Question about Sharp AR-M205 Copier
Power save mode
Is there any way to shut the power save mode OFF? my boss hates it and doesnt want it on. help
  • Sharp Master
  • 1,297 Answers
Enter in the User programs and select the auto power shut OFF setting.Use this setting to enable or disable auto power shut OFF,press 0 to OFF or 1 to ON.The program name is auto power shut off setting and the program number is 5.
Posted on Nov 22, 2009
Why does my Sony Cybershot DSCW370 Turn on but the LCD screen doesnt stay on????
You might have the Power Save Mode on, if camera wakes up after you depress the shutter button and the screen lights up, then more than likely you have the Power Save Mode on? The settings come in 3 values, screen turns off after 30 seconds, next setting is screen off after 60 seconds. Go the the cameras menu and then navigate to Main Settings, scroll down until you find Power Save Mode and adjust it to standard, hope this helps?
Sep 29, 2014 | Sony Cameras
Tip
Power saving mode officejet 6500 series
did you know that officejet 6500 series doesnt have any configuration about power saving mode (sleep mode).
it will turn to sleep mode after 1 hour.
if it is wireless, you need to turn off/on the product for you to use it again
on Mar 21, 2010 | Office Equipment & Supplies
Tip
Copiers Sharp AL-1631 AL-1641CS DESCRIPTION OF SPECIAL FUNCTIONS
Toner save mode
Reduces toner consumption by approximately 10%.
Power save modes
The unit has two power save modes of operation: preheat mode and auto power
shut-off mode.
Preheat mode
When the unit enters the preheat mode, the power save indicator will light up
and other indicators will remain on or off as before. In this condition, the fuser in
the unit is maintained at a lower heat level, thereby saving power. To copy from
the preheat mode, make desired copier selections and press the start key
using the normal copying procedure.
Auto power shut-off mode
When the unit enters the auto power shut-off mode, the power save ( ) indicator
will light up and other indicators except the ONLINE indicator will go out. The auto
power shut-off mode saves more power than the preheat mode but requires a
longer time before starting copying. To copy from the auto power shut-off mode,
press the start key. Then make desired copier selections and press the star key using the normal copying procedure.
Auto clear
The unit returns to the initial settings a preset amount of time after the end of copy, or
scanner job. This preset amount of time (auto clear time) can be changed.
Stream feeding mode
For description of the stream feeding mode, see "Stream feeding mode".
Resolution of AUTO & MANUAL mode
You can set the copy resolution used for AUTO and MANUAL ( ) exposure
mode.
on Mar 14, 2010 | Office Equipment & Supplies
What am i doin wrong with my boss radio? when i set a station when i shut the engine off i loss my settings
Sounds like your Memory +12V wire is not connected properly. If this wire does not have a constant source of power then you will lose all of your settings on your radio.
Things that may cause you to lose power through the Memory 12V wire:
  • Not hooked up properly to the battery
  • Bad battery
  • Bad ground
  • Loose wires
Boss 637UA manual
Sep 04, 2014 | BOSS AUDIO SYSTEMS BOSS 637UA - radio / CD...
Why doesnt it save my clock and preset settings
There is a wire on your stereo called the (constant) wire, it is usually either yellow or orange, this wire needs to be spliced into your power wire. It is constantly hot,hence the name. Find this wire and your presets and your clock should be good to go. let me know if this helps
Nov 25, 2010 | BOSS AUDIO SYSTEMS BV9994I Car Video...
Boss car amps
boss sucksss if you get one throw it up on craigslist and sell it to some ****** then buy something with higher rms.
no offense but boss is the ultimate piece of ****.
Mar 30, 2009 | Boss AUDIO SYSTEMS CX1800 Car Audio...
MY Boss br 1180 ,disk error
before you go out and buy a new hd try intializing your system.
unfortunaly you will lose all saved info, but you will either way. this test may save you some money.
with your 1180 in the off position press and hold the track 5 button below the fader and the redo/undo button that is just to the left of the rotarty knob and below the power button. while holding these two buttons press the power button and continue to hold the track 5 button and the undo redo buttons untill the test menu is showing. its takes about 15- 30 sec. in the test menu rotate the value knob till you see 23 initialize HDD and press ok. this process may take up to 30 mins. if this doesnt fixya then contact roland for a replacement.
Dec 06, 2008 | Boss Micro BR Digital Recorder
Batteries problem....
Try rechargable NiMH batteries. They are specifically designed for today's technology, and last much, much longer than traditional batteries. It doesn't matter about the brand -- Energizer, Rayovac, Duracell, generic -- I've found that they all tend to last about the same amount of time in my digital camera. But I only use rechargable ones anymore.
Nov 14, 2008 | Concord Camera Eye-Q 4060AF Digital Camera
Need help
You are confusing Hibernation, where the RAM is written to the HDD and power is turned off without unloading the OS, with Screen saver (control panel - display).
Mar 18, 2008 | HP Pavilion a1120n (PX759AA) PC Desktop
Sharp AR-M205 Copier Logo
326 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
