Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
It sparked and died! the filters were clean and there were no clogs the machine is about 6 years old! I love this vacuum is there any fix?
  • Dyson Master
  • 379 Answers
Most likely the motor has failed, or possibly the switch.
Replacement motors and switches are avaible on eBay for about £25 / £5, however replacing either requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Posted on Dec 01, 2009
My vaccuum cleaner has lost its suction, how can i fix this?
Your vacuum most likely has a clog in the hose somewhere. It's a dirty job, but usually pretty easy to fix. They usually clog where there is a bend in the hose, such as near the brushes or near the body of the vacuum itself. It would be helpful to know what kind of vacuum you have. Sometimes the bag is full and debris starts to back up. That fix is very, very easy. Sometimes there is a clog in the hose because something was vacuumed up that should have been picked up instead. I (unplugging the vacuum first) generally take apart a wire coat hanger to snake my way through the hose. You may have to unscrew the brush area of your vacuum to access that end of the hose.
May 29, 2014 | Panasonic Vacuums
Motor issues
A faint burnt plastic smell is actually normal for these when brand new, but that normally disappears after a week or so. As for sparks, a thin trail of blue sparks trailing along the commutator (the uppermost part of the motor that can be seen rotating) is normal. However, if there are blue, orange sparks flying out of it its toast. The motor is dying in that machine.
Nov 23, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
We have the Kenmore progressive direct drive (bagless) and have had it for about 3 years. We have taken good care of it, and paid quite a bit for it hoping that it would last for a good long time. It has...
there has to be a clog or block somewhere - if the motor works, it should work did you try a wire coat hanger to go up in further where you cannot see?
Bets regards
Ck
Jan 15, 2011 | Kenmore Progressive Bagless Upright with...
Sweeper wont pick anything up. When the motor runs it sounds like the belt is broke, but it is not. It revs real high. There are no clogs and the filters are clean. I have no idea what it is, and I...
to me it sounds like a blockage?having worked on these machines for so long,when the motor runs high as you say then its under pressure im not convinced you have cleared the blockage take another look ,i use a old wire coathanger straightened out to push the rubbish out,if that fails,go out and buy yourself a new machine you derseve it and you will be surprised at what the new machine can do..adrian,,,,
Sep 06, 2010 | Fantom Vacums FM741 Twister Bagless...
No suction, filters have been cleaned/replaced!
Sounds like you most likely have two problems:
1: There is a clog somewhere in your air pathway, which is why you're not getting any suction at the end of the hose. Try disconnecting the hose from the machine and checking inside the various openings for clogs.
2: Your belt needs replacement, which is why you're not getting the lines on the carpet. Remove the baseplate on the underside of the machine and remove the brushroll, put the new belt around the motor pulley and replace the brushroll. Note that even if your old belt appears fine, it's probably stretched to the point that it's not agitating properly.
Otherwise, it is entirely possible that your motor is shot and is not able to effectively move air. This is very common with bagless vacuums, which is why the average lifespan of bagless vacuums is 1.5-3 years.
Good luck,
-R
Mar 09, 2009 | Bissell 6594 PowerForce Bagless Upright...
No suction in the hose for the hand held tools at all
Hi I had the same problem and my Hepa filter was clogged. You may wanna check that.
I hope that helps. This is my 4th Windtunnel and I hate this one also. I loved all the rest.
Jan 03, 2009 | Hoover U8361-900 WindTunnel 2 Bagless...
I have a dirt devil that is only 2 years old, I used it and sparks began to shoot out from the front grill area. I called dirt devil's corporate office at 12noon today July 25th, and was told that with out...
The sparks may be from the carbon brushes in the motor. Bagless vacuums do not filter dirt out as well as a bag does so dirt and grit gets sucked into the motor. Filters should be cleaned frequently and replaced at least once a year. If the filter gets clogged the motor can overheat. If you got two years out of a $39 vacuum you did well. Many people are lucky to get a year.
Mar 24, 2017 | Dirt Devil Vacuums
Bissell Healthy Home
1. Make sure the hose attachment is pushed all the way down into its receptacle. It will click softly when it's all the way down.
2. Detach the hose from the machine. Do this by twisting the grey fitting on the back of the machine. (Note: leave the attachment end of the hose plugged into the machine) Turn the machine on. Hold your hand over the hose fitting. If there's strong suction then there is a blockage in the hose.
3. If not, check in the fitting to see if something is stuck in there. On the back of the machine there is a long clear tube that travels down the back of the machine. Sometimes larger peices of paper get stuck in there. If something is in this tube, take a phillips screwdrive, remove the 7 black screws off and remove the blockage. Reassemble and try the machine.
4. There are two filters on this machine. The one that may be clogged and affecting the suction is located below the canister in the front of the machine. Simply pull ouot the tray and reomve the grey foam filter to clean. Rinse it out with warm water then allow it to dry. Replace in its tray then slide the tray back into the machine. The other filter is the HEPA filter and has nothing to do with the suction of the unit. It is an exhaust filter and does need to be changed at least once a year. It filters the air coming out of the machine. The first few times we used ours the whole house smelled "clean". Whne a new filter is placed in the machine that "clean" snmell returns. The filters are $25 apiece at Amazon.com.
5. As a maintainence item, remove the canister as though you were going to empty it. Place it on the ground, locate the two buttons (one clear plastic/one blue) on the front and back of the canister and remove the clear plasctic housing. This will allow you to clean the hundreds of little holes on the grey surface of the top of this section. (This looks like a circular colender.) To clean this, use an old toothbrush and scrub the dust and stuff into your grabage can. I do this once or twice a year. (Since I have a Shop Vac in the garage, I use this instead of a toothbrush.)
Hope this helps.
Dec 19, 2007 | Vacuums
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
78 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
