I need to write a program in java that will connect to a mysql database and execute some sql queries and display the result. suggest me a link with similar implementation / discussion of such concepts for guidance.
  • sumitnxt Nov 19, 2009
    great help thanks a lot
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. In java we can use Java Database Connectivity (JDBC) drivers to connect to database.
Follow these steps to connect to JDBC---
1) Load the driver, using Class.forName (DriverName);
2) Get the connection object, Connection con = Driver.getConnection (loaded driver name);
3) Create a SQL statement, Statement s = con.createStatement();
3) Create Resultset object using the statement created above, ResultSet rs = s.executeQuery("sql statement");
There are a lot of webs dealing with this subject. However, a few of them are listed below for reference please---
Programming in Java to connect a My SQL database
Programming in Java to connect a My SQL database 1
Programming in Java to connect a My SQL database 2
Programming in Java to connect a My SQL database 3
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 19, 2009
How can I restore my SQL database from .frm files?
You just copy the .frm files to the to the databse folder but you also need to copy the ib_logfiles and ibdata file into your data folder. I have just copy the .frm files and copy those files and just restart the server and my database is restored.
Best Professional Resume Writing Service Online from Washington USA...
Oct 22, 2015 | Oracle MySQL Enterprise Ed 1-4 Socket...
How to fix mysql error 1046?
For the database import, before you attempt to import the "flat" file data in, you need go to your local DB (MySQL) and create new database
After that you can import!
Also check this links:
http://www.repairtoolforsql.fixtoolbox.com/ Fix Toolbox for MySQL
http://www.sqlservercentral.com/Forums/Topic1618894-2893-1.aspx
Apr 09, 2015 | Quest Software Toad for MySQL
'Table does not exist' error in MySQL, although it really exists
it usually means that no table exists in the default database with the given name. In some cases, it may be that the table does exist but that you are referring to it incorrectly. Maybe your database and table names are case sensitive if they are located on a file system that has case-sensitive file names. Or perhapsall references to a given table within a query must use the same lettercase.
Use SHOW TABLES to check which tables are in the default database.
Well, if you are sure that table is exist and you write its name exactly such it should be, then I suppose something wrong with the database, it can be seriously corrupt. And in this case you need a professional help. This tool must help at any rate - Recovery Toolbox for MySQL https://mysql.recoverytoolbox.com/
Mar 11, 2015 | Oracle MySQL Enterprise Ed 1-4 Socket...
I want ot link my inventory database to another pc
Create user account for second system in Sql
If u want to get data by code means u need to create
connection to database by using jdbc connection string .
then write a query to acces data.
create statement
pass query to that statement
run query
Statement statement=con.createstatement();
statement.executequery(querystring);
Oct 15, 2009 | Microsoft Designing ASP.NET Applications...
How to connect from jsp login page to database
hey try this code......just found it on the net... Put the code in tomcat and test the application through browser. The browser should display the display the data stored in the table.
Here is the code of our JSP file
<%@ page language="java" import="java.sql.*"%>
<html>
<head><title>Read from mySQL Database</title>
</head>
<body>
<p align="center"><b>Following records are selected from the 'jakartaproject' table.</b><br>&nbsp;</p>
<div align="center" width="85%">
<center>
<table border="1" borderColor="#ffe9bf" cellPadding="0" cellSpacing="0" width="658" height="63">
<tbody>
<td bgColor="#008080" width="47" align="center" height="19"><font color="#ffffff"><b>Sr.
No.</b></font></td>
<td bgColor="#008080" width="107" height="19"><font color="#ffffff"><b>Project</b></font></td>
<td bgColor="#008080" width="224" height="19"><font color="#ffffff"><b>Url
Address</b></font></td>
<td bgColor="#008080" width="270" height="19"><font color="#ffffff"><b>Description
of the project</b></font></td>
String DRIVER = "org.gjt.mm.mysql.Driver";
Class.forName(DRIVER).newInstance();
Connection con=null;
ResultSet rst=null;
Statement stmt=null;
try{
String url="jdbc:mysql://192.168.10.2/tutorial?user=tutorial&password=tutorial";
int i=1;
con=DriverManager.getConnection(url);
stmt=con.createStatement();
rst=stmt.executeQuery("select * from jakartaproject ");
while(rst.next()){
if (i==(i/2)*2){
<tr>
<td bgColor="#ffff98" vAlign="top" width="47" align="center" height="19"><%=i%>.</td>
<td bgColor="#ffff98" vAlign="top" width="107" height="19"><%=rst.getString(2)%></td>
<td bgColor="#ffff98" vAlign="top" width="224" height="19"><a href="<%=rst.getString(3)%>"><%=rst.getString(3)%></a>&nbsp;</td>
<td bgColor="#ffff98" vAlign="top" width="270" height="19"><%=rst.getString(4)%></td>
</tr>
}else{
<tr>
<td bgColor="#ffcc68" vAlign="top" width="47" align="center" height="19"><%=i%>.</td>
<td bgColor="#ffcc68" vAlign="top" width="107" height="19"><%=rst.getString(2)%></td>
<td bgColor="#ffcc68" vAlign="top" width="224" height="19"><a href="<%=rst.getString(3)%>"><%=rst.getString(3)%></a>&nbsp;</td>
<td bgColor="#ffcc68" vAlign="top" width="270" height="19"><%=rst.getString(4)%></td>
</tr>
i++;
rst.close();
stmt.close();
con.close();
}catch(Exception e){
System.out.println(e.getMessage());
</tbody>
</table>
</center>
</div>
</body>
</html>
Feb 27, 2009 | Compaq Computers & Internet
How to write jdbc connections
http://www.jdbc-tutorial.com/
window.google_render_ad();
welcome_title_image.gif Java JDBC Tutorial Java JDBC Tutorial
The JDBC ( Java Database Connectivity) API defines interfaces and classes for writing database applications in Java by making database connections. Using JDBC you can send SQL, PL/SQL statements to almost any relational database. JDBC is a Java API for executing SQL statements and supports basic SQL functionality. It provides RDBMS access by allowing you to embed SQL inside Java code. Because Java can run on a thin client, applets embedded in Web pages can contain downloadable JDBC code to enable remote database access. You will learn how to create a table, insert values into it, query the table, retrieve results, and update the table with the help of a JDBC Program example.
