Question about XO Vision Audio Players & Recorders
I can't pick up radio stations anymore. (and the battery if fully charged)
  • 27 Answers
Antenna inside is broke. send it in.
Posted on Nov 19, 2009
Transister rsdio won't turn on or off
Very likely bad batteries in the handhelds. Make certain they have been charged fully and try again. If not, get new batteries. Batteries go bad even not used, sitting in a box or on a shelf. 1999 are likely nicad chemistry and without a professional battery conditioner, I doubt they will take a charge. You could try to charge and dis charge them your self 10-12 times. Sometimes this will work. Fully charge the battery, put in the radio and turn it on until the radio beeps. Do not let it go dead overnight or you make the problem worse.
Sep 30, 2014 | Radio Shack 1999 Radioshack 6 Transistor...
The AM side of the radio receives a few local stations...the FM side works fine...are there two separate antenna...thanks
The antenna for your am receiver is located inside the radio itself and is only a couple of inches in length and about 3/8 of an inch in diameter.
May 08, 2010 | 2000 Buick Park Avenue
My m175c picks up an am radio station
ive had subwoofers do the same thing. i cant explain it. its in the air
Feb 11, 2010 | Radio Communications
I have a T2+ remote sys and need a manual. as a start I need to know how to charge.
The remote comes with a charging dock, if you did not get this you can order one from RTI (952) 253-3136.
BATTERY AND DOCKING STATION
The T2+ uses a Lithium-Ion rechargeable battery. This battery does not exhibit any type of "Memory Effect" from being charged too often. Since the T2+ can safely be charged after each use, a docking station is included for convenience. If left out of the docking station, the T2+ will remain in sleep mode for 1 or 2 months before shutting down. At that point the battery must be recharged. The T2+ Docking Station can be placed on a flat surface such as a shelf or table, or it can be mounted to a wall using the mounting holes on the back of the unit. If the T2+ battery capacity is reduced to approximately one hour of remaining run-time, a low battery icon will appear in the upper left corner of the display The docking station LED illuminates to indicate a charge in progress. The LED will turn off when the battery in the unit is fully charged.A fully discharged battery will take approximately 2-4 hours to completely re-charge.The T2+ can remain in the docking station indefinitely without damage to the battery.
Jan 17, 2010 | Rti Technologies Rti T1 Remote Control
Dangers of a Motorola being left on when charging in a multilpe
Don't know if you'd call it dangerous, but wisedom would be not to leave a radio turned on while on the charger. 1) Shortened battery life due to short charging. The battery will never be fully charged due to powering the radio. 2) Inadvertently pressing the PTT button while the radio on the charger can/will burn out components in the radio including the PA (final amp) which is a costly repair.
Instead of leaving the radio turned on while on the charger, buy a second battery to keep on the charger. Then you only need to swap batteries. Your radio would be able to remain on, and never be on the charger.
Jun 28, 2009 | Motorola Radio Communications
It won't charge the rechargeable batteries anymore
I have the same problem , the only logical reason i could think of is that the charger connecting to the base station has malfunctioned .
Aug 30, 2008 | Philips VOIP8411B/37 IP Phone
82 people viewed this question
Top XO Vision Audio Players & Recorders Experts
Gyula Lacz
Belzonsci Belzonsci
Belzonsci Belzonsci
Level 1 Expert
Are you a XO Vision Audio Player and Recorder Expert? Answer questions, earn points and help others
