Question about Bosch Classixx WFL 2462 Front Load Washer
Washing machine filling up too much,washes but will not empty?
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 12, 2008
How do I fix washing machine to finish emptying during rinse and spin cycle?
Long shot, but does it fill the same as when new? I would check the atmospheric switch which is a hollow tube that runs down the inside of the drum(not in the wash cage) when the water fills, It pushes air up to stop the fill. It may have gotten clogged. Or partially clogged.
Mar 28, 2016 | Fisher and Paykel Washing Machines
.My LG washing machine fills
If it fills and empties, that Eliminates The Pump. If no Spin Of the Actual drum, Could Be Belt-Stretched/Snapped. Motor brushes Worn. Or A Problem With the logic board Controller Panel.
Go for The belt/Motor brushes first.
Mike.
Jun 02, 2011 | LG Washing Machines
Hi my hotpoint wma63 fills with water for a wash, then empties
motor tacho not being sensored...motor or pcb fault...chopper board faulty bottom front right in machine.
Jul 31, 2010 | Hotpoint Washing Machines
Moffatt washer is washing and draining but not spinning out the clothes
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 03, 2009 | Washing Machines
Washer stop in middle of rinse cycle
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Frig. Gallery washer and it will fill up and drain but not spin. What could be wrong and how can I fix it??
Dec 02, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washing machine won't fill up with water
Hi can you tell me the make and model of the machine and if it makes any noise when it is trying to fill?
Then we can fix it!!
Feb 15, 2009 | Washing Machines
The Washing Machine fills and then empties with not running a wash cycle
possible a pressure stat fault. some pressure stats have a too high water detector which turns on pump
Mar 27, 2007 | Zanussi F1245W Front Load Washer
Bosch Classixx WFL 2462 Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