Although JDBC was designed specifically to provide a Java interface to relational databases, you may find that you need to write Java code to access non-relational databases as well.
JDBC Architecture jdbc.jpg Java application calls the JDBC library. JDBC loads a driver which talks to the database. We can change database engines without changing database code.
JDBC Basics - Java Database Connectivity Steps Before you can create a java jdbc connection to the database, you must first import the
java.sql package.
import java.sql.*; The star ( * ) indicates that all of the classes in the package java.sql are to be imported.
1. Loading a database driver,
In this step of the jdbc connection process, we load the driver class by calling Class.forName() with the Driver class name as an argument. Once loaded, the Driver class creates an instance of itself. A client can connect to Database Server through JDBC Driver. Since most of the Database servers support ODBC driver therefore JDBC-ODBC Bridge driver is commonly used.
The return type of the Class.forName (String ClassName) method is “Class”. Class is a class in
java.lang package.
try { Class.forName(”sun.jdbc.odbc.JdbcOdbcDriver”); //Or any other driver } catch(Exception x){ System.out.println( “Unable to load the driver class!” ); } 2. Creating a oracle jdbc Connection
The JDBC DriverManager class defines objects which can connect Java applications to a JDBC driver. DriverManager is considered the backbone of JDBC architecture. DriverManager class manages the JDBC drivers that are installed on the system. Its getConnection() method is used to establish a connection to a database. It uses a username, password, and a jdbc url to establish a connection to the database and returns a connection object. A jdbc Connection represents a session/connection with a specific database. Within the context of a Connection, SQL, PL/SQL statements are executed and results are returned. An application can have one or more connections with a single database, or it can have many connections with different databases. A Connection object provides metadata i.e. information about the database, tables, and fields. It also contains methods to deal with transactions.
JDBC URL Syntax:: jdbc: <subprotocol>: <subname> JDBC URL Example:: jdbc: <subprotocol>: <subname>•Each driver
Feb 01, 2009 | Microsoft Windows XP Home Edition
After installing DB2 query is not executing
could you check whether you are connected to the database, where you are trying to create table,
check the database list, then connect to the database you want then execute the table creation ddl,
if no db found then create a database then proceed.
Dec 05, 2008 | IBM DB2 Connect Enterprise Edition for PC,...
I installed DB2 in my laptop . then i go to all programs->DBCOPY1(default)-> command line tools -> command editor then write down query to create a table but i cant build it it is showing CREATE TABLE...
Before you create a table you need to:-
1. create a database
2. create a username and password or use the admin generated userid
3. connect to the database
you can then create a table and use the database
Please post if you do not know how to do this and i'll give you some links
MySQL Database
THE SYSTEM REQUIRMENTS ARE
MySQL Tools
1. A SQL server : This is an engine which provides access to your databases.
2. Client programs for accessing the server : A program allows you to enter queries directly and view results
3. A client library for writing your own programs : You can write your own programs into the client library using C.
Recommended Hardware Requirements For Mysql Installation
  1. Pentium V processor
  2. 128 MB RAM
Note that MySQL can be installed on a platform with as little as 32 MB
RECOMENDED SOFTWARE TOOLS for better performance
IT is recommended to have at least 128MB memory.
You can freely download MySQL from the website http://www.mysql.com MySQL runs on many varieties of UNIX, as well as on other non-UNIX systems, such as Windows and OS/2. MySQL runs on hardware from home PCs to high-end server. MySQL can be installed on Windows XP, Windows Server 2003, Red Hat Fedora Linux, Debian Linux, and others
Sep 08, 2008 | Sun MySQL
Final yr project
Nice project you can easy solve this problem first you want to known how to connect the java with sql or some other database. http://www.academictutorials.com/ this is the site this help you for your project. If you have any problem just contact me i will clear it.
Feb 17, 2008 | Computers & Internet
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
