Question about Sharp MX-2700N Color Copier
Fk1 error code - Sharp MX-2700N Color Copier
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Will a maintenance required code FK1 prevent printing on a Sharp 3100N printer/copier?
Yes it will if SNMP is ticked in the Ports tab situated in the printer properties of the print driver. To check this open up Printers & Faxes on the PC, right click the sharp printer & select "printer properties" Click on the 3rd tab along(Ports) & on the lower left hand side you should see the SNMP box. If it is ticked then untick it, apply & OK. This should allow to print. If this box is ticked then when the copier displays any maintenance code it wiil allow copying but not printing.
Hope it helps.
Dave.
Sep 25, 2014 | Sharp Mx-3100n Color Copier Super...
What is sub code of fk1
FK1 refers to the maintenance life counter for the fuser unit.
The fuser rollers have a fixed life count & when that count is reached FK1 is displayed. If the rollers are worn they should be replaced but if they are ok you can reset the fuser maintenance counter in SIM 24-4 FUSER UNIT
Aug 08, 2014 | Sharp MX-2300N Color Copier
Service code: FK1
Since you neglected to state the type of device, make or model, I am assuming everything and sending you what I guess!
http://search.aol.com/aol/search?&s_qt=sb&q=service+codes+fk1%2Cfk2%2Ctk1&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Jan 21, 2013 | Audio Players & Recorders
Code:fk1 sharp 2301 N
That is a maintanence code. Usually says that the fuser rolls are at a certain copy count.
Here is what to do.
Press in order on the consol. # * C * That will enter the machine into what is called SIM mode.
Then enter the number 24 then 4 for that code, then press execute. You may want to just do the clear all maintenance code too.
Apr 26, 2011 | Sharp MX-2300N Color Copier
Can you tell me what code FK1 means?
Your fuser has gone past 200,000 sheets of usage and it's time for a rebuild. You could reset the counter with sim code 24 but eventually it will clog up with waste toner and your rollers will tear up. Sharp has rebuild kits for your or you could just buy a new one.
Jan 07, 2011 | Sharp MX-3501N All-In-One Printer
IT WENT BANG THEN SMOKED FROM NEER FAN, NO ONE WILL TOUCH IT LOCALY FALKIRK FK1 1QJ
What happened was there was an arc between layers of the multi-layer circuit board in the HCA2400 power amp at the rear of the unit. It takes extensive labor to repair the board and $20 of parts.
If you replaced the fuse or if no lights come on, it likely took out the power supply too... that is about $30 of parts.
IF THE LIGHTS still come on, get a replacement HCA2400 module (includes heat sink) and replace it. They cost about $175 online.
I have repaired several of these, but it requires a lot of skill and time to repair the module as the burned area must be carved out and replaced with jumpers and several semiconductors have to be replaced and probably a metering resistor which is usual source of the smoke.
Sep 14, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I have a sharp copier MX2700N with an error code of FK1. What do I need to do to fix it?
fuser count has reached 200,000 copies. hit P*C* then 24, start, then 4 start. select Fuser Unit and Fuser Acum Day then execute at bottom then yes. Hit CA button. copier should reboot and clear code.
Apr 17, 2009 | Sharp MX-2700N Color Copier
Sharp MX-2700N Color Copier Logo
332 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
