Question about Lexmark X4270 All-In-One InkJet Printer
How do I get a confirmation sheet(first sheet copy
  • 250 Answers
You can view the manual online (or download it) from the Lexmark website
http://www.lexmark.com/publications/pdfs/2007/4200/ug/en/frameset.html
Posted on Nov 19, 2009
Not printing confirmation page
CHECK IF THERE IS ANY ALARM, CHECK CARTRIDGE, CHECK PAPER PICK UP ROLLER AND SEPARATION PAD, CLEAN OR REPLACE IT.
Jul 22, 2013 | HEWLETT-PACKARD HP 2140 Fax
DOUBLE SIDED COPYING
First normaly copy first side, then take copied paper and set it in bypass tray, when you do thath, the copier ask you for paper size and type, choose correct sett. and confirm with OK.The side on wich you want to print must be face down in bypass tray.
May 11, 2010 | Canon iR 1600 Laser Photo Printer
Confirmation page needed
Press MENU - 2 4 1 then you can choose to have that feature ON or OFF. the +Image means that it will also print a copy of the first page sent so you can actually verify the document sent.
Mar 31, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
"Delimited" gibberish in Excel
You could try to change the whole workbook font to a known good one or do it a sheet at a time by doing a "select all" then setting the font.
It sounds as if though you are trying to import a web page including the HTML code which may well cause the problem you see.
I prefer to do that type of thing with a
"Get External Data"
"new web query"
which will put things into a sheet in such a way as you can use them in other calculations
Whenever you open the sheet it will go and get the latest information for you automatically so you can then select what you want and copy that to another sheet. to use to keep track of things.
Oct 17, 2009 | Microsoft Excel 2003 (065-03992) for PC
How to photocopy double sided A4 sheets?
you copy first side normaly. then on left side open bypass deck.Put the paper, so that the side on wich you want to print is down. Automatically when you put paper in bypass, the machine ask you wich format is it ( eg. A4 ), confirm with OK, then you need to tell machine wich type of paper ( eg. plain paper ) and OK. then green copy key.
May 02, 2009 | Canon iR 1600 Laser Photo Printer
FIRST PAGE PRINTING AFTER SENDING FAX
Scroll through the menus for REPORT PRINT to set confirmation.
Jan 27, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Fax Confirmation Sheet
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
BROTHER INTELLIFAX 4100
NEED TO CHANGE SETTING IN REPORTS TO ON + IMAGE
SHOULD BE IN SETUP RTEPORTS
Aug 22, 2007 | Brother IntelliFAX 4100 Laser Fax
Lexmark X4270 All-In-One InkJet Printer Logo
57 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
