstation WHRG 125 and I have recently purchased a HP dv4 with a broadcom wireless adapter that accepts wireless g/b connections. I have a wireless g network operating and my other HP...
The OS on the computer is vista.
I think you will need to change the advanced wireless settings on the wireless router.
you can try changing the following settings on the wireless router.
Beakon Interval = 75
RTS threshold = 2307
Fragmentation threshold - 2306
Reduce the MTU 1400.
change the wireless channel.
You can also add the network manually on the vista computer.
open network and sharing center ==> manage network connections
If you see your network listed then highlight the network and click remove at the top.
Now click ADD option at the top.
Then select the option add network manually.
enter the wireless network name and security settings of the wireless network and then try to connect.
to change the wireless settings you will need to open the set up interface of the router.
Oct 13, 2009 | Buffalo Technology AirStation...
Computer sees belkin 54g, shows all bars, when
Make sure that your router is set for an "encryption system" that is similar to all your computers and mobile devices. Example, if your router is set to encrypt using WAP2, make sure all your devices connect and is capable to connect using WAP2. Or else, set it to WAP and set your devices to WAP also.
Regards!
Jul 10, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
How do I rename it so I can further protect my network
  1. Log-in to your router (default: 192.168.2.1)
  2. Go to LAN Settings
  3. Change Local Domain Name to a name of your liking.
  4. Click Apply Changes.
  5. Done.
If you have any more questions or this is not clear to you, just come back here and leave a comment - I'm happy to help.
May 22, 2009 | Belkin (54G F5D7230UK4) Wireless Router
I secured my wireless network but have forgotten the password
hey what you can do is you can reset the entire router... by using the reset button on your belkin router... Or else you can also access the router by using the following IP address in the internet exlorer...
try 192.168.1.1 or 192.168.1.0 & then go to the wep settings & reset the router or change the password for the router...
Jan 17, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Buffalo Technology AirStation G54 WHR-HP-G54 Wireless Router (DHWHRHPG54) Logo
178 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
