Motorola Mobility L9 Unlocked GSM Cell Phone Logo
Posted on Nov 19, 2009
I was just sending an image message and suddendly the screen dissapered. I need a help
3helpful
2answers
I have received a MMS. i have user name and password.please tel me where do i type this.i can not see any screen asking for username and password.please advise
Configure using settings wizard MMS for Nokia
1.Press the Menu key on your phone.
2.Scroll to and select Applications.
3.Scroll to and select Sett. wizard to launch the Nokia settings wizard.
4.Scroll to and select Operator.
5.Select Start > Multimedia message and follow the wizard's on-screen steps to automatically configure the phone with the required operator service settings.
Configure MMS settings
To configure MMS settings, select Menu > Messaging > Options > Settings > Multimedia message
Additional MMS settings include:
1.Image size - Define the size of the image in a multimedia message.
2.MMS creation mode - If you select Guided, the device notifies you when you try to send a message that may not be supported by the recipient device. If you select Restricted, the device prevents you from sending messages that may not be supported. To include content in your messages without notifications, select Free.
3.Access point in use - Select which access point is used as the preferred connection.
4.Allow anonymous messages - Reject messages from anonymous senders.
Download the device user guide for a comprehensive list of MMS settings
Send MMS Multimedia messages can be sent in a number of ways. An example of the steps required to send an image is listed below:
1.Select Menu > Photos.
2.Select the image you want to send.
3.Select
4.Select Via message.
5.Add the recipient name or contact number.
6.Select
Tips If you are unable to send and receive MMS, try these simple steps.
1.Check if the MMS settings (for example, MMS access point) are correct in your device. These settings are sent by the operator or service provider. See Operator or service provider settings.
2.Operators usually set a limit for the size of a picture message. If you need to send a picture that is large in size, you can resize it before it is sent. See Image size.
3.Contact your operator or service provider to confirm whether:
•Data plan is activated on your SIM card.
•Roaming is activated when you are not in your home network.
IF you want to see your MMS through go to your service provide site.and click the MMS and fill the username and password, and hit enter. you see your MMS in inbox double click to view the MMS.
This phone we can play internet or not?
Yes the Motorolla RAZR2 V8 is capable of networking features including text messaging, photo and video capture.
Turn on the phone with which the typing keypad could be used to create messages to be sent to family and friends. The camera on the phone also allows to capture, save and send images as well.
Once images have been taken, could be saved on camera or manipulated into screen savers, or display background images.
The phone has networking capabilities
1. your friends can send pictures to you
2. you can receive comment by typing them messages about several things
3. Enjoy the features of the phone by;
1. selecting the menu features
2. adjusting prodcutivity parts
1helpful
Have tred sending texts sets off sending ok then suddendly stops and says sending failed
Hi the problem you are having is with your message center number this is a common problem and usually happens after you have changed your sim card to another network all you need to do to solve this problem is call your service provider and tell them the make and model of phone you have then ask them for the correct message center number.
they wont charge for this and they will tell you how to set it up, you will also need to ask them to send you the latest wap and mms settings so you can use the net and send and receive picture messages. they wont charge for this either and they will send you these settings via txt message and this will then update your phone to the latest settings.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
2helpful
2answers
I have a samsung a777. I cant receive or send text........it saids it successfully sends but My friends dont get my text and they said they try to send me a text and it sends but i dont receive it can you...
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.samsung.com/us/consumer/mobile/mobile-phones/at-t-phones/SGH-A777EGAATT/index.idx?pagetype=prd_detail&tab=support
Check out the section on Messaging page 65 in your manual:
Important!: When creating a message, adding an image, a sound file, or a video clip to a text message changes the message from a text
message to a multimedia message.
Important!: Adding an image, a sound file, or a video clip to a text message changes the message from a text message to a multimedia
message. This also changes the Options that appear in this menu.
Note: A multimedia message should only be sent to a phone which can
support the receipt and display of this message type.
Note: If you exit from this View screen, you will need to go to the Messaging ➔ Inbox screen, the Recent Calls screen, or you will need to dial your Voicemail contact to access your messages.
Note: Messages can also be accessed by navigating to your Inbox (Menu ➔ Messaging ➔ Inbox).
Messaging Settings page 72 in your manual:
You can set up various options for using messaging services.
1. When the Idle screen displays, press the Menu soft key,
then select Messaging ➔ Messaging Settings.
2. Select the type of message settings that you want to
change.
• Text Message
• Multimedia Message
• Voice Mail
• Push Message
• Broadcast Message (SIM card dependent)
3. Press the Select soft key or the key.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Picture suddendly changed to "photo
hi! your lcd cpu is defective, here in the philippines we try to re heat the cpu and it works.
Images dont get forwarded with message in yahoo
Try sending the image as an attchment and not embedded there is usually an attatch tab click on that then/picture then browse to the pic on your pc attatch and send it's usually at the bottom of the page you send.John
Tv goes fuzzy and when turned of on stand by for 5 mins its ok
This is called image retention where the screen is not dissapating the last picture information quickly enough. This can be cured either by adjusting the settings on the Y-Sustain board or a software upgrade can fix the problem. Either way I suggest you contact an LG dealer to arrange an engineer to do this.
The LCD suddendly turned white
loose lcd connection, you need to open the unit and reconnect the the cables or flexwire inside, better seek professional fix.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
