Question about Hutchins HTN - 2000 Air Straight Line Sander
Sander seems to struggle, doesn't run as fast as it used to. Air supply hasn't changed. Also, where can you buy parts if necessary?
    President:
  • 1,149 Answers
I am not sure of a parts source, but you should consider putting some air tool oil and try to lubricate the air motor. It might be the problem ...a few drops in the air connection
Posted on Nov 19, 2009
Where can i buy a drive belt for a clarke model bt1009a sander
from Clarke direct or 'sanderparts'.
Clarke CS4-6D Belt and Disc Sander Manual - Clarke International
https://www.clarkeservice.co.uk/manuals/woodworker/cs4-6d.pdf
Faulty goods should be returned to their place of purchase, no product can be returned to us without prior permission. This guarantee does not effect your statutory rights. IN THE BOX. The following should be supplied inside the box. If any parts are missing, please contact your local Clarke dealer. • 1 x Belt/Disc Sander.
Where can I buy a belt for a clarke model Bt1009a sander - Fixya
www.fixya.com/support/t14574446-buy_belt_clarke_model_bt1009a_sander Oct 7, 2012 - The belt width is 0.31in or 5/16in or 7.9mm. Its pitch (distance from tooth to tooth) is 0.20in or 1/5in or 5mm. Its total height is 0.09in, and tooth height is 0.045in. It has 60 teeth, making the total length 12in. I found a replacement at sdp-si.com, part number A 6R 3-060031. Look here for timing belts (inch), then ...
Clarke Power Products BT1009A - Free Shipping on Orders Over $99 ...
https://www.summitracing.com/parts/clk-bt1009a Find Clarke Power Products BT1009A and get Free Shipping on Orders Over $99 at Summit Racing!
[PDF]CA30 20B - Clarke
https://www.clarkeus.com/~/media/NewClarke12.../PL56091130.as... Translate this page
If the batteries are incorrectly installed or inaccurately connected, the electric components of the machine may be seriously damaged. The batteries may only be installed by qualified personnel. According to the battery model number (WET or GEL) being used, set the functional circuit board and onboard charger (optional).Missing: bt1009a
Clarke Sander Parts ' Buy online at sanderparts.com
https://www.sanderparts.com/categories/Parts/Clarke/ Clarke sander parts - buy replacement parts for all models of Clarke sanders.Missing: bt1009a
clarke model bt1009a parts Google Search
Mar 12, 2018 | Sander Tools & Hardware - Others
SANDER RPM IS LOW , EVEN AFTER MAX AIR SUPPLY
Turn dial on side,or on bottom of sander should change rpm.
Sep 19, 2012 | Ingersoll Rand 313A IR-313A 7"Dia 5000RPM...
Need part for Mastercraft belt sander 54-7240-8 I need to replace the belt on the motor that drives the belt drive assembly. The motor runs ok but, the wheel that drives the sanding belt doesn't turn...
Anyone has a broken belt sander 54-7240-8 within Canada? I could use a particular part from it to fix mine. If you do, email me at mstevlik@zoznam.sk
Thanks.
Sep 27, 2011 | Tools & Hardware - Others
I have a Dewalt sander I am using for wet sanding on a boat hull. I have already burned one sander out do to moisture I figure is there a way to protect the new sander from this happening again I am...
Impossible not to get water in the bearings and motor. It is vibrating too fast. You need air sander. Or sand dry, then wet sand the primer by hand.
Dec 17, 2010 | Dewalt DW421 5'' orbital sander
Sander stops
There can be a few problems. First is your air supply the right pressure and volume for the sander. Check that at the quick connector to the sander itself. Second, if it is cold and moisture is high, ice can get into the sander which will slow it way down. Third, and probably most likely cause, is the sander well oiled and the parts inside clean. Fourth, mechanical issues: the drive motor may be well worn out inside, the bearing that the main shaft for the sander may be worn out & so forth. Hope this helps you, Rick
Apr 28, 2009 | Air Tools & Compressors
Electric Bosch hand held orbital sander belt not rotating properly
My guess is that your sander got gunk in the belt and other rotating parts and you are either burning up the belt, or (hopefully not) the motor windings. Rick
Apr 13, 2009 | Air Tools & Compressors
As soon as i apply my sander to the surface it stops sanding
hi a major problem with pneumatic tools is that nobody ever seems to oil them! try droping tool oil or a light machine oil down the air inlet and leave over night and then run the tool on full ,if this doesnt work then strip the tool and clean and make sure that the blade sealing surfaces are good
hope this helps ian
Mar 21, 2009 | Dynabrade 57810 Dynabug Orbital Air Sander...
Hutchins HTN - 2000 Air Straight Line Sander Logo
222 people viewed this question
Top Hutchins Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Hutchins Tool and Hardware - Other Expert? Answer questions, earn points and help others
