Question about Samsung V25 XVC 2800 Notebook
Can't view the screen
It was working fine, i was just try to find where 2 extend ram, But i couldn't found so i cls it as it is. After doing thatonly the laptop screen doesn't display i can use external crt monitor os works fine.
thanks in advance
  • 1 more comment
  • lucky346 Jan 11, 2008
    this was because of monitor cable was disconnected
  • Anonymous Mar 15, 2008
    I also
  • Goody407 Mar 15, 2008
    How do i re-connect the monitor cable on my laptop as i was trying to see what memory i have so i can upgrade some more, but when i tried to take the back off the monitor no longer works
  • 32 Answers
most laptops have an option to switch between CRT, CRT&LCD, & LCD... usually you have to hold down the 'fn' button and then press F5 to switch back and forth.
Did you try that? If that doesnt work let me know the model of your laptop and I will try to help you further.
Regards,
-Chester
Posted on Jan 11, 2008
Is motorola cls-1110 compatible with bpr40 radios
yes, with conditions. The CLS comes preprogrammed with frequencies and tone codes. The BPR requires software and cables. It is not a preprogrammed business radio, but a fully programmable business radio. If your BPR radios are first: UHF, then they can be programmed to match the CLS. Do note, a few of the CLS frequencies are approved by the FCC for low power only, meaning a maximum of 2 watt power output. Find a dealer willing to do the programming for you if you do not understand. Our shop does it often.
Mar 14, 2015 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Motorola cls 1410 on frequency 10 and need it to bw on 2
The manual can be found at:
http://www.axcesstechnologysource.com/manuals/cls_series_userguide.pdf
If you need replacements including a CLS replacement antenna, this place is great:
http://shopwiscomm.com/Motorola-CLS1110-CLS1410-C254041.aspx?sid=2181
Nov 22, 2013 | Motorola CLS 1410 (4 Channels) 2-Way Radio
I have a samsung tv crt with no sound i want to access the factory mode
I HAVE A TV WITH THE SAME PROBLEM. I CHECKED ALL THE POWER SUPPLIES AND I FOUND THEM ALL RIGHT. I TURN(INCREASED) THE SCREEN KNOB IN THE FLYBACK TRANSFORMER JUST A LITTLE BIT. ONE LINE APPEARED IN THE SCREEN. I SUSPECTED VERTICAL CIRCUIT IS DEFECTIVE.I CHECKED ALL THE COMPONENTS HERE AND I FOUND OUT THATONE OF THE RESISTORS IS OPEN. HOPE COULD HELP. TNX
Sep 11, 2013 | Office Equipment & Supplies
New memory, the board just beeps
First of all that board supports DDR400 (PC3200) so why did you get PC2100 chips?
Anyway, do a bare minimum test (only MB, CPU, RAM & PSU connected, nothing else). Remove all the RAM and test each one individually. Properly insert one into the first RAM slot and test by booting until the POST RAM test is finished. Shutdown and repeat the test with the same RAM module in slot 2 and keep repeating this for every slot. If successful in every slot, mark that module as working then try the other RAM modules using the same procedure.
  • As soon as you find one that doesn't fully pass the POST test, mark it as faulty.
  • If some pass in one slot but not another, then mark it as faulty.
  • If they all fail to pass on a specific slot, mark that slot as faulty and don't use it (you can use electrical tape to cover the slot for future reference).
Once you've finished the bare minimum test, try 2 RAM modules this time (use only the modules that you found to be working from the above tests). Mix and match the RAM modules & then try 3 together and even 4 (if you found all of them to be working fine).
Finally once you're satisfied you've found the modules that work properly, boot with memtest and test the RAM for any problems. If they all seem to work fine individually, boot them individually and test with memtest to determine which ones are actually faulty.
Jul 13, 2012 | HP Compaq Presario SR1610NX (ED865AA) PC...
WHEN I TURN MY LAPTOP ON I HEAR ONE LONG BEEP FOLLOWED BY TWO SHORT BEEPS AND THE SCREEN STAYS BLANK. WOULD GREATLY APPRECIATE ANY HELP
Dear Check your ram because it is 100% RAM's fault. If you are using two RAMs, you should try with one RAM and then try to power on if it will work its mean you have found the fault and problem have solved. If the problem will remain same and then you should replace the second RAM and pull out the first RAM and then try to boot up. I assure your problem will be solved.
Good Luck
Nov 27, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
We have the monitor hooked to a docking station for a laptop. I can not view the screen on the Viewsonic, but does display on laptop. I have been able to do an extende monitor view, but not the main view....
when you connect external monitor to a laptop u get two options in the monitor section of graphic properties tab
1.) extended
2.) clone
it is clear from ur post that u are using extended view
try using clone mode then both laptop screen and external monitor will show the main screen
other method is to disable the laptop screen and just allow external monitor to work, in this case laptop screen shows nothing but external monitor shows main screen
Sep 29, 2009 | ViewSonic VG700b 17" LCD Monitor
Motorola T5522 Talkabout
A User's Manual for Motorola CLS series is available online here.
It's file name is Motorola CLS Manual (PDF).
You would need Adobe® Reader® to view PDFs.
Mar 31, 2009 | Motorola T5522 (7 Channels) 2-Way Radio
Flickering picture
It sounds like it is to much work for your system. The ram is relitively low and your graphics card needs upgraded. When you try to play it full screen, your computer has to try to produce a higher quality result and it is just too much work. I would recommend a ram and video upgrade if possible. If you can't upgrade the video, at least get more ram. It's not a guarantee that it will make a big difference depending on your video card, but there is a good chance that it will.
Nov 14, 2008 | Computers & Internet
User's guide
Good luck and kind regards.
Dec 29, 2007 | Radio Communications
Samsung V25 XVC 2800 Notebook Logo
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
