Question about IBM Wheelwriter 30 Typewriter
IBM golfball typewriter- how is the carriage unlocked?
I have an old IBM golfball typewriter and the carriage appears to be locked. I can't find any obvious way to unlock it!
  • 610 Answers
If it is an IBM Selectric, there is no lock. Usually means it needs a good cleaning and lubrication. Could also be a broken drive cord.
Posted on Nov 19, 2009
I have an IBM Selectric 11 Typewriter that will not backspace. Can you please help? tks
If it moves a little but not enough the tab tensioiner on the R. side is broken not a bad job but yuo must know how.
DickyO
Oct 30, 2012 | IBM Office Equipment & Supplies
IBM Lexmark typewriter carriage return won't return to left position
Hi:
Open the top cover and locate the shiny rod that the carrier moves back and forth across. Use some WD-40 on a rag to clean it well the apply a light coating of it to the entire shaft.
Jun 21, 2012 | IBM Wheelwriter 1500 by Lexmark Electronic...
IBM Wheelwriter 5 is locked up
The gears on the motor do crack and come off. if so you need a tech.
DickyO
Oct 05, 2009 | IBM Wheelwriter 30 Typewriter
Can't find carriage lock on Olivetti Lettera 25
Learn how to unlock the carriage in Olivetti Lettera 22 Manual posted by Ed Cornish (Carriage Locking Lever 7). It is a different machine model, but the lock/unlock mechanism might be the same.
You can see the full manual at Ed’s Flickr account or you can download it from here: http://dl.getdropbox.com/u/1322442/Olivetti%20Lettera%2022%20Manual.pdf (temporary link)
Aug 28, 2009 | Olivetti Lettera 25 Typewriter
My IBM Selectric System 2000 Wheelwriter 6747/6747-2 has quit typing. The keys respond and the carriage moves but no type appears.
The plastic cap on the print solenoid is probably broken. We sell them with installation instructions for 20.00 including shipping. DickyO Cleveland Business Machines 216-241-0027
Jun 04, 2009 | IBM Wheelwriter 30 Typewriter
How to use certain parts of the keyboard.
Only 2 of the letters or symbols will the others will be on another element (ball).
DickyO
Mar 26, 2009 | IBM Office Equipment & Supplies
Old remington typewriter
G'day mate, most likely cause is that the drawband is broken/disconnected. Look under the right-hand side of the carriage,you would have to tilt the typewriter on it's back. There you will see a small hook where the drawband should be attached to. If not, set the typewriter on it's feet again and move the carriage to the extreme right then looking down past the left thumb wheel you will notice a drum with the drawband attached. Rotate it until the drawband hook come into view. Get a piece of strong wire about 12 inches long,fashion one end into a hook,thread it through the machine under the carriage,from the right-hand side until it appears just over the drum. Ayyach the drawband hook to it and pull your piece of wire out to the right. You will notice the drum rotating and the increasing tension on the drawband , this good,nothing is going to snap, break etc. Hook the drawband on to it's latch and try the typing. If the typewriter's carriage moves slowly it means that there is not enough tension on the main-spring located inside that drum. Do not depair, because by removing both side plates you will see a large screw on each side of the back cover plate remove these and then you will see the mainspring drum in it's entirety. There will be a winding gear central to the drum,loosen the locking pawl and begin winding in aclock-wise direction to increase the main-spring tension. Test the carriage occasionally for tension.
When all is OK reverse all what you did before.  Cheers and goo luck from Australia....
Oct 11, 2007 | Office Equipment & Supplies
How do you unlock a locked carriage?
The solution is not right--there is a carriage return release lever on the far right of the typewriter, that engages a notch on the underside of the roller/carriage return--push it forward to release the lever and you are in business--it has a spoon shaped end and its on the right side
Jan 24, 2006 | Olivetti Lettera 35 L Typewriter
IBM Wheelwriter 30 Typewriter Logo
255 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
