Question about Kenmore 96213 Electric Kitchen Range
Stove top units wont heat up - Kenmore 96213 Electric Kitchen Range
The problem turned out to be the 220 circuit breakers that had gone bad. It was an easy fix and only 16 dollars! That was a lot less than we were expecting!
Posted on Nov 21, 2009
Testimonial: "Thanks!"
Glass stove top error message wont go out, wont turn on?
What is the model number of your unit?
What is the error code?
Nov 22, 2012 | Kitchen Ranges
Maytag 8114p732 60 stove top works, oven does not
Check the heating element,to make sure it has a good connection,turn power off and remove,inspect,may need replacing.Also check circuit breaker at power box.
Nov 20, 2012 | Washing Machines
My stove poped and went off. I tripped the breaker and now the oven will not heat. Neither the top or bottom unit.
First I would look at the heating element in the oven and make sure it is all in one piece. there are usually one on the bottom and one on top. sometimes they will burn apart and short out to stove. if they look ok then do a quick check, I would turn off all knob on the stove top and oven. then try to reset the breaker. hopefully it resets ok. then turn on one at a time and see which burner or oven element has a short. when you find the bad burner or stove element it will trip the breaker again.
hope this helps
Jan 09, 2012 | Kenmore Kitchen Ranges
My heating in my maytag stove burnt out will that stop the glass top heating units from heating up
No. Sounds more like a power problem. Check your circuit breakers for the stove. You shoud be getting 240 volts to the stove. If you are only getting 120 volts the clock and lights will still work but no heating.
Mar 02, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My oven made a buzzing sound,and and smoke came out form the oven. Now it wont heat up, but the top stove still works...Any ideas? Thanks
fryed switch or fryed burner
if smoke came from inside stove likely the burner is fryed
try setting oven to broil and see if it heats up
if it does replace lower burner
Jul 31, 2009 | Ovens
Frigidaire model MGF331BFWA...Oven isn't lighting(heating)up
Stove wont heat up. Stove top elements are working fine. do you think it is the heating coil/element in the oven?
Mar 01, 2009 | Ovens
Electric stove top and oven
hi
if neither the cooktop nor the oven works check your voltage. Is there 240 volts to the unit. Flip the breaker off and back on. If that doesn't work, with the unit unplugged, remove the cover where the stove cord is connected and check the connections
Good Luck!!!
Dec 10, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Stove top works oven wont heat on 465
the ignitor needs replacing, that's the glow that you see. it's not getting hot enough to open the safety valve.
Dec 07, 2008 | Whirlpool GS460 Gas Kitchen Range
Kenmore ultrabake lights up when stove top is on but wont heat up
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
Nov 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ge true temp stove top burner wont stay on
dont know how old unit is or how familiar you arewiththe unit, but the burner will need to heat up and cycle off/on. no matter how high or low you set the setting it will heat to a specific temp and cycle off, if hte burner remained RED all the time the glass would crak( so dont go by appearnce of burner, the glass should dictate the temp
Nov 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore 96213 Electric Kitchen Range Logo
109 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
