Question about Ricoh Aficio SP C811DN Laser Printer
My Ricoh SPC811dn is displaying a message : Set the fuser unit correctly, how to I solve this?
    Sniper:
  • 58 Answers
Pull the fuser out ....look around inside the fuser cavity I belive on the left lower side as your looking in..... your looking for a sensor that is knocked out of its bracket...... reinstall sensor and fuser and you should be good to go
Posted on Feb 26, 2010
Ricoh c8 problem solution
hi sir help me rico sp 100su c8 error whats the problem
May 19, 2014 | Ricoh Aficio SP 100SU e Laser...
Ricoh AFicio C3260 has fuser not set message
Pull the fuser out and put it back in or order a new fuser unit. Please fill out my form for additional information http://ryanluke.net/?page_id=37
Sep 19, 2013 | Ricoh Aficio 2022 All-In-One Laser Printer
I have a Ricoh CL7100 printer. It has for some time displayed a red error lamp and a message "replace fuser oil unit (type g)" I was advised a while ago that I could continue to use printer (and have...
OPEN FRONT DOOR OF COPIER LEFT SIDE SHOULD BE A CLEAR CONTAINER WITH OIL IN IT. THAT IS WASTE OIL FROM FUSER. HAS FILLED UP. EMPTY IT OR FIND A RICOH DEALER THAT CAN SELL ONE TO YOU. try ebay saw one on there
Apr 18, 2017 | Ricoh Office Equipment & Supplies
How do I set the fusing unit correctly?
How to fix the Error: "Set the Fusing Unit correctly"
Ricoh Aficio SP C411DN & C410DN Color Laser Printers
Instructions:
1. There is a short Wire Jumper (color: black or white) on the inside of the main electrical connector of the Fuser Unit.
Note: These procedures can be done without removing the outer plastic housing of the Fuser Unit.
2. Press the side clip (or tab) and first pull the tab end of the large connector plug from the main housing of the Fuser Unit.
Warning: The connector plug wires are very short -- it extends a maximum of about 1 inch (or 2 cm) from the main housing of the Fuser Unit.
3. Use a small screwdriver and gently remove the small white connector that the Wire Jumper is plugged into.
Warning: Try to remember the correct orientation that this small connector is plug-in.
4. Use a small screwdriver (or a small flat blade) and gently raise the small tabs on the front of the small connector, while pulling gently on each end of the Wire Jumper.
Warning: Do not remove Wire Jumper forcefully by pulling.
5. Make sure that this Wire Jumper is plugged into the same pins as the one on the old Fuser Unit that is being replaced. There are only three pins that the jumper can plug into.
6. Reassembly the Fuser Unit by plugging in the two connector that were removed.
7. Replace the Fuser Unit into the Ricoh printer and secure properly.
8. Power on the printer -- it should start-up and go to the ready state without any errors.
9. The END.
Apr 26, 2010 | Ricoh 4506 Copier
Replaced Maintenance Kit and receive "Set Fuser Correctly" message. Will not work with new fuser. Old fuser works fine but new fuser will not seat correctly. This is the second new fuser that I have...
That's a common problem when you are not using Original fuser. Sounds like you are using a comaptable one. This printer is specific. It needs original parts.
Is the fuser from the original manufacture?
Mar 05, 2010 | Ricoh Aficio SP C410DN Laser Printer
Getting error: set fusing unit correctly on Ricoh Aficio SP C410DN. Have just changed thermister in fusing unit.
Take the unit out and install it again, making sure it is in all the way and sitting correctly. Then reset the machine and see if the error goes away.
Nov 10, 2009 | Ricoh Aficio SP C410DN Laser Printer
Error message - Reset Oil Fuser Unit Correctly
The fuser oil sits on top of the fuser and has silver contacts on it. Sometimes the contacts in the machine get bent. Turn off the printer and check the contacts and if bent use needle nose pliers to make straight again. Make sure the contacts on the fuser oil are not drity.
May 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio 2238c: Fuser Oil Unit
It is what it is. No, you can't refill it
Apr 06, 2009 | Ricoh Office Equipment & Supplies
Service Call SC548
fuser problem . danger . call tech
Dec 18, 2008 | Ricoh Aficio SP C811DN-DL Printer
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Oct 25, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh Aficio SP C811DN Laser Printer Logo
366 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
