Question about Maytag Atlantis MDG6400AW Gas Dryer
Gas flame comes on for 30seconds then goes out on my maytag gas dryer
  • Maytag Master
  • 5,568 Answers
All gas appliances I have ever seen have a thermocouple which can shut down the gas flow if there is a momentary loss of combustion. A lag in the response of these is normal since they must first be heated thoroughly to function.
This thermocouple is prone to failure due to its continuous exposure to high heat and yours has probably failed and a safety device is turning off the flame to avoid being without the normal degree of protection.
Posted on Nov 19, 2009
My Maytag Gas Dryer makes a loud buzzing noise when the ignighter and flame come on
thats a good sign the valves that those coils you replaced sit on are getting bad and you will sooner or later need a brand new gas valve
Oct 13, 2012 | Maytag Dryers
Dryer goes on, flame comes on but goes out soon, moisture accumulates on the door, clothes remain wet and very slow drying.
Hello Sam,
What the most likely problem is,is weak gas valve coils,when teh coils are weak the flame comes on when they are cool but once the gas valve coils get warm the quit working. It is a fairly common problem,so common in fact i have written this tip covering weak gas valve coils http://www1.fixya.com/support/r10174506-gas_dryer_starts_off_hot_but_after_while
GENE
Oct 19, 2011 | Maytag MGD5600TQ Commercial Dryer
Igniter comes on will not let the gas in. The gas burner does not come on Maytag model dg882s
Your have one of two problem causing the gas to not come on on your dryer.
1) the flame sensor is bad...if the igniter comes on and stays on and doesn't go off...usually within 1 minute the flame sensor isn't working as its supposed to
2) the coils on the gas valve could be the problem...if the igniter does indeed go off within 1 minutes and as soon as the igniter goes off if their is no flame the coils on the gas valve is what would need to be replaced
here is what each part looks like
FLAME SENSOR
Sep 14, 2011 | Maytag Dryers
The flame goes out after about 30 seconds. I have
one of the thermal sensors may be bad.
you may also have a faulty ignitor even though it glows it maynot be drawing enough current to keep the regulator open
May 28, 2010 | Maytag Neptune MDG7500AW Gas Dryer
Flame wont stay on
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 26, 2010 | Maytag SDG3606A Gas Dryer
Maytag drier goes off after flame comes on. Flame comes on for a second then power goes off. All lights on timer flash?
perhaps the igniter is not strong enough to keep the dryer lit. if it is orange in color you need to change it, it should be white hot to open the valve to keep the gas flowing. hope this helps.
Oct 27, 2009 | Dryers
Maytag Neptune MDG5500AWW gas dryer ignites, then flame goes out
The 'radiant sensor/ needs to be replaced. This sensor tells the system that the flame is lit and everything is good. Go to repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500aww-%3d%3di2681&PartID=2681
Oct 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer not heating
You may want to disconnect the vent from the back of the dryer and try it. Flame rollback will cycle the burner off by the high limit.
Considering what you have already done to it, if the problem still exists you probably have bad coils on the gas valve. make sure you replace them as a set.
The thermal fuse is a one time device. If it opens, the burner will not come on at all.
Apr 28, 2009 | Maytag Neptune MDG9700A Gas Dryer
I HAVE A MAYTAG ATLANTIS GAS DRYER STOPS HEATING ABOUT 5 MINUTES IN
the flame going out is normal. the heat cycles on and off as called for by the thermostat. If the heat doesn't come back on i would start by changing the gas coils.
Oct 08, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG6400AW Gas Dryer Logo
146 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
