Question about LG Vu CU920 Cellular Phone
I need to set up my voicemail message and figure out how.
I cannot figure out how to set up my voicemail for my alcatel one touch. How do I do it?
Voicemail isn't set up by the phone it is set up by your cellular provider. Usually is a paid for add-on to your plan. You need to check you have it. Then you dial into the number and set it up.
Search Results Once voicemail is set up, new messages will be played automatically. ... To access the voice mail system after the initial setup, press and hold the 1 key for 2-3 seconds. If prompted, enter the voicemail password to access new messages.
Show Me How on your Alcatel ONETOUCH Fling ' Boost Mobile
devicehelp.boostmobile.com/scenario/ONETOUCH.../Set_Up_and_Access_Voicemail
voicemail set up for Alcatel one touch Google Search
Dec 10, 2017 | Alcatel Cell Phones
How do i set up my voicemail...manual not explaining ...please list steps ....
Once you call your voicemail service, you'll be taken thru step by step instructions to set up your voicemail.
To call your voicemail service
1. From the Home screen, tap Phone.
2. Touch and hold down 1.
If this does not work, you need to set up your voicemail number. Your subscription includes an answering service, callers can leave a voicemail message when you cannot answer a call. Usually, the voicemail number is saved on the SIM card. If not, contact your service provider to get your voicemail number. You can then enter the number manually.
To enter your voicemail number
  1. From the Home screen, tap .
  2. Find and tap Settings > Call settings > Voicemail settings.
  3. Enter your voicemail number.
  4. Tap OK.
Hope this helps. If so, please rate the solution.
-regards,
M
Mar 05, 2011 | Sony Ericsson XPERIA X10 Cell Phone
How can I remotely change my outgoing message on my panasonic cordless home phone?
It will depend on the exact model of your phone, but generally you can access the message area by dialing your home phone, waiting until it goes to voicemail, and pressing the # key any time during the voicemail message. You'll be prompted to enter your PIN and will then be able to change any settings you need to. If this doesn't work, please reply with your phone's model and we can get it figured out. Good luck.
Mar 04, 2011 | Panasonic Cell Phones
LUCENT PHONE 18D PARTNER/CAN'T GET VM MSSSAGES
Has someone changed the password by accident?
To figure this out for sure, we need to know the model of the voicemail.
When you dial into the voicemail to check messages, the recording voice comes on and says "Welcome to Partner......."
Fill in the blanks.
Sep 24, 2008 | Lucent PARTNER18 Corded Phone
Voicemail answering
Contact your mobile service provider's helpdesk for further assistance on activating your VM
Aug 28, 2008 | Motorola Mobility RAZR V3
Can't set up voicemail.
Click on Menu=>Messages, scroll down to Voicemail. Now push the Men button (TOP button above round dial, center). Scroll down to Voicemail Setup and hit select. Put your cellphone # in (you may need to include the 1 first). Now you can retrieve messages by holding down the #1 button or the CALL button from the message screen.
Mar 08, 2008 | Cell Phones
Voicemail alert tones
I think that there is just a generic message alert tone setting applies for both vm and text. If your voicemail alert tone and message alert tones are the same, this is probably the case. I have searched the menu on my phone and haven't found any setting to change vm tone specifically.
Feb 14, 2008 | LG Shine KE970 Cellular Phone
Razr v3 setting up voice mail
Which mobile service carrier do you use? Are you trying to setup voicemail to play your messages on your phone, or are you trying to setup greetings and what not inside of the voicemail?
Your voicemail settings depend on where you live, and there are hundreds of different access numbers. If you are trying to setup the phone to connect to voicemail and are on Cingular/AT&T, call them at 800-331-0500 from a different phone and they can walk you through the setup easily since they have access to the appropriate voicemail access number for your location.
Dec 17, 2007 | Motorola Mobility RAZR V3
Razor v3 voicemail
Changing the voicemail message would entirely depend on your provider - how they set it up for you and how you can setup your own message. They must have a specific number you can dial to set your voicemail message. This setting is not available on your phone; rather voicemail messages on the voicemail server of your provider. So, the best way out would be contact the provider. Cheers
May 10, 2007 | Motorola Mobility RAZR V3
LG Vu CU920 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
