Question about Phil & Teds E3 Jogger
Tyre is completely flat. what can i do? - Phil & Teds E3 Jogger
  • 419 Answers
You can purchase a replacement innertube at most bicycle shops as this a standard size.
I hope this helps.
Posted on Nov 29, 2009
Why does it feel like my tires are flat when I drive on the highwayin my 2013 Kia Rio when I just got the heat shields replaced because ey won't stay secured correctly? Is there a flaw in the design?
I don't entirely understand your reference to heat shields. The only heat shields I know of are associated with the engine exhaust system. While these can cause problems and make noise they don't affect the ride quality or cornering.
Your description of your tyres feeling flat while driving makes me think it is time to carry out a thorough safety inspection and in particular tyres, wheels, suspension and steering.
The symptom indicates a problem with wear or misalignment of the suspension (including the rear) and/or steering.
A thorough inspection is required to ensure the vehicle is safe. The feeling of flat tyres should ring alarm bells...
If the inspection and alignment check reveals no faults, I suggest you pay attention to the tyres. The symptom could be caused by tyre mismatch.
I have experienced this myself and also a number of cynical customers have, dubious of my diagnosis. One of the most unsafe cars I have ever driven, in theory, had nothing wrong with it. The car would be strongly influenced by minor defects of the road surface so without the driver doing anything at all the car would literally veer across the road by a complete lane. Being in control of the car was less like driving and more like wrestling.
The owner had replaced each tyre as it became worn. The result was four tyres of different manufacture and tread pattern.
Tyres do not travel exactly in the direction they are pointing. The difference between the actual and theoretical direction is called the slip angle. For the best ride quality and predictable braking and steering the slip angle of all four tyres should be identical or similar and that means fitting tyres of the same manufacture and type or at least in identical pairs. If that doesn't happen sometimes the slip angles are not sympathetic but in opposition with the distinctive "flat tyre" symptom, which is relatively rare so it is important to eliminate other possibilities first.
Mar 05, 2016 | Cars & Trucks
How do you fix a flat tire
there are a lot of quick fixes for tyres but generally anything sprayed into the tyre will not allow a proper repair
Replace the tyre with the spare and have a tyre shop carry out the repair. The case of the tyre has to drilled out to get the puncture repair plug in place and the rubber inside the case has to be perfectly clean so that the plug flap will adhere to the rubber for a good seal
anything you spry in will prevent this from happening
You may have to replace the tyre if you have been running on a flat tyre as the condition destroys the inner side walls.
Feb 13, 2015 | 2005 Toyota Prius
How do you fix a flat tire?
This picture has nothing to do with a flat tyre but if you have a flat this is what you do
First take wheel off vehicle
Locate the cause of leak
Remove the nail or what ever it is
Get a car puncher kit and follow the instructions
Fix the tyre and pump up
All done
Jan 10, 2014 | Android Apps
Front passenger side thumping at very low speeds
check if you tires have rayon cords or steel belts. this is a problem associated with the older tyres that had rayon cords as the main structure of the tyre. When left standing after running and allowed to cool the rayon belts actually took on a flat spot on the bottom and the noise lasted until the tyre warmed up enough for the tyre pressure to make the tyre round again. In extreme cold it may be the same for steel belted radials as the flat bottom of the tyre would hold the shape until the rubber warmed up .
Dec 13, 2013 | Nissan Xterra Cars & Trucks
My 2008 ultima tires will leak air to the extent they are almost completely flat. It started with the passenger side rear almost completely flat. I would fill with air and it will last for 2-5 days. Now...
Your tyres need checking for slow punctures or leaking valves. If you want to do it yourself. You'll need a tub or pool big enough for a complete wheel. Fill it with water, then, remove one wheel at a time and put it in the tub/pool. look for bubbles, the puncture is where the bubble come from.
Of course you could go to a tyre shop and get them to check, once done and you know your tyres are in good order, the only other thought is that it may be someone having fun at your expense, you could get some lockable valve caps.
Jul 19, 2010 | 2007 Nissan Altima 3.5 Sedan
How do you fix a cycle puncture - not sure how to get the tyre off its not completly flat
there are two type of valves, one is like a car valve and you can press the tiny button in the centre. The other style of valve you need to unscrew the small knob at the end of the valve which then lets you push it in to deflate the tyre.You also have to unscrew this knob to blow it up. Most tubes will let air out over time even if they are not punctured. If its not completely flat it just might need pumping up
Apr 24, 2010 | Cycling
I have a tw200 2007 and my rear tire is flat I do not have a user manual and I am having some difficulty removing the tire
Make sure that the tyre is completely off the rim beeding and push the tyre on the opposite side of the valve to the centre of the rim and then proceed to lever the tyre off (with tyre levers)about 100mm from valve on either end.
make sure you have undone the nut that secures the valve first.
Aug 06, 2009 | Yamaha TW 200 Motorcycles
Run flat tyre warning light is on i have checked tyre pressure
This will only come on when a tyre has dropped in pressure (not spare). It work on the principle that a tyre with less air has a smaller rolling circumference and therefore a different wheel speed. This is then monitored against other signals from other wheels and determined that a loss in pressure has occured.
If all tyre pressures seem ok, there could be a chance of a small unoticeable leak and would require a bath test. This is when the tyre is dipped in water and bubbles would appear where the puncture is.
Ultimately the system may just need to be reset, or has incorrectly been reset from a tyre change. For this you just press and hold the TPC button (located on the centre console above the gearstick - looks like a flat tyre with an exclamation) turn on the ignition to position 2 and the light will come on re then yellow,go out, come back on yellow. When it comes back on yellow it re-initializing the system. You can let go of the button and after 20 odd seconds the light will go out for the final time, completing the reset.
If the light continues to come on after the reset then you definitely have a puncture somewhere!
Hope this helps!
May 28, 2009 | 2005 BMW 3 Series
BMW 320D,2006- run flat tyre warning light is on. How do I reset?
Using the indicator stalk, navigate to the tyre pressure reset option, press the reset button twice in short succession but hold it in the second time until a tick appears on the display
Apr 19, 2009 | 2003 BMW 325
Flat tyre
We've just had same problem with a drawing pin. The tyres have an inner tube (like a bicycle tyre) which you can fix with a puncture repair kit- just find your local bicycle shop or somewhere like Halfords for this. Good luck!
Apr 25, 2008 | Quinny Buzz Jogger
Phil & Teds E3 Jogger Logo
213 people viewed this question
Top Phil & Teds Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Phil & Teds Baby Gear Expert? Answer questions, earn points and help others
